MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Heritage Guitar Talk - Click here! LIKE MyLesPaul on Facebook FOLLOW MyLesPaul on Twitter
Like Tree45Likes
Unread 03-03-2014, 03:51 PM   #1 (permalink)
Capacitors
I've been lurking this forum in the background when I was deciding what to do with my Epi Les Paul Std I picked up for real cheap at a garage sale. Was interested in pickup selection opinions when I found the endless debate on caps.
Congrats, you guys are putting all the "guitar capacitor" manufacturer's kids, and their grandchildren through college. Come on, $50 each for bumblebee or vintage PIO's? Besides the fact that Gibson's bumblebees are really cheap caps inside a vintage looking shell, there are other issues to address. Now, before I don my flame suit, let me explain from an electrical engineer's point of view.
All that matters in a capacitor is its actual capacitance value - not its construction, voltage rating, size, age, etc. Measuring this value directly is tricky because you need to know the charge it is carrying. This is not easily done outside of a lab environment. Even though caps come in values (.015, .047, ect), all that means is that the cap's actual value is within a certain percentage of its advertised value, which is called a tolerance. This is similar to resistors, which have a separate color band just to designate the different tolerance percentages. For example, a .020uF cap with a tolerance of 10% would pass quality control with values from .018-.022uF. Basically, 5 different .020uF caps can have 5 different actual values, which affects their tone very slightly. All you idiots who claim you can tell vintage from cheap radioshack caps are only hearing the subtle differences in actual capacitance.
Applying that concept to the real world: Caps are in guitar circuits to filter out undesired frequencies. So lets take 100 different caps, and measure the values of all of them in a lab environment. 4 out of the 100, even though they are made of different materials, have the exact same value. If you were to install each of them into the same guitar and hook up the output jack to an oscilloscope, the waveforms produced would be identical, because the frequencies being sent to the jack are identical.
Now, if having vintage caps makes you feel you guitar sounds better, which results in better playing, then ignore this whole post.
DrBGood likes this.
cschuster is offline   Reply With Quote
Unread 03-03-2014, 04:57 PM   #2 (permalink)
MLP Vendor
Unsung Heroes's Avatar
Re: Capacitors
Ah ha... snake oil or smoke and mirrors you say..? Somewhat similar to pickups there then...
Placebo has a lot to do with it. Sure, there may well be some subtle tonality change between components, but as you suggest, if changing them out makes people 'feel' that their guitar is now way better, which in turn means that they play more and even enjoy it more, then rock on
Clive
Supplier of quality, pre-owned Epiphone Les Pauls - better than new and saving YOU money!
Guitar sales - Set up, Component Upgrades & Refurbishment Service - Parts & Spares
Unsung Heroes is offline   Reply With Quote
Unread 03-03-2014, 05:04 PM   #3 (permalink)
Glegalee's Avatar
Re: Capacitors
Thank you for your incite. You seem to assume that the entire community of MLP are retards. I myself am an electronics engineer. You are right in your factual analysis of the capacitor and testing of them.
I have upgraded the electronics in one of my LP's and will be doing the same to the rest of my guitars. Ok ok I'll not be buying bumble bee's because I can not justify the cost but I will be using Orange drop's again and again. Yes I can get cheap Chinese caps that will do the job but we all know that they won't last as long as a more reputable brand. I built myself a Marshall 18W TMB clone amplifier (not from a kit, all parts individually sourced) and all my caps came from china. I did this to cut the initial cost of producing my one off amplifier, safely in the knowledge that the quality of said caps are sub standard and will be replaced in the future when finance dictates.
My point is this. If someone feels the need to rewire their guitar to 50's standard wiring, they may also have the desire to use capacitors that look similar to those used historically in the original guitars that the modern instruments are modeled on. And that said If someone wants to spend $50 on a bumble bee looking capacitor then that is their prerogative. Please don't come and judge people for their preferences regardless of whether they deviate from your logic as an electrical engineer.
Next topic for your thought, Can you tell the difference between the sound generated by a Valve amp and a Transistor amp? I can't but that's not to say that I am an expert in the sounds of amplifiers. Never the less I have both because that is what I choose to do.
Cheers G.
Edit: At the end of the day, blue smoke is blue smoke and once you let it out, you're Fudged regardless of the cost of the capacitor.
J_Edgar likes this.
Glegalee is offline   Reply With Quote
Unread 03-03-2014, 05:08 PM   #4 (permalink)
J_Edgar's Avatar
Re: Capacitors
Only an idiot would insult a significant proportion of the the members here by calling them idiots in their first forum post.
As for caps, for me the jury is still out.
Glegalee, Curmudgeon and Paulie C like this.
Danelectro DC59 12 String
Epi 1960 Ltd Ed LP Standard V3
Epi 1961 Ltd Ed Casino TD
Epi 1962 Ltd Ed Sorrento
Epi DR500MCE Masterbilt
Epi Special I P90 TV Yellow
Fender Baja Tele
Gibson Les Paul Junior Special P90
Guild D125CE
Ibanez EW 12 String Acoustic
Yamaha Pacifica SD PUPS
Yamaha APX4
Yamaha APX5
Yamaha GL-1
Tokai Love Rock ALS-48 2008
Tokai LS-Reborn 2014 VLD
Blackstar HT 5R Combo & HT 112 Cab
Fender PJ Mk II
Hayden Mini MoFo Head
J_Edgar is offline   Reply With Quote
Unread 03-03-2014, 05:35 PM   #5 (permalink)
Paulie C's Avatar
Re: Capacitors
What the hell kind of a first post is this? Welcome to MLP from one of the "Vintage Idiots"!
Epiphone LP Classic Trans Red Quilt
Crafter TE6
Roland Blues Cube
Roland Micro Cube
Paulie C is online now   Reply With Quote
Unread 03-03-2014, 05:41 PM   #6 (permalink)
MrKensei's Avatar
Re: Capacitors
Hi newbie, this thread belongs in the Tonefreaks forum. Plenty of cap butthurt in there.
This is the Epiphone Les Paul forum.
The above said: You're wrong in almost everything you said. If you cant hear it the. i pity you.
Skit likes this.
YMMV but that's my experience
Ibanez Jem7VWH
Jackson Pro RRTMG Silverburst w/BKP C-lbombs
Dean Razorback Explosion w/EMGs
2007 MIK Epiphone Zakk Wylde Custom Bullseye
2003 MIK Epiphone Les Paul Standard w/SD Pickups.
Marshall JVM410H
Carvin legacy 2x12 Combo
Rhythm guitarist for Templar. listen to us here
MrKensei is offline   Reply With Quote
Unread 03-03-2014, 05:47 PM   #7 (permalink)
mondomojo's Avatar
Re: Capacitors
OP has all of the tact of a Sherman tank.
Badges? Badges??!! We don't need no stinking badges!
Epiphone Ultra 3
Epiphone 1960 Tribute Plus
Epiphone Wildcat
Squier Deluxe Stratocaster
Squier Vintage Modified Jaguar
Douglas WNO 630
Gretsch Electromatic Junior Jet Bass
Hondo who-knows-what from the 80s
Dean Markely Spectra 60T
Peavey Bass amp
Just about very harp Hohner makes
Assorted Dean Markley & Huang Harps
Assorted bullet mikes & pedals
mondomojo is offline   Reply With Quote
Unread 03-03-2014, 05:54 PM   #8 (permalink)
Curmudgeon's Avatar
Re: Capacitors
Welcome to MLP. Here's your hat, what's your hurry?
Barcham, kevinpaul and Paulie C like this.
Brian
2014 Joe Bonamassa Pelham Blue
2008 MIC '56GT
2007 Elitist Standard Plus FCB
1976 Alembic Short Scale Bass
2002 Curbow 5-string Fretless Bass
1960's JG Single Cutaway Bass that I can't find any info on
1968 Giannini Nylon String Classical
19th Century German Bowlback Mandolin (great-great grandmother's)
Bugera V-22
BK Butler RealTube Preamp
A few cheap pedals
Curmudgeon is online now   Reply With Quote
Unread 03-03-2014, 05:57 PM   #9 (permalink)
Minstrel in the Gallery
Dun Ringill's Avatar
Re: Capacitors
2008 Gibson Les Paul Studio Fireburst
2013 Gibson Les Paul 60's Tribute Vintage Burst
2014 Gibson Les Paul Futura Plum Insane
1998 Epiphone Les Paul Studio Turquoise
2006 Epiphone Les Paul Standard Cherry Burst
2010 Epiphone Les Paul Custom Blackback
2013 Epiphone Les Paul Tribute Plus Black Cherry
1983 Kramer Pacer Imperial Translucent Red
1986 Kramer Focus 3000 Candy Apple Red
2011 Kramer Stagemaster SM-1 Black
2014 Taylor 320ce
Many assorted others..
Dun Ringill is online now   Reply With Quote
Unread 03-03-2014, 05:57 PM   #10 (permalink)
Re: Capacitors
I'm certainly not an EE, but my understanding is that caps are measured at a specific industry standard for voltage and frequency. Which tells me by "common sense" that just because 5 different types of caps measure within 10% of .022uF at 1k/1vrms, how they act at vastly different freqs/voltages are likely to be vastly different.
And my experience tells me that just because things match within a single given measurement, it hardly means they will sound the same. You can easily build a $50 CD player with the same freq response as a (for ex) $500 Oppo, but just because this measurement matches (say, 20-20k +/-0.2db), it absolutely does not mean the 2 units will sound the same.
entresz likes this.
houston is offline   Reply With Quote
Unread 03-03-2014, 06:01 PM   #11 (permalink)
GitFiddle's Avatar
Re: Capacitors
...All you idiots who claim you can tell vintage from cheap radioshack caps are only hearing the subtle differences in actual capacitance...
Welcome to MLP.
Bazinga. This should be fun.
Great way to greet the room.
Glegalee and Paulie C like this.
GitFiddle is offline   Reply With Quote
Unread 03-03-2014, 09:49 PM   #12 (permalink)
donlumber's Avatar
Re: Capacitors
Successfully learned how to use my ignore list today.
NYC LP player and Curmudgeon like this.
donlumber is offline   Reply With Quote
Unread 03-03-2014, 10:09 PM   #13 (permalink)
Witch Doctor
Skit's Avatar
Re: Capacitors
All that matters in a capacitor is its actual capacitance value - not its construction, voltage rating, size, age, etc...
What a douche.
I've posted it before I'm sure I'll post it again.
Guitar Tone: Pursuing the Ultimate Guitar Sound: Mitch Gallagher: 9781435456150: Amazon.com: Books Guitar Tone: Pursuing the Ultimate Guitar Sound: Mitch Gallagher: 9781435456150: Amazon.com: Books
Read and learn grasshopper. I will say if you can't hear the difference, then save your money and use the stock caps.
Do us all a favor and go back to lurking in the background.
The smoker you drink, the player you get.
-Joe Walsh
Bacchus Classic BLP-STD FM
Fender Japan Strat 40th Anni. ST54-150AS 1 of 40
Fender American Vintage '59 Strat
Fender Japan Tele TL52-SPL/DP
Epi Elitist Faded CB Plus
Epi Elitist '57 Goldtop
Epi MIJ LQ LP Special - Cherry
Epi MIJ LQ LP Special - TV Yellow
Epi Joe Perry Boneyard
Fender '60s Classic Strat
CV '50s Tele -Donocasters
1988 Kramer
1966 Fender BF Vibro Champ
EVIL ROBOT Combo
Little Lanilei 3350LT
Peavey Classic 20
Skit is offline   Reply With Quote
Unread 03-04-2014, 12:24 AM   #14 (permalink)
DavidRamey's Avatar
Re: Capacitors
My father had a name for engineers who thought they knew everything. "Educated Idiot"
dave, rabidhamster, Skit and 1 others like this.
DavidRamey is online now   Reply With Quote
Unread 03-04-2014, 12:47 AM   #15 (permalink)
chasenblues's Avatar
Re: Capacitors
HEY,
Mom say's to get off the internet,Its time for your enema.
rabidhamster and Skit like this.
chasenblues is online now   Reply With Quote
Unread 03-04-2014, 01:40 AM   #16 (permalink)
Bobbyk1978's Avatar
Re: Capacitors
You sir, are not just an internet troll, you are KING of the internet trolls
Epiphone Les Paul 1960's Tribute Plus
Epiphone '58 Korina Explorer re-issue
Washburn D10sce
Oscar Schmidt OG2CE
cheap as hell Line 6 Spider IV 15w practice amp
Bobbyk1978 is offline   Reply With Quote
Unread 03-04-2014, 02:08 AM   #17 (permalink)
rjw
rjw's Avatar
Re: Capacitors
this whole thread is too funny...
how to piss people off and NOT become part of a community
Maybe if we all play them unplugged then who'll care about caps
Glegalee likes this.
'55 Les Paul Special, Mahogany tele, Strat, 2 Yamaha basses, Yamaha M08 synth,Tama drums,Yamaha DTX 562 9 piece kit, Roland Cube 40, Fender frontman, Kustom defender 15,Mesa express plus 525 head w/ 1-12 cabinet (MC-90) and 4-12 closed back cab. 1970's JBL 4341 studio monitors, ur44,Cubase
rjw is offline   Reply With Quote
Unread 03-04-2014, 11:34 AM   #18 (permalink)
NYC LP player's Avatar
Re: Capacitors
OMG thank you for solving this one and for all!!!! You are a true hero. I only wish this had been discussed earlier as I have outlay $8 on caps.
I will pass this to Rebecca Dirks so she can include it in her next Tone Report.
In all seriousness welcome to the forum.
Skit and houston like this.
Shere Khan the CHIbson '13 Traditional with ECP RD-59 Hybrid Neck & ReWind JPPost72 Bridge
Tabby the Walnut Thinline w/ Lollar Regal Wide Range
The Mistress - Triple ECP P90 Strat
Phaez kt66/el34 SIBLY Combo
1964 Fender Super Reverb
Video Demos
The Family
NYC LP player is online now   Reply With Quote
Unread 03-04-2014, 11:55 AM   #19 (permalink)
MLP Anchorman
Led Zep Fan's Avatar
Re: Capacitors
Another capacitor expert... You should have stayed "lurking in the background"...
You must have a lot of capacitor experience with your garage sale Epi.
Lol.
Facebook "Likes" are appreciated!
https://www.facebook.com/hardbargainband
___________________________________
New website:
http://hardbargainband.com/
Led Zep Fan is online now   Reply With Quote
Unread 03-05-2014, 02:55 AM   #20 (permalink)
Teeceman's Avatar
Re: Capacitors
Not to pour too much scorn on the OP, but why didn't you take this conversation to one of the endless debates on CAP's that you talk about
'12 Epiphone Les Paul Tribute plus 1960 BC
'06 Epiphone Les Paul Elitist Standard+ Top FCB
'02 Epiphone Les Paul Elite Standard HB
'13 Blackstar HT Metal 5 Amp
Teeceman is offline   Reply With Quote
Unread 03-05-2014, 04:22 AM   #21 (permalink)
rabidhamster's Avatar
Re: Capacitors
Let me explain this from an electrical engineering point of view: You don't know what you're talking about.
NYC LP player likes this.
rabidhamster is offline   Reply With Quote
Unread 03-05-2014, 08:30 AM   #22 (permalink)
Poly sniffer ;)
JohnnyN's Avatar
Re: Capacitors
Nice trolling attempt - but I'm not buying
Led Zep Fan and martin6string like this.
Johnny
Epiphone 50th Anniversary 1959 Les Paul Standard.
Epiphone Les Paul Standard Trans Amber Ltd.
Squier Standard Telecaster.
J&D Stratocaster
Laney VC15 + Celestion G12H loaded 1x12.
Less is more
JohnnyN is offline   Reply With Quote
Unread 03-05-2014, 12:13 PM   #23 (permalink)
Witch Doctor
Skit's Avatar
Re: Capacitors
Someone check blings IP.
-Joe Walsh
1988 Kramer
EVIL ROBOT Combo
Peavey Classic 20
Unread 03-05-2014, 12:23 PM   #24 (permalink)
Re: Capacitors
Because his entire argument is explaining tolerance? (A case of "knowing just enough to be dangerous"?)
Unread 03-05-2014, 12:28 PM   #25 (permalink)
Bristol Posse's Avatar
Re: Capacitors
Originally Posted by chasenblues View Post
Yeah that was my first thought too
Although a really douchebag way of presenting the original post, I am waiting with baited breath to see if anyone can refute what he said with anything more tangible/substantive than "you suck" or "well I changed caps and I think I can hear a difference"
Bristol Posse is offline   Reply With Quote
Unread 03-05-2014, 12:48 PM   #26 (permalink)
Re: Capacitors
My post didn't count? (Which was to point out that a single, very specific specification is a very narrow aspect, and should not be made to represent "the whole story" of how something performs.)
Unread 03-05-2014, 12:57 PM   #27 (permalink)
Re: Capacitors
houston and Bingles like this.
Video Demos
The Family
Unread 03-05-2014, 12:58 PM   #28 (permalink)
kevinpaul's Avatar
Re: Capacitors
Now it is ruined for all of us real cap nuts. I was waiting 6 years to spring that on them! I even wrote a paper on it!
kevinpaul is online now   Reply With Quote
Unread 03-05-2014, 01:14 PM   #29 (permalink)
Re: Capacitors
Great vid.
Assuming the OP is serious, he would attribute the obvious differences in sound to differences in tolerance--that the values of any manufactured part are close to its spec, but vary within a few % in either direction. So, we would need some more precise measurements of the actual capacitance rather than the printed values. If what we hear correlates to the actual values, the OP might have a point. If it doesn't, then there's another factor (such as construction) that matters.
For example, the stock Epi sounds darkest and most muffled to me. If its actual capacitance is somewhat higher than the rest then tolerance could account for the darker sound.
To me the Mallory sounds brighter than the rest. If its actual capacitance is somewhat lower than the others, then it could account for the brighter sound.
I'm not saying the OP is right, just that we'd need more data to prove that he's wrong.
Bristol Posse likes this.
Bingles is offline   Reply With Quote
Unread 03-05-2014, 01:17 PM   #30 (permalink)
MLP Anchorman
Re: Capacitors
The OP was attempting to troll, that's it.
New website:
Copyright © 2006-2015, MyLesPaul.com. All Rights Reserved.
