Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Unread 10-02-2010, 07:29 PM   #1 (permalink)
help with les paul standard serial #
So theres a 1994 gibson les paul standard for sell that im interested in and the seller doesnt want to give out the full number for "security reasons" but said the first two numbers were 9 and 4.
b_ryceeeee is offline   Reply With Quote
Unread 10-02-2010, 07:32 PM   #2 (permalink)
Bartlett Retrospec Member
KS 5150's Avatar
Re: help with les paul standard serial #
It should be the first & 5th digits that denote the year....the second digit would be the first part of the day of the year it was built, so a 4 sounds off....I'm pretty sure there's less than 400 days in a year...
2007 Gibson Les Paul G0 Darkburst VOS
2003 Gibson Les Paul Standard Light Burst
1989 Gibson Les Paul Custom Black Beauty
2009 Gibson Explorer Classic White
2012 Epiphone Budokan # 496/1000
2002 Peavey Wolfgang Special
2013 EVH Striped Series R/B/W (incoming )
2012 Fender Stratocaster 2-Tone Sunburst
1980 Fender Telecaster
Peavey 5150 2X12 Combo
KS 5150 is offline   Reply With Quote
Unread 10-02-2010, 07:56 PM   #3 (permalink)
Yeah i thought it was the first and 5th digit too.
Unread 10-02-2010, 08:02 PM   #4 (permalink)
Tim Plains's Avatar
I wish people would read the stickies (before posting and especially before giving advice) because the info is all there...
There are always exceptions to these rules, the two listed below are worth noting:
Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers. There should be a space after the 1st digit with the 4 and 5 digit serial numbers, and no space with the 6 digit numbers.
The 1st digit indicates the year of manufacture for the 4 & 5 digit serial numbers, these were used from 1989-1999. The 1st and 2nd indicate the year of manufacture for the 6 digit serial numbers which we've been using since 2000.
Examples -
9 xxx = 1989 (4 digit number beginning with "9" used only in 1989)
0 xxxx = 1990
9 xxxx = 1999
00xxxx = 2000
05xxxx = 2005
Those beginning with "94":
In 1994, Gibson's Centennial year, many instruments have a serial number that begins with "94" for the year, with the remaining 6 digits indicating the ranking number.
Tim Plains is offline   Reply With Quote
Unread 10-02-2010, 08:11 PM   #5 (permalink)
Examples -
0 xxxx = 1990
9 xxxx = 1999
00xxxx = 2000
05xxxx = 2005
Yup, im an ediot!. Haha
Unread 10-02-2010, 08:13 PM   #6 (permalink)
RobP's Avatar
RobP is offline   Reply With Quote
Unread 10-02-2010, 08:50 PM   #7 (permalink)
KS 5150's Avatar
Examples -
0 xxxx = 1990
9 xxxx = 1999
00xxxx = 2000
05xxxx = 2005
Alright, point taken with the '94's...I was just trying to help...
