#2 (permalink) |
Re: Vintage neck adjustment tele
Loosen the strings and unbolt the neck, lift it up out of the pocket just enough to get the screw driver in to adjust. then bolt it back down and re-tune to check relief.
Nigel is always one louder than you. |
#3 (permalink) |
I normally unscrew the pickguard and slide it off completely. Might need to move the d and g strings off to the side to get the tool in there comfortably.
edit- Tech said it best ^ while I was typing! |
#4 (permalink) |
I would assume because of the travel (and its cold as all hell) that I gained a bit of relief, its not bad but I like mine pretty close to straight. Probably 1/8 turn or so.
#5 (permalink) |
![]() Join Date: Sep 2007
What do know the guy that knows for a fact ALL Fender have high frets, doesn't know this.
IMO let it acclimatise before ya touch it.
#7 (permalink) |
The proper way is to REMOVE THE NECK watch for any shims before ya take it off note where they are so you can return them. Not all are shimmed some are though. your welcome.
#12 (permalink) |
I slacked the strings put a capo on the first fret unbuttoned it broke the nitro loose, put a quarter turn on the neck and it is almost perfectly straight now. All put back together and tuned up in 5 minutes. Easier than I thought.
| PUP adjustment question. Not possible to set neck PUP to 3/32... | dnottis | My Other Guitars | 0 | 01-11-2009 05:43 PM |
| Neck adjustment screw hitting switch wires??? | decoy205 | Pickups | 10 | 12-19-2008 07:42 AM |
| FT: Fender Custom Shop Vintage Heavy Relic Tele HB neck (Olympic White!) | ikeyedyourcar8i | Member Classifieds | 12 | 12-08-2008 09:41 PM |
| PLEK, what the heck? Traditional neck adjustment | twiddlebug | Gibson Les Pauls | 4 | 11-11-2008 10:14 PM |
| Neck relief adjustment | dtube | Luthier's Corner | 2 | 08-29-2008 07:40 PM |
