Go Back   Les Paul Forums > Music Gear > Other Guitars > Fender
Like Tree32Likes
Unread 07-26-2012, 03:49 PM   #1 (permalink)
FLICKOFLASH's Avatar
Thumbs up MJT – Custom Aged Fender Guitar Finishes by Mark Jenny
MJT Custom Aged Guitar Finishes Photo Gallery
I have been admiring his work for years.I think he does the best relic refins
Bodies, Necks Hardware items in mjtele aged guitar finishes store on eBay!
5F6-A, mojotop, MrRhoads and 3 others like this.
FLICKOFLASH is offline   Reply With Quote
The Following 3 Users Say Thank You to FLICKOFLASH For This Useful Post:
Unread 07-26-2012, 05:58 PM   #2 (permalink)
toppsseller's Avatar
Re: MJT – Custom Aged Fender Guitar Finishes by Mark Jenny
He does great great work and their customer service is better than anything that I've ever experienced. Highly recommend.
toppsseller is offline   Reply With Quote
Unread 07-28-2012, 04:51 PM   #3 (permalink)
dazzypig's Avatar
I bought a tele body off him a couple of years ago. They are fantastic.
Why put of 'till tomorrow what needn't be done 'till next week?
dazzypig is offline   Reply With Quote
Unread 07-28-2012, 05:05 PM   #4 (permalink)
slapshot's Avatar
Location: Fishing.it's like yoga but I get to kill something
Send a message via ICQ to slapshot
if you can't paint & want a partscaster none better really.
suppose even if you can paint but can't be arsed to they're a good deal
i'd love to see a nash & MJT side by side though.
slapshot is offline   Reply With Quote
Unread 07-28-2012, 05:07 PM   #5 (permalink)
diceman's Avatar
Mine:
Unread 07-28-2012, 05:09 PM   #6 (permalink)
slapshot's Avatar
shoreline or aztec?
Unread 07-28-2012, 05:38 PM   #7 (permalink)
diceman's Avatar
Firemist.
Unread 07-29-2012, 08:42 PM   #8 (permalink)
5F6-A, Shai`tan and CHUNKYNECK like this.
Unread 07-31-2012, 04:43 AM   #9 (permalink)
5F6-A's Avatar
Send a message via Skype™ to 5F6-A
good to know thanks!
“The function of prayer is not to influence God, but rather to change the nature of the one who prays.” Sören Kierkegaard
5F6-A is online now   Reply With Quote
Unread 07-31-2012, 06:29 AM   #10 (permalink)
fretno's Avatar
ma MJT tele
CHUNKYNECK and fairlanericky like this.
fretno is offline   Reply With Quote
Unread 08-01-2012, 09:15 AM   #11 (permalink)
PSM
PSM's Avatar
That's badass. The number 2 guitar on my want list right now is a Charcoal Frost Metallic Strat with a body that's been beat and worn to hell. I was gonna try to do something myself with a little more "artistic" approach, but I may have to look into pricing from him.
Thanks for the post!
I think an amp rig update is overdue...
PSM is offline   Reply With Quote
Unread 08-01-2012, 09:35 AM   #12 (permalink)
CHUNKYNECK's Avatar
I just recieved delivery of my new MJT Fiesta red strat body today. Great timing on the post Flick.
Waiting on a Custom shop 69 loaded mint green pickguard and wilkinson brass block unstamped vintage trem before i can get it together. The checking doesn't show in the picks but it looks sweet.
CHUNKYNECK is offline   Reply With Quote
Unread 08-01-2012, 09:35 AM   #13 (permalink)
PSM
PSM's Avatar
For someone who's never done it before, how easy/hard is it to swap all the parts from my current USA Strat onto one of his custom bodies? What tools/skills are required other than unscrewing/screwing? I'm assuming some light soldering?
Unread 08-01-2012, 09:49 AM   #14 (permalink)
CHUNKYNECK's Avatar
It's very easy, just need a soldering iron, screwdriver, couple of drill bits to fit trem claw screws and strap locks and a couple of rags or towels to protect the old shiny body. If you aren't comfortable doing a setup on it i'd recommend just putting it in to get it done at the shop. If you are then go for it. De solder the jack to trem claw and swap everything over. Then re solder to claw. Same with pickups to jack, Easy. Be sure to check that you have a vintage trem before ordering the body. There are heaps of clips on youtube of the assembly process so it's worth having a look at them before you start.
Unread 08-01-2012, 10:20 AM   #15 (permalink)
PSM
PSM's Avatar
Thanks for the info. My current trem won't work with his custom bodies?
Unread 08-01-2012, 10:32 AM   #16 (permalink)
World Class Service
martin6string's Avatar
Nice bodies although not to the level of what Bob Davenport does. My humble opinion, of course.
martin6string is offline   Reply With Quote
Unread 08-01-2012, 10:32 AM   #17 (permalink)
CHUNKYNECK's Avatar
I think you might have a 2 point trem? If so you would have to re drill the body to take the two point trem. If it has 6 screws at the front of the trem plate, a vintage tremolo, it should fit.
Unread 08-01-2012, 11:19 AM   #18 (permalink)
PSM
PSM's Avatar
Yeah, it's just a 2 point, I believe. A stock, maybe '99 (?) Standard American Strat. I bought it basically new but don't remember what year that was.
Unread 08-01-2012, 03:48 PM   #19 (permalink)
slapshot's Avatar
what's this "wilkinson brass block unstamped vintage trem" ?
i'm only down down with this one which appears stamped & steel? But like anything else vintage style they mke I'm down to give it a razz
Unread 08-01-2012, 10:11 PM   #20 (permalink)
CHUNKYNECK's Avatar
i'm only down down with this one which appears stamped & steel? But like anything else vintage style they make I'm down to give it a razz
I found it at GFS, at 37 bucks i thaught it was a great option seing as i plan on aging it. It will be my first attempt at aging so i didn't want to risk screwing up an expensive callaham etc. Having a second look it might not be a wilkinson? I was tossing up between this one and the stamped wilkinson with solid steel block. The wilkinson stamped one also had a stamp on the trem plate which doesn't look true to the vintage look i'm going for.
http://www.guitarfetish.com/USA-Spaced-Solid-Brass-Block-Tremolo-Complete-Kit_p_1239.html
Unread 08-03-2012, 01:30 AM   #21 (permalink)
slapshot's Avatar
yes i see that does appear to be something else.i thought they'd brought out something new with a brass block i was going to try for a change.
small point,irrelevant to some,but the wilkinson has staggered holes through the block too so each string breaks at pretty much the same angle.i thought it was nice.
i've had a few,aged them,I think they're pretty much tops actually.
wouldn't think twice about putting a wilkinson strat or tele bridge plus their tuners & P90s in something
CHUNKYNECK likes this.
Unread 08-03-2012, 03:12 AM   #22 (permalink)
CHUNKYNECK's Avatar
Yeah i'm kinda pissed that the one i ordered isn't a wilkinson but seems to be made for gfs. Still, i hope it's decent enough quality. The brass block hype got the better of me and i like how it hasn't got a name stamped on the plate. With a little luck the fender stamped saddles from my classic 60s mim will fit on it or the block will be suitable to swap out with the classic trem. I'll let you know what i think of it and if it's worth the 37 bucks when it arrives.
Unread 08-03-2012, 04:12 AM   #23 (permalink)
slapshot's Avatar
dont they sell brass blocks specifically for the mexican and various trems?
ive generally gone for the 1 piece trems ive found on the old japanese strats now and have a spare wilkinson brand new here that may or may not be utilised for something
Unread 08-03-2012, 06:22 AM   #24 (permalink)
CHUNKYNECK's Avatar
Yeah, they have brass blocks for mim, import and usa. I've read somewhere that the later mim classic series and road worn trems are pretty close in spacing to the usa vintage. I don't know for sure but it would be awesome if the blocks and saddles where interchangeable. I think the brass blocks alone are about 25 bucks so i played it safe and went for the whole usa trem kit for 12 bucks more.
I'm trying to put this thing together on the cheap but still hoping for it to end up better than my best playing/sounding strat which is currently a 60s road worn. The 7.25 neck profile is choking out on 2 step bends on the 14 to 18th fret high e string. Hoping a 9.5 radius neck on this one will prevent this problem.
Unread 09-01-2012, 06:23 PM   #25 (permalink)
fretno's Avatar
Love ma MJT , just tracked this .lead is the MJT w/ DiMarzio Area T , IK slash jcm
SoundClick artist: Fretless Jamz - page with MP3 music downloads
fairlanericky likes this.
Unread 09-02-2012, 12:07 AM   #26 (permalink)
fairlanericky's Avatar
Hey fretno, nice sounding clip, thanks for posting. The Tele a'int bad either.
Ric
84 Ebony Studio
12 White Blonde MJT Tele
12 Surf Green MJT Tele
Line6 SpiderValve Mk II
"shattered dreams, empty streets, runnin' from the law man"
fairlanericky is offline   Reply With Quote
Unread 09-02-2012, 07:03 AM   #27 (permalink)
fretno's Avatar
Ric
Thanks man ! MJT's got it going on
Unread 09-02-2012, 08:13 AM   #28 (permalink)
MrRhoads's Avatar
Send a message via ICQ to MrRhoads
Here´s 3 pictures of a "Yngwie" yellow i custom ordered recently.
It´s made from photos of Yngwie Malmsteen´s the Duck which is a old olympic white which has gone yellow.
I´m holding it in different angles to show it´s different nuances in different lighting.
Don´t have a body yet to spray it on and yes it´s 100% nitrocellulose
Proud user of "JonesyBlues Customshop" parts
T-Top info read this http://www.mylespaul.com/forums/pick...490r-490t.html
Alot of good wiring help http://www.mylespaul.com/forums/tone...g-library.html
Help on soldering http://www.mylespaul.com/forums/tone...ow-solder.html
Capacitor info http://www.mylespaul.com/forums/tone...apacitors.html
MrRhoads is offline   Reply With Quote
Unread 10-16-2012, 08:36 PM   #29 (permalink)
snaredrum's Avatar
Mark is making me a Jaguar at the moment. got these pics last week, before he puts the clear on and checks it and everything...
excited isn't the word.
5F6-A, Syrus and fretno like this.
www.facebook.com/themadelinerust
snaredrum is offline   Reply With Quote
Unread 11-08-2012, 09:08 AM   #30 (permalink)
fretno's Avatar
Nice !
