Unread 02-16-2010, 07:09 PM   #1 (permalink)
RandolphT's Avatar
Exclamation Epiphone LP Std '07 Wiring
Well, after forgetting my username thinking it was the same as my e-mail, I've been searching this forum anonymously. You don't wanna read a fourteen year-old's words about forgetting their stuff.
Here is my point.
I've been wanting to switch my bridge pickup with a Seymour Duncan JB Sh-4, and been reading and watching videos of DIY. I am just not liking the muddiness of the original pups. So, after school today I removed the back cover revealing all my pots and what not.
Here is what it looked like:
It looks like a complete disaster to me, a whole wreck, a tangle of wires. After seeing that I won't even know where to start on changing the pups out. I just decided to ignore it for now and deal with it later, until i realized when I turn my volume/tone knobs on both tremble and rhythm the whole pot moves. That being the worst, no. I plugged the LP in and when I moved or turn the knobs. Scratching. They have never been cleaned but, I have never thought of that about 3 months ago.
The pots are original pots that came with her. They are 500k pots.
So here are my options.
1. Deal with it, pots cleaned, tightened, and the SD JB installed.
2. Find pots that will fit, have someone rewire it, JB installed.
3. Find pots that will fit, I rewire it using a diagram, JB Installed.
If I get the pots replaced and rewired should I get 500k push/pull? or just regular?
Guys, I don't wanna go this way on her forever. Help. Where can I get a fair priced yet worth the money pots that will fit my Epiphone? What should I diagram it to if I rewire it myself. I just the bridge pickups the most but I would still like to have the neck and both on the toggle switch. with the two bottom knobs being bridge pups and top being for the neck pups. Both Left being Volumes and the right being Tones/what ever.
My Guitars:
07' Epiphone Les Paul Standard (SD JB - Bridge)
Mexican Fender Duo Sonic 1997
http://www.youtube.com/watch?v=-7mZkt4bP5I
RandolphT is offline   Reply With Quote
Unread 02-17-2010, 05:44 PM   #2 (permalink)
sFLsniper's Avatar
Re: Epiphone LP Std '07 Wiring
Complete Les Paul Upgrade Electrical Component Kit
sFLsniper is offline   Reply With Quote
Unread 02-17-2010, 06:30 PM   #3 (permalink)
RandolphT's Avatar
I Learned most of this yesterday and I saw that yesterday, What is the capacitor? what do they do?
My Guitars:
Unread 02-17-2010, 06:45 PM   #4 (permalink)
snaredrum's Avatar
it restricts the amount of treble going from the pickups, basically. the lower value the capacitor, the more treble you'll hear. although expect someone to tell me i'm completely wrong pretty soon.
for a les paul, .022 capacitors are awesome. if you want to feel REALLY special, get Jonesy on here to hook you up with some PIO (paper in oil) caps that are .022 for the bridge and .015 for the neck. sweeeeeeeeeeeeet.
www.facebook.com/themadelinerust
snaredrum is offline   Reply With Quote
Unread 02-17-2010, 06:49 PM   #5 (permalink)
RandolphT's Avatar
Humm sounds interesting, I'm needing to pick up a book from my library about guitar electronics, hopefully it has something in there.
If I strip and desaughter the pups can I use the neck against. (Getting a JB)
My Guitars:
Unread 02-17-2010, 06:56 PM   #6 (permalink)
snaredrum's Avatar
the Epi neck pickup is surprisingly good when wired properly. i'd suggest doing the '50s wiring mod from here
Wiring Library
and a JB will be a great HOT bridge sound to contrast with the softer neck.
Unread 02-17-2010, 07:09 PM   #7 (permalink)
RandolphT's Avatar
What's JB stand for I've herd from Blues/Jazz to Jeff Beck
My Guitars:
Unread 02-17-2010, 11:44 PM   #8 (permalink)
sasquatch's Avatar
Jelly Butter
You get that buttery feelin' every time you hear it and you get all jelly and sticky in the hands
Epiphone LP Special wP-90's
Squier CV 60's Jazz Bass
Squier VM Jaguar Bass
Marshall HDFX 100/a cab
Acoustic B200 115
Sansamp DI/Boss TU-3
Digitech RP-355
sasquatch is offline   Reply With Quote
Unread 02-18-2010, 06:58 AM   #9 (permalink)
RandolphT's Avatar
Jelly's not that stick O.O Jezz...
My Guitars:
Tags
pups changing pots
