MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Unread 01-26-2008, 04:44 PM   #1 (permalink)
How to Dull down the High gloss Poly finish on an Epi
Has anyone successfully done this?
I have read that mild rubbing with very fine Wet and dry or pumice will do this , but it's a big step if you havn't seen it done.
I'd like to achieve the look of an aged nitro finish i.e a dull sheen.
Springer 6 is offline   Reply With Quote
Advertisement
Unread 01-26-2008, 07:14 PM   #2 (permalink)
sktn77a's Avatar
Re: How to Dull down the High gloss Poly finish on an Epi
SoftScrub. But try it on the back first to make sure it's what you really want!
sktn77a is offline   Reply With Quote
Unread 01-28-2008, 01:17 PM   #3 (permalink)
Question Re: How to Dull down the High gloss Poly finish on an Epi
I am also interested in aging the poly-paint on my Standard Plus.
Anyone else had any experience with this?
wats434 is offline   Reply With Quote
Unread 01-29-2008, 03:58 AM   #4 (permalink)
Big_dawg's Avatar
have you had much experience in paint spraying / sanding??
Ive been spraying (as a hobby) for over 20 years) and Im still sometimes mess up the between layer sandings (fortunately I can spray over it again)... You really can risk ruining the whole finish just by applying a bit too much pressure in the wrong place....
Practice on something you dont need, then try a tiny bit on part of the guitar you cant see....good luck....
t'sall Good
And Jesus said 'come forth and you shall receive eternal life'....
But I came fifth and only got the toaster
But damn I got another guitar....
Big_dawg is offline   Reply With Quote
Unread 01-29-2008, 05:22 AM   #5 (permalink)
mojofilter's Avatar
try steel wool or 2000 grit sand paper good luck
mojofilter is offline   Reply With Quote
Unread 01-29-2008, 10:56 AM   #6 (permalink)
hedzeppelin's Avatar
I'm interested in that too....and how do you fade it a little? Will the poly finish allow fading?
You have a nice guitar, but can you actually play it?
hedzeppelin is offline   Reply With Quote
Unread 01-29-2008, 11:11 AM   #7 (permalink)
hbucker's Avatar
Sunshine will fade anything. It's the tint in the stain that fades, not the poly finish. Set it in the sunshine on a regular basis and it will fade eventually.
hbucker is online now   Reply With Quote
Unread 01-29-2008, 11:45 AM   #8 (permalink)
Cool...I'll try that..
Now, the best way to dull the finish?
Unread 01-29-2008, 05:19 PM   #9 (permalink)
hbucker's Avatar
I won't hold you accountable hed but I thought you were against artificial aging...
http://www.mylespaul.com/forums/hist...91-ironic.html
Unread 01-29-2008, 06:17 PM   #10 (permalink)
Sunshine? In the UK ? C' mon .
Unread 01-29-2008, 06:20 PM   #11 (permalink)
No, I'm against paying extra money for pre-aged instruments.
Unread 01-30-2008, 09:57 AM   #12 (permalink)
hbucker's Avatar
So:
Preaged = good
extra money = bad
gotcha
Unread 01-30-2008, 10:44 AM   #13 (permalink)
So:
Preaged = good
extra money = bad
gotcha
Kind of...I just would prefer that the color on my Epi was a little less "vibrant".....I have no problem with someone aging their guitar themselves, just paying those exhorbitant costs for pre-aging is what scorches me.
