MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Unread 06-12-2008, 11:28 AM   #1 (permalink)
Nashville to abr-1 conversion
Ive got a recent Les Paul classic and I would like to convert the bridge from nashville to abr-1. Any thoughts or opinions, as well as info where to get the conversion parts is welcome. Thanks for your time!
Everybody knows the secret...Everybody knows the score...
Pogue Mahone is offline   Reply With Quote
Advertisement
Unread 06-12-2008, 04:36 PM   #2 (permalink)
Re: Nashville to abr-1 conversion
Just plug the larger holes for the Nashville with some doweling, layout the ABR spacing, drill out with a tap or screw by hand for the ABR studs, install...play. Just did it to my '88 Dot and it does make a difference. Most Gibson dealers have the parts and there are many sources online...or you can buy machine screws from a hardware store and make your own custom length studs (hint: longer studs in the body sound pretty good).
ES350 is offline   Reply With Quote
Unread 06-13-2008, 05:26 AM   #3 (permalink)
Thank you for your reply ES-350, good to hear others have done this successfully! I figured doweling would be the way to go, though Ive heard there are conversion studs you can buy to make the swap. Thanks again for the info!
Unread 06-13-2008, 06:22 AM   #4 (permalink)
You can also ream out the holes of an ABR-1 & it'll fit on Nashville studs if you're just after the look & feel of a tune-o-matic...
Frutiger is offline   Reply With Quote
Unread 06-13-2008, 07:31 AM   #5 (permalink)
Tom99SS's Avatar
Try Faber Parts a CV Guitars
Look at the ABR-59 and the BSWkit. This looks like a great alternative to the Nashville Bridge.
'09 Les Paul R8 - Iced Tea
'11 Les Paul R6 - GoldTop
'11 Les Paul '57 Custom BB
'13 Les Paul R9 - Washed Cherry
'13 Les Paul R0 - Washed Cherry
'14 Les Paul R9 - LemonBurst
'15 63 ES 335 - Cherry
'16 Firebird - VS
'14 Am. Vintage '52 Tele
'14 Am. Vintage '56 Strat - Aged White
'14 Am. Vintage '59 Strat - Sunburst w/ Maple neck
'07 Marshall Vintage Modern 2266 w/ 425A+425B cabs
'12 Marshall 1987x w/ 1960AX+1960BX cabs
'10 Marshall Class 5
Tom99SS is offline   Reply With Quote
Unread 06-13-2008, 10:44 AM   #6 (permalink)
Thanks guys, I just checked out the CV Guitars site and I think I'll be using the BSWkit. Looks like good stuff! Thanks again!
Unread 07-12-2008, 11:14 AM   #7 (permalink)
It is, first rate quality (put my 68 GT PAF Conversion right which had a Schaller bridge and Nashville posts installed at some point i the past).
djd100 is offline   Reply With Quote
Unread 07-12-2008, 07:56 PM   #8 (permalink)
So Relax's Avatar
I installed Browns Guitar factory conversion posts. Its simple, completely reversible and with a tonepros AVRII it worked wonders.
So Relax is offline   Reply With Quote
Unread 07-12-2008, 08:19 PM   #9 (permalink)
Belzeebub's Avatar
So...let me get this straight. Do Classics come stock with Nashvilles?
2008 Gibson Les Paul Classic Heritage Cherry with Guitarforce Vintage '57s
2010 Fender American Standard Stratocaster Maple Olympic White
2006 Epiphone Dot Cherry
2009 Taylor 214CE
Marshall JCM 2000 TSL602 60W 2x12
Epiphone Valve Junior combo
Acoustic AG15
Digitech RP1000
Belzeebub is offline   Reply With Quote
Unread 07-12-2008, 08:32 PM   #10 (permalink)
Boleskinehouse's Avatar
Yes, at least they have since '05 I believe. They used to come with ABR-1s. My '99 has the ABR-1.
