#1 (permalink) |
Hello. I know there's lots of threads around about this, but damn I just can't find a solution!
I need a Les Paul with a whammy bar that can play the parts I recorded with a Strat whammy bar. Bigsby's have the wrong range for this. I also need to be able to tune to drop D in 5 seconds flat between songs. This rules out Floyd Roses. There's other custom shop things around, Wilkinsons, Stetsbars, but I've never seen these in person. Any help? I played a 2010 Epiphone Plus Top Pro today and it sounded great, I love the split pickup option and the Floyd Rose felt very nice. But how can I drop a D with the locking nut? I'm looking for ONE guitar that I can rock straight through a set - les paul thick rhythm sounds, overdriven chords with total defintion, some clean single-coiley rhythm stuff, one song in drop D, and two songs with Whammy bar stuff... |
#4 (permalink) |
Re: Need a les paul whammy bar with no issues
Just pick up the Gibson Axcess and a D-Tuna. Or that Epiphone.
You can even do this on the cheap. Here's an Agile AL-2000 with a Floyd and 24 (!) frets: ![]() Or an Agile AL-3000 with a Floyd:
#5 (permalink) |
You could just tune it by ear. Just make 6th string 7th fret equal to open 5th string. Easy as hell. Or a clip-on tuner works well.
'10 Epiphone Les Paul Standard Plaintop in Heritage Cherry Sunburst(ギー太?) ![]() '09 First Act SFA Series 1 Lola CE-120 in Gloss Black Behringer UM300 Ultra Metal Distortion Pedal Vox Cambridge 30 Reverb Vox AmPlug Azusa Ver. |
#6 (permalink) |
If you don't use a D-Tuna, you can cheat and tune the low E with the fine tuner on the screwed all the way down. Lock the nut and then you can quickly back the fine tuner off enough to do drop D.
#7 (permalink) |
![]() Join Date: Feb 2010
I have a gold Stetsbar available if you're interested . .
FS Stetsbar for LP . . Gold If you plan to gig with this you will need to be plugged into a tuner to make adjustments between songs. Otherwise they work great, and installation is simple drop in with no mods needed.
mylespauls
#9 (permalink) |
Use your ear! That usually doesn't take much time as long as your D is in tune. It's going back up that's the bitch.
| Tags |
| bigsby, epiphone, floyd rose, les paul, whammy bar |
