Go Back   My Les Paul Forums > The Les Paul > Epiphone Les Pauls
Old 04-04-2008, 09:08 PM   #1 (permalink)
ablezebra's Avatar
Unhappy Single fret buzz - fix or return?
Hey guys, I need to tap into your infinite wisdom:
So Ive been noticing lately that my Epi LP Standard has a pretty bad buzz on the 14th fret on a couple of the strings, and the odd other fret higher up. I'm getting icnreasingly annoyed with this, because I can hear/feel it even over my amp. I've ruled out the action being too low as the cause because it is already quite high, and even though the 14th buzzes, the 15th is perfect.
Let me add that the 14th clearly buzzes because it is making contact with the 15th fret. based on what I've read this is probably caused by the frets being a bit uneven in some fashion (Let me know if anyone thinks differently).
I checked the neck, and I'm not a guitar tech but I think it looks great, and it's pretty much dead straight with a tiny touch of relief.
I bought this particular guitar about 2 weeks ago, so hypothetically I could still return it - I believe it's a 30 day return period. But of course in those 2 weeks I've grown a bit attached to it.
So my questions to all of you are:
A) How much approximately would this cost to fix, at your average big-chain guitar shop
B)Would I be better off just returning it and finding something without this sort of problem? If I exchange it I'm going to consider saving up a bit to get a Gibson Studio or something.
Thanks!
ablezebra is offline   Reply With Quote
Old 04-04-2008, 10:18 PM   #2 (permalink)
ninny404's Avatar
Send a message via AIM to ninny404 Send a message via MSN to ninny404 Send a message via Yahoo to ninny404
Re: Single fret buzz - fix or return?
seems like a truss rod adjustment. i do my adjusting on my own guitars so i'm not sure on pricing... maybe $50?
i wouldn't return it for that because (mostly on floor models) it's usually a given on cheaper guitars. i just recommend having someone check it out, especially since you've grown attached.
My Videos
ninny404 is offline   Reply With Quote
Old 04-04-2008, 10:23 PM   #3 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
You need a fret dress and set up.
find a private luthier, do not go to a big chain.
Fret dress and set up can run you anywhere between 75 to 150 bucks.
Roman
Factories build guitars for profit, Luthiers build them for players
Roman Rist is offline   Reply With Quote
Old 04-04-2008, 10:26 PM   #4 (permalink)
ablezebra's Avatar
My concern though is that it occurs only on certain isolated frets.
Fret 14 on the A string is the worst, but frets 13 and 15 on the A string are perfect. Also fret 14 on the low E and and D strings are quite a bit better. Can this be solved with a truss rod adjustment?
I'm mainly basing my guess of an uneven fret on this site (Guitar Fret Buzz -Finding & Fixing Buzzes - What Causes Fret Buzz & How to Fix), but if the people here think a simple adjustment can fix it, then I'm game.
Old 04-04-2008, 10:29 PM   #5 (permalink)
diceman's Avatar
Obviously, go with RFR/Roman's advice - he's a real (true) pro.
But
You might just want to do the exchange if you don't want to pay the $75-150...
diceman is online now   Reply With Quote
Old 04-04-2008, 10:30 PM   #6 (permalink)
Roman Rist's Avatar
It occurs because you have high frets. Period.
A neck adjust takes care of fret buzz closer to the nut, but it will not help you in this case.
Maybe some of the offending frets need to be seated better, but you still need a fret dress.
Brand new guitars that are "high end" need this service often times as well so don't feel bad.
Old 04-04-2008, 10:34 PM   #7 (permalink)
ablezebra's Avatar
Roman
I hope I can find a local place around here, but it's slim pickings.
If it's going to get up to $150 then I'm going to have to seriously consider returning her... tough call, she plays nice otherwise...
Well, thanks Roman, good to know for sure what's going on. I've got another two weeks to think about it I suppose.
Old 04-04-2008, 10:37 PM   #8 (permalink)
Roman Rist's Avatar
There has to be someone near you (within an hour).
If you are in a smaller town, prices tend to be cheaper.
Old 04-04-2008, 10:43 PM   #9 (permalink)
ablezebra's Avatar
Well, I'm in a reasonable size city (pop ~ 100 000) so I guess there will be someone, I will look in to it. Of course, as a poor university student without a car, driving an hour isn't an option, in any direction.
I'll try and get a quote on having it fixed but I can't justify sinking another $150 into it within the return period.
Oh, how I wish I had tried to play that one particular fret when I was testing it out in the store!
Old 04-04-2008, 10:44 PM   #10 (permalink)
Roman Rist's Avatar
If you love the guitar, fix it, if you don't return it.
cheers,
Roman
Old 04-04-2008, 10:45 PM   #11 (permalink)
diceman's Avatar
The store should fix it for free! Just take it back there - tell them that they need to either fix it or exchange it - odds are they'll fix it right up at no cost, rather than take it back and sell it as a used item!!
Old 04-04-2008, 10:50 PM   #12 (permalink)
ninny404's Avatar
good point
My Videos
Old 04-04-2008, 10:55 PM   #13 (permalink)
inxs996's Avatar
Roman
I second that, DO NOT GO TO A CHAIN TYPE STORE, i.e. Guitar Center
-Epiphone Les Paul Custom, 07
-Epiphone Zakk Wylde Bullseye LP, 08
-Epiphone Zakk Wylde Buzzsaw LP, 05
-Epiphone Zakk Wylde Bullseye ZV, 08
-Epiphone Zakk Wylde Camo LP, 09
Amp:
-Marshall Zakk Wylde 2203ZW
-VOX - AD100VT-XL
Pedals:
-Boss TU-2
-MXR M108
-MXR ZW44
-Dunlop ZW45 Wah
-Dunlop JD-4S Rotovibe
-Dunlop DC Brick
Equipment Wishlist:
-Epiphone Graveyard Disciple
THE "OTHER" MLPF MEMBER WHO WILL NEVER BE BESTOWED V.I.P STATUS, HOW WILL I GO ON...
inxs996 is offline   Reply With Quote
Old 04-04-2008, 10:55 PM   #14 (permalink)
Scooter2112's Avatar
I had the same thing happen on a cheap ($150) used acoustic-electric that I bought in a small guitar shop. Sounded great in the store, until I got it home and put a tuner to it. Every string was tuned 1/2 step sharp (which told me that someone knew something was wrong). When I got it to standard tuning, everything above the 12th fret on the high E string was buzzing and toneless.
I tried adjusting the truss rod, but it didn't completely go away. So I got online and read some articles on dressing frets and did it myself, which wasn't that difficult and it worked out. If it were a Gibson, or even an Epi, I wouldn't have attempted it myself, but I learned something in the process.
Taking the strings off and putting a straight edge to it (allowing for any neck relief) might help you identify the problem fret that is seriously out of line. Crowning is a separate issue that I didn't bother to tackle.
-"Hey...every brain surgeon had a FIRST brain surgery"
"Have you hugged your Custom today?"
the CS Customs make the Standards sound like a plastic banjo with a live cat stapled to the back! - Hemply, 2009
Scooter2112 is offline   Reply With Quote
Old 04-04-2008, 11:00 PM   #15 (permalink)
ablezebra's Avatar
Getting the store to fix it free sounds like the best first thing to try, thanks.
If they refuse to fix it, I'll go from there - part of me really wants to keep this one, part of me wants a good excuse to buy a Gibson.
P.S. I got it at Long & McQuade (Canada)
Old 04-05-2008, 12:23 AM   #16 (permalink)
ablezebra's Avatar
Actually, if no one minds, one more follow-up question:
Do you think this type of problem could be a precursor to more problems down the road? For example, is this an indicator of poor quality in some areas that might result in frets popping up in the future or other construction issues?
Old 04-05-2008, 12:27 AM   #17 (permalink)
ninny404's Avatar
i doubt it, nothing i'd lose sleep about. that's just me though
My Videos
Old 04-05-2008, 12:34 AM   #18 (permalink)
Roman Rist's Avatar
Most factory guitars need work. To answer your question, maybe , maybe not.
Keep in mind they make them QUICK! as in fast!
Factory instruments overseas are made by small asian women for the most part, not musicians.
Most are built pretty well, but not set up well.
To give you an idea, when I do a setup, it takes about 2 hours to do it all.
Fret dressing, nut height, neck adjustment, etc.
I had a friend that worked at the gibson custom shop..........they got 3 minutes!
Most of the Epiphones I have seen at chain stores are horrible. But with a proper set up they could be great.
Hope that helps.
Old 04-05-2008, 12:37 AM   #19 (permalink)
diceman's Avatar
I figured that they didn't get a whole lot of time for setup - but I would have thought it'd be more than 3 minutes!
Old 04-05-2008, 12:42 AM   #20 (permalink)
ninny404's Avatar
i know, that's insane haha.
My Videos
Old 04-05-2008, 12:43 AM   #21 (permalink)
Roman Rist's Avatar
It may be different now, he worked there 10 years ago.
He told me they had an egg timer on each bench set for 3 minutes.
The point is, factories crank out product.
Old 04-05-2008, 12:44 AM   #22 (permalink)
overdriver's Avatar
Yeah they come with a thing called WARRANTY
overdriver is offline   Reply With Quote
Old 04-05-2008, 01:05 AM   #23 (permalink)
ablezebra's Avatar
Hope that helps.
Thanks everyone. After listening to what you all had to say, I've decided to keep the guitar and get it fixed up, unless the costs get ridiculous (hopefully it will be free). After staring at my guitar for a while, I decided it was beautiful and deserved a chance... I really clicked with it when I first picked it up in the store.
maybe I'm too sentimental
Old 04-05-2008, 01:09 AM   #24 (permalink)
Roman Rist's Avatar
Please find a good guy, most chain store "repairmen" are not good. If they were good they wouldn't be working for the store.
Old 04-05-2008, 01:12 AM   #25 (permalink)
terence_tez's Avatar
thats what i heard too.3 mins.dang,a quickie lasts longer...
they have firm bodies n exotic curves.they cry n scream bt we love them all the same--who need women anyway?
terence_tez is offline   Reply With Quote
Old 04-05-2008, 01:14 AM   #26 (permalink)
diceman's Avatar
Not when I'm in charge!!
Old 04-05-2008, 01:18 AM   #27 (permalink)
ablezebra's Avatar
Alright, alright, I'll pay to have it fixed by someone competent rather than trying to negotiate it for free from the chain I bought it at.
Thanks again for setting me straight.
Old 04-05-2008, 01:28 AM   #28 (permalink)
ninny404's Avatar
best of luck and hopefully it doesn't set you back too much
My Videos
Old 04-05-2008, 01:33 AM   #29 (permalink)
diceman's Avatar
Might be worth talking to the guys there and seeing if they do indeed have anyone competent squirrled away in the back (if they're willing to take care of your for free).
Old 04-05-2008, 02:23 AM   #30 (permalink)
kaptinkrunch's Avatar
I had a MIM Fender Strat that had the same problem, luckily I had a friend who was a guitar tech ( a decent one) and he "redid" my frets for me and from then out no worries w/the guitar. I have been lucky w/my epiphones I have really never had a problem w/them. I wouldn't worry about this being an idication of quality issues as no brand is immune from this type of problem.
This space for rent.
kaptinkrunch is offline   Reply With Quote
Introduction + Fret Buzz? pcorajr Epiphone Les Pauls 12 05-09-2008 11:37 AM
Fret buzz is killing me! Please help. Buzzin Gibson Les Pauls 8 01-28-2008 06:37 PM
HELP! Cant stop open fret buzz on my classic, tried it all... is it the nut? *pics* alligatorbling Gibson Les Pauls 11 01-20-2008 08:05 AM
Lots of fret buzz when lowering action Camazza Gibson Les Pauls 9 12-30-2007 08:54 AM
Fret Buzz LP increases marsb Epiphone Les Pauls 20 12-28-2007 03:04 AM
