Unread 03-14-2010, 09:40 PM   #1 (permalink)
Epiphone replacement parts
Does anybody know a good website to find quality parts for an Epiphone Les Paul Standard? I want to change my tuners because I hate how they look. Thank You
famana888 is offline   Reply With Quote
Unread 03-14-2010, 10:15 PM   #2 (permalink)
doodie's Avatar
Re: Epiphone replacement parts
STEWMAC.COM : Guitar, solid peghead tuners
Never argue with an idiot. They just drag you down to their level and beat you with experience.
Member Of The €piphone Empire
Edwards Jimmy Page ELP-112LTS/RE w/ Super Circuit
Epiphone Slash Les Paul Standard Plus Top
Epiphone Zakk Wylde Les Paul Custom
doodie is offline   Reply With Quote
Unread 03-14-2010, 10:22 PM   #3 (permalink)
Thank You Will all of those tuners fit in my Les Paul?
Unread 03-14-2010, 10:41 PM   #4 (permalink)
doodie's Avatar
you need to take out your tuner and measure the diameter of the hole but if it's kluson type(tunlip plastic tuning peg) it's usually 8mm and the grover is usually 10mm. just pick the tuner you like and check their spec on the page to see if they'll fit. btw, since you are changing out the stock epi tuners go for 16:1 or 18:1 gear ratio tuners, they'll stay in tune better. fyi, the stock epi grover is 14:1 and the stock kluson type is like 12:1
Unread 03-14-2010, 10:48 PM   #5 (permalink)
Thanks dude 1 last question, do you thibk this would fit? http://www.stewmac.com/shop/Tuners/G...=Specs#details I got the stock grover tuner.
Unread 03-15-2010, 12:10 AM   #6 (permalink)
doodie's Avatar
should fit but you'll need to drill new screw holes on the back of your headstock.
