Go Back   Les Paul Forums > MLP Community > Front Desk
Unread 09-30-2010, 01:09 PM   #1 (permalink)
58_Iced_Tea's Avatar
Signature help
Yes, I searched. I found the answer to be "it's in quick links". I don't see signature mentioned in my quick links. Is there a minimum post requirement, perhaps?
58_Iced_Tea is offline   Reply With Quote
Unread 10-01-2010, 02:44 PM   #2 (permalink)
Harmony's Avatar
Re: Signature help
You need to go to your user Control Panel (CP).
On the left side, edit signature. There you will have a box to add your signature.
There is no minimum post count to add one.
Harmony is offline   Reply With Quote
Unread 10-01-2010, 04:27 PM   #3 (permalink)
Re: Signature help
Sorted. Thanks.
Unread 10-01-2010, 10:33 PM   #4 (permalink)
Re: Signature help
Test
1963 Silvertone 1449 with the "Amp in case"
1975 Gibson Dove Custom
1998 Ovation Celebrity
???? Fender "parts-o-caster"
2008 Les Paul Traditional
2006 Taylor 314ce
Unread 10-02-2010, 01:25 AM   #5 (permalink)
Harmony's Avatar
Re: Signature help
One other thing, if you want your signature to show in every post, be sure the box under additional options box is checked.
Otherwise you will have to check the 'show your signature' box each time you want it to show.
Unread 10-30-2010, 03:42 AM   #6 (permalink)
JDS
JDS's Avatar
Re: Signature help
No mention of signature in my Control Panel. My CP only has the following options:
Your Control Panel
Your Profile
Edit Your Details
Customize Profile
Profile Privacy
Networking
Contacts & Friends
Social Groups
Settings & Options
Edit Avatar
Edit Email & Password
Edit Options
Edit Ignore List
Subscribed Threads
Folders
Subscriptions
List Subscriptions
Edit Folders
Miscellaneous
Event Reminders
Paid Subscriptions
JDS is offline   Reply With Quote
Unread 10-30-2010, 04:25 AM   #7 (permalink)
Epi Verification Expert
-=[Shifty]=-'s Avatar
Re: Signature help
Hmm, maybe there is a post limit?
It should be there, between "Edit Avatar" and "Edit Email & Password".
Shifty's Channel
-=[Shifty]=- is offline   Reply With Quote
Unread 10-30-2010, 04:55 AM   #8 (permalink)
JDS
JDS's Avatar
Re: Signature help
It now has miraculously appeared...
Unread 11-25-2010, 03:50 AM   #9 (permalink)
ijustdontgiveaf's Avatar
Re: Signature help
to clear this up for anyone stumbling over this thread: there is a minimum limit.. you don't have the option in the CP if you have less than 10 posts (at least that's the way it was in my case)
2009 LP Custom '68 Reissue 5A-Quilt Top Firemist
2009 LP Studio Ebony
2012 Lapstick
Marshall YJM100
Marshall AFD100
Marshall 1960av
ijustdontgiveaf is offline   Reply With Quote
