Unread 05-06-2009, 01:11 PM   #1 (permalink)
JohnnyKane's Avatar
A question about nuts
I bought a Black Tusq XL from Graphtech and got it yesterday. It's made for Epis, and even though I have not installed it yet, the size and string spacing seems to be dead on (although some sanding is necessary). My question is about the grooves... they seem to be a little bit big. I use .09 strings and I'm thinking that the grooves are too big for this string gauge. I haven't read anywhere what size strings this nuts are made for, but I'm guessing the XL is an indication that it may use thicker strings? Or am I completely mistaken here?
Then I saw this pic:
Check out the first string... the groove is bigger than the string. Is this normal? Shouldn't the string have a tighter fit on the groove? Or am I completely mistaken here?
JohnnyKane is offline   Reply With Quote
Unread 05-06-2009, 01:49 PM   #2 (permalink)
Epi Verification Expert
Sinmastah's Avatar
Re: A question about nuts
It's not the biggest deal ever, it might effect it a little bit. Even if you go up to a really high gauge, you won't be able to fill it anyways.
Epiphone Elitist SG Faded Cherry(Jonesey'd and WB'd)
Epiphone Elitist SG Faded Brown (EMG's)
Epiphone MIJ Les Paul Ebony LQ
Fender Mexi Oly White Strat
Squier Natural Vintage M Jazz bass
Peavey Classic 50
SG's FTW
Sinmastah is online now   Reply With Quote
Unread 05-06-2009, 02:05 PM   #3 (permalink)
JohnnyKane's Avatar
Thanks, Sin. As long as it sounds better than the stock nut and there's less or no buzzing, I'm cool with it.
Unread 05-06-2009, 03:57 PM   #4 (permalink)
TWANG's Avatar
The neat thing about graphite is the sting seems to have less problem with less than perfect slots.
Same with the Tusqs.
So if it aint broke don't fix it!
TWANG
TWANG is offline   Reply With Quote
Unread 05-06-2009, 08:32 PM   #5 (permalink)
It'll work fine. It happens on most pre slotted tusq nuts.
SABLE is offline   Reply With Quote
Unread 05-07-2009, 01:40 AM   #6 (permalink)
SGmanElitist's Avatar
All men should feel this free to ask questions when they aren't sure about their nuts
SGmanElitist is offline   Reply With Quote
Unread 05-07-2009, 01:52 AM   #7 (permalink)
coreydm676's Avatar
i had mine carved custom for 11-48s
2006 Epiphone Les Paul Standard Honey Burst (Seymour Duncans)
2011 Epiphone Les Paul Standard Ebony
1997 Epiphone Les Paul Custom Black Beauty
2004 Fender Deluxe Stratocaster Pearl White
2011 Squire Classic Vibe Custom Telecaster Sunburst
2012 Les Paul Junior Replica *WIP*
coreydm676 is offline   Reply With Quote
Unread 05-07-2009, 01:53 AM   #8 (permalink)
coreydm676's Avatar
haha you said nuts (I had to)
Unread 05-07-2009, 04:04 PM   #9 (permalink)
TWANG's Avatar
I just got two graph tech nuts in.. I haven't had time to look at them..
I will asap and tell you what I find.
TWANG
Unread 05-07-2009, 06:33 PM   #10 (permalink)
I don't know if i could have my nutz carved, epecially since they're made of brass.
But really, thats much better than some guitars that i have purchased with damned 11's that look like they were trying to squeeze in slots for 9's
