#1 (permalink) |
Problems with Pickup / Electrics Upgrade
Hi all,
New to this, so I hope i've put this in the right place. I have just taken the plunge and attempted a swap for my Epiphone Les Paul 1998. I have put two Seymour Duncan pickups in and changed all of the pot / switch / wiring!! This is my first attempt to do this and its failed BADLY!!!....so any help would be gratefully received. In brief, the problem is am getting NO sound from the bridge pickup and more strangely whilst the neck pickup works and gives out a reasonable-ish voulme and volume pot will increase and decease the volume does, I cant increased the volume of the guitar using the amp....i can turn it to the top and it makes no difference. The amp is working fine for my other guitars. Any ideas please. Peter. |
#3 (permalink) |
TONE FREAK
![]() Join Date: Mar 2008
Re: Problems with Pickup / Electrics Upgrade
"Pro Guitar Wiring Upgrades Built & Designed by a Guitar Player with over 33 years of Experience" ![]() Jonesyblues.com for Professional Guitar Wiring Upgrades & DIY Kits Questions? Email to: jonesyblues@yahoo.com or Call 1- 574-249-8816 Aged Parts, Vintage Tone Caps & Wire in my ebay store Jonesyblues Youtube channel Jimmy Page Wiring.com GOD ROCKS! |
#4 (permalink) |
First of all - if your Duncans have red and white wires, you must connect them together. Connect the red and whites together, and tape them off (unless you're doing some fancy wiring which I doubt).
I'm pretty sure that will solve some of your issues. Do that, then post back. I have a feeling there's some grounding issues here too but one step at a time. |
#5 (permalink) |
Hey,
Many thanks for the help and advice. I do have the red and white taped together and soldered. The second pickup only has the hot wire and braid sleeve which is soldered to the volume pot. I've been back on this today and I following an article on the Seymour Duncan website, I have tried wiring the pickup that was not getting any output direct to the jack plug. This has shown that the pickup is in fact working, so back to square one. However, in bypassing the volume and tone pots, whilst the pickups works and I can get some sound through the amp, and control the volume via the amp, the volume at its highest is still way below normal. I can turn it full up and still get only a very moderate volume. This is a 25W amp and its normally very loud. I tried other guitars and it works great with them. As a start, how can I get full volume out of this. The pickup is pretty close to the strings, albeit, I only have the top two bass strings on a the moment for testing. Thanks again. Peter. |
#7 (permalink) |
There's a couple of possible things potentially wrong here.
First, double-check your wiring. Did you ground out the pots by soldering their ground lugs to the casing? Next, check ALL grounds. Start by checking the continuity between the bridge and the other side of the bridge ground wire inside the cavity. Next, check continuity to all pot casings, as well as the ground switch and the jack ground. If all of these read continuity, you are properly grounded. You may also have fried the pots while installing them. I have done this numerous times, and each time I will get either no sound at all or very little sound. Did you hold the soldering iron on the pot casing excessively long while wiring them in? Also, I'm not sure about this one, but I'm pretty confident you also have to ground the jack to the bridge ground wire when you wire the pickups directly to the jack. That would explain your low volume.
'07 Epi Les Paul -SD JB & '59/Gotoh bridge/Switchcraft toggle & jack/CTS pots/2 push-pulls for coil-split/Orange Drops/Reflectors/Schaller strap locks/Custom cavity covers/Removed gloss from neck, pup rings, poker chip, fretboard, TRC '04 DSL401 -Bad Monkey/DS-1/Monster Cables/casters |
#8 (permalink) |
Thanks for all the advice guys,
I spent the afternoon with new pots, new wire. Redid the whole thing from start to finish and still the same problem. What would prevent the full output getting to the amp. I can understand no sound but why some sound!! I'm about to pack up and go get someone knowledgeable to do this for me. Pity cos the whole project was to make a start getting into this. Peter. |
#9 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Apr 2008
Location: Kalifornische Demokratische Republik Core Club ®
Are the pots all grounded? Opps, sorry already brought up. Pictures would help.
"Fast is fine, but accuracy is everything." .... Wyatt Earp "I want you to be nice until it's time to not be nice." .... Dalton "Free the two." .... KP 01110011 01101000 01110101 01110100 00100000 01110100 01101000 01100101 00100000 01100110 01110101 01100011 01101011 00100000 01110101 01110000 ![]() ![]() |
#11 (permalink) |
Post some good pics.
Check that the pots haven't turned and are hitting the cavity walls or that a ground wire somewhere is touching something it shouldn't be. |
#14 (permalink) |
![]() 11 Gibson Buckethead LP Studio 00 Gibson Les Paul Standard 84 Gibson Explorer 98 Gibson SG Special (Duncan 59's, Jonesy'd) 10 Epi Prophecy Futura EX 08 Epiphone Elitist Custom (GFS Crunchy Rails) 12 Epi Trad Pro Goldtop 95 Korean Epi Standard 80 Tokai Reborn Old LS50 (Gotoh tuners) 08 Agile Dauntless (EMGs, wired Buckethead style) Schecter C1 Hellraiser A few others Amps -Marshall JCM 900 -Blackheart Little Giant Stack -Mesa Recto cab |
