#1 (permalink) |
Really enjoying the epi standard I got last month, but the bass is a little muddier than I'd like it to be. Any suggestions for cheap and simple ways to get better clarity in the low end out of the stock pickups? (Cheap and simple meaning I can't afford a new amp either right now
)Thanks, everyone, keep on rocking
#2 (permalink) |
'MLP Mid-West'
![]() Join Date: Jan 2008
Re: Any suggestions to clear up low end?
Are you using the stock pots/caps?
You can replace the pots/caps with better quality ones, and your guitar will really open up. Also: What kind of amp are you using? BB
I use: WB Custom Pickups--6707 VTP/VTPH, 5707 Prototypes, Habaneros, Firewaters DeTemple 'Sweet Spot' Pickups (Strat) RS Guitarworks Electronics Jonesy's Caps |
#3 (permalink) |
get an eq pedal bro. boss ge7. or an mxr graphic eq. pickups are like a guitars microphone. you wouldn't see bono from u2 using a cheap shure sm58 right? so it's your jop to get pickups that sound good. your amp only puts out the sound you give it from the pickups. if the pickups are muddy the amp will sound muddy. i think an eq pedal is a cheap fix but it doesn't cure muddy pickups. the thing i found with epiphone guitars is the neck pu is always muddy and the bridge sounds way to shrill. but my epi's all have gibson 57+(bridge) and 57 classic(neck) pickups.
#5 (permalink) | |
![]() Join Date: Sep 2007
Alot of people dislike the stock pups because they find the neck too muddy and bridge too shrill, and change their pick ups out . |
#7 (permalink) | |
Changing stuff all depends on what ya want. |
#8 (permalink) |
'MLP Mid-West'
Not necessarily. I used to be a "knobs on 10" guy; then I put in an RS kit, and my guitar absolutely came alive. Now I tweak the knobs, because they actually work like they were supposed to. (Maybe my R9 just had bum pots in it--who knows?)
Just because you have your knobs on 10 doesn't mean you're getting the best signal through the electronics in you guitar to your amp. True, volume on 10 should cut out the tone circuit (as I remember). Quality pots DO make a difference. This is an old argument; in my experience you can improve your guitar's tone by putting better components in it. BB
#9 (permalink) |
^ Alpha pots are quality pots. IMO just as good as the now MIM CTS. But what the hey whatever . I have CTS in my Sheraton , and or course my Fenders, Alphas in my Epi lps. no noticeable performance diff.
#10 (permalink) | |
![]() Join Date: Dec 2007
#11 (permalink) |
'MLP Mid-West'
Never tried Alpha pots, so my clue bag is empty on those.
![]() I do love the Superpots from RS for my volume controls...have them on 4 of my guitars. ![]() BB
#12 (permalink) | |
MLP Trucker
![]() Join Date: Apr 2008
"I'm male, between the ages of 18 and 49 with a loud mouth and a gun; I AM the American Dream"-Anthony DiNozzo "I've never used one, but I hear good things about them."
#13 (permalink) |
I just do not use mine at all. I mean really. I Never use my tone knobs and rarely use my volume. I don't have any need for it. I may rewire it just because I like to tinker, but I am not expecting any miraculous event to happen when I am done.
#14 (permalink) | |
Also - and especially if you're on carpet - try to raise and/or tilt back your amp/speaker cab. I have an Epiphone Valve Jr. that sounds like mud when it sits on the floor, but will scream when raised up. You might also try dropping the neck pickup down a little bit if you're playing in the middle position, or drop the bass side of whatever pickup is giving you the problem down by a quarter or half turn and see if that helps. |
| Gibson Black Custom neck flaw, hair under clear coat | MetalMan | Gibson Les Pauls | 39 | 11-09-2009 03:57 PM |
| P90 pickup suggestions? | romonster | Pickups | 7 | 05-11-2008 12:20 PM |
| Looking for suggestions... | Bonehead | Gibson Les Pauls | 1 | 05-04-2008 12:28 PM |
| Need suggestions | uloozer | Gibson Les Pauls | 15 | 04-26-2008 12:47 AM |
| Site Changes - Suggestions? | Alex | The Backstage | 55 | 11-02-2007 08:16 PM |
