Unread 06-28-2009, 11:52 AM   #1 (permalink)
yllsacky's Avatar
Send a message via Skype™ to yllsacky
how do you measure pickup output? help fast!
how do you do with a mulimeter?
yllsacky is offline   Reply With Quote
Unread 06-28-2009, 12:28 PM   #2 (permalink)
ZoSo0789's Avatar
Re: how do you measure pickup output? help fast!
connect the hot to one lug and the ground to another on the ohms setting....
Seth - '07 Epiphone Les Paul (MIC, SD Pearly Gates bridge, Gotoh hardware)
Sadie - '04 Ibanez GAX30 (MII, SD JazzN, SD '59b)
Melissa - '08 Taylor 214 Grand Auditorium
Vox Valvetronix ADVT15
Ibanez Tubescreamer TS9DX
Vox 847A Wah (True Bypass, Inductor Mod)
No Mids??.......
Note to self: Line6 = Tone Herpes
ZoSo0789 is offline   Reply With Quote
Unread 06-28-2009, 12:31 PM   #3 (permalink)
yllsacky's Avatar
kj
Unread 06-28-2009, 09:59 PM   #4 (permalink)
No way to measure output unless you could somehow measure the minute currents generated by the strings over the pickup. With a multimeter you can measure the coil resistance - but this does not equate to output. For example if you put a weak (or no) magnet in the same pickup the multimeter reading will be the same but the voltage output less.. thus the guitar will drive the amp less and the sound softer. Thus the output is a function of the magnet strength and the DC resistance and topology of the coil and magnets.
Curt1lp is offline   Reply With Quote
