#1 (permalink) |
EMG Pickups in a Epiphone Les Paul Special II
Hi. I'm wondering if anyone has tried to assemble EMG Pickups in a Epiphone Les Paul Special II? I'm going to buy a pair of the Zakk Wylde EMG Pickups in a few weeks and try it out. But is it even possible with a bit modding with the guitar case ++
And is it possible to use one volume and tone controll on both pickups instead of using 2 for each?
#2 (permalink) |
![]() Join Date: Nov 2007
Re: EMG Pickups in a Epiphone Les Paul Special II
I wouldn't waste your money on a Special II. For the almost $300 it would cost to get them and installed you could simply have a much nicer guitar.
You can visit me @ ![]() Hit me up with any and all gear questions. I'd be happy to help! You can reach me on here or at brett@eddiesguitars.com Rig!: 72' Fender Tele Deluxe RI/ 93' Epi LP Custom/Xotic Ep-Booster/Boss TU2.RV3.DD6/Orange Rocker 30/Orange 4x12 |
#4 (permalink) |
Thats what I did. I have the white Special II, and I bought a set of EMG H4's from a friend of mine, who is a guitarist and an electrician! Got the set for $65.00!! He wired 'em in for me, so don't know the schematics, but look at the wiring library thread in the Tonfreaks section of this site. It shows the schematic for master and tone controls like we have.
Here's how it turned out:
#5 (permalink) | |
![]() Join Date: Sep 2007
Electric Guitar Pickups & Accessories - EMG Pickups |
#6 (permalink) |
The Zakk set 'should' come with everything u need; I figure a Special II would be a good guitar to start with and mayb u can take em out' and put em in a standard/custom when/if u get one.
MVL.
www.weepingstrings.co.uk My music: www.myspace.com/weepingstrings My vids: www.youtube.com/victorlazarus Thank you.
#7 (permalink) | |
#8 (permalink) | |
#10 (permalink) |
'MLP Mid-West'
![]() Join Date: Jan 2008
One thing to consider is the knob spacing on the Special II. I recently installed a set of EMGs into an Ibanez (they were previously in my LP Custom), but the presoldered volume/tone pots were not far enough apart. I had to clip the cap, get another from Radio Shack for about $1.50, and re soldered it.
They work great now. Also plenty of room for the battery.BB
I use: WB Custom Pickups--6707 VTP/VTPH, 5707 Prototypes, Habaneros, Firewaters DeTemple 'Sweet Spot' Pickups (Strat) RS Guitarworks Electronics Jonesy's Caps |
#12 (permalink) |
It's definitely possible to do it, but I would really reccomend having them installed. If you buy the pick-ups from wherever your getting them for cheaper, then it probably won't be too bad on the price.
But, from what I understand installing active pick-ups into anything that didn't normally have them is going to be a pretty in-depth install that is gonna need routing, a good amount of soldering and wiring. Hope it all works out for you man! If you go thorugh with the pick-ups, next on your list needs to be a set of tuners! I know the ones on my Special II are down right HORRIBLE! Don't forget to post pics!
#13 (permalink) |
'MLP Mid-West'
EMGs are the same size as a standard PAF-type humbucker. I used the same p/u rings, as well.
The soldering isn't really that complicated, but there are a few extra wires in there because of the 9v battery. If you have any doubts, by all means get a reputable tech to do it. BB
#14 (permalink) |
![]() Join Date: Dec 2007
What am I missing here? The standard pots in the EPI should be 500K, could be 250K, the actives would need something more like a 25K pot. So a pot change would be needed for actives. Are you telling be B-squared that you wired active pickups to a 500K pot?
#15 (permalink) | |
#17 (permalink) | |
'MLP Mid-West'
I bought my EMGs in a LP kit. The Ibanez I installed them into had 1 tone, 1 volume, and they were spaced farther apart than the LP specs. The pots were 25K. BB
#18 (permalink) | |
Yes, I know my guitar had the option to get them stock. But, I wanted the amber sunburst! Plus, idk if I am going down the EMG route, I might get another JB for the bridge and call it a day.
#19 (permalink) |
'MLP Mid-West'
I gave my buddy a good deal; $100 for the set, installed.
![]() He's the guitar player in our church youth band. That guitar is totally B.A. now. (Bad Ass) ![]() BB PS--He's totally into Avenged Sevenfold, and that metally stuff.
#23 (permalink) | |
#24 (permalink) | |
#25 (permalink) |
Okay, now I have bought the EMG 81 & 85, but i got problems with the Volume and the Tone control. Is it possible to make the wires long enough without buying longer shaft pots? Because no local guitar store sells this, and I don't want to import anything.
#27 (permalink) |
Hey WildeStarr,
I was thinking about buying the Zakk Wylde Bullseye Epiphone LP, i know the pups that come in the Epi version isn't the same that come in the Gibson version, i intend on buying the ZW signature set, just was curious how big of a difference is the Epi version pups compared to the Gibson version pups... thanks Eric
-Epiphone Les Paul Custom, 07 -Epiphone Zakk Wylde Bullseye LP, 08 -Epiphone Zakk Wylde Buzzsaw LP, 05 -Epiphone Zakk Wylde Bullseye ZV, 08 -Epiphone Zakk Wylde Camo LP, 09 Amp: -Marshall Zakk Wylde 2203ZW -VOX - AD100VT-XL Pedals: -Boss TU-2 -MXR M108 -MXR ZW44 -Dunlop ZW45 Wah -Dunlop JD-4S Rotovibe -Dunlop DC Brick Equipment Wishlist: -Epiphone Graveyard Disciple THE "OTHER" MLPF MEMBER WHO WILL NEVER BE BESTOWED V.I.P STATUS, HOW WILL I GO ON... |
#28 (permalink) |
Now I have installed the pickups but the sound is kind of crappy, and the three-way switch doesn't work probably, when its on treble, only the 81 pickup is on very low sound, when in the middle both pickups are on, and the same on Rhytm, and very high sound. And when I adjust the Volume there is a fuzzy sound. Anyone knows what the problem could be? I used the wiring diagram that came with the Pickups.
#29 (permalink) | |
| Epiphone Les Paul Special II | dc81 | Epiphone Les Pauls | 30 | 08-21-2009 07:35 PM |
| New Pickups on an Epiphone Les Paul Custom? | Kipling241 | Epiphone Les Pauls | 4 | 03-01-2008 12:10 PM |
| Epiphone Les Paul Standard Plus or just upgrade pickups?? | JKSteger | Epiphone Les Pauls | 8 | 01-05-2008 02:49 PM |
| SEYMOUR DUNCAN PICKUPS - Epiphone Les Paul Special II | exile666 | Epiphone Les Pauls | 2 | 12-09-2007 10:33 AM |
| pickups for my epiphone les paul special II | tattoodane | Epiphone Les Pauls | 17 | 10-17-2007 12:55 PM |
