Go Back   My Les Paul Forums > The Les Paul > Epiphone Les Pauls
Old 01-05-2009, 02:52 PM   #1 (permalink)
Burstbuckers in Epiphone Les Paul
Hi - I have recently had Gibson burstbuckers 1# and 2# fitted to my Epiphone goldtop to replace the standard pickups. However there is now a noticeable difference in the volume levels between the treble and rhythm pickups. On treble (bridge pickup) the voulme is a lot lower....is this right or could there be a problem?
The pots were also replaced with Gibson 500k parts.
Any advice would be great.
Thanks,
Dave
DaveLPGT is offline   Reply With Quote
Old 01-05-2009, 02:55 PM   #2 (permalink)
slowhand0461's Avatar
Re: Burstbuckers in Epiphone Les Paul
lower the bridge pup....do it while the guitar is plugged in so you can strum it and listen for the volumes to "even" out..
"Crank up the Drums...Crank up the Bass....Crank up My Les Paul in your Face"
MOJO'd
slowhand0461 is offline   Reply With Quote
Old 01-05-2009, 02:56 PM   #3 (permalink)
Oh yeah...Welcome to the forum!!
MOJO'd
Old 01-05-2009, 02:59 PM   #4 (permalink)
Epi Verification Expert
Sinmastah's Avatar
Or raise the neck pup. Either way it will do the same thing. If you like louder and closer like I do then you should raise, but if you like it lower (Good for keeping random noises quieter) Lower the bridge.
Epiphone Elitist SG Faded Cherry (Tone Mojo'd and WB'd)
Faded Cherry Epiphone SG G-400
Flamed Cherry SunBurst Epiphone Les Paul Plus Top
Epiphone EB-3 Ebony (Yes Long Scale)
Marshall MG250DFX
VOX AD30VT
http://www.youtube.com/profile_videos?user=sinmastah My Videos
http://www.youtube.com/user/SmithMi2007 Band Videos
SG's FTW
Sinmastah is offline   Reply With Quote
Old 01-05-2009, 03:04 PM   #5 (permalink)
Cool - thanks! I will try that out in a minute. Just wondering why it's been set-up like that in the beginning...has anyone done this sort of thing on purpose before? Just wondering if I was being an idiot and it was a well known configuration. The Neck pickup is low while the the bridge pickup is high.
Old 01-05-2009, 03:12 PM   #6 (permalink)
There's really not a set ..exact height for the pups...Jason Lollar has a great video on his web page explaining how to set heights...most folks just put 'em in and leave 'em...although thatsnot a good idea...
Adjusting Guitar Pickups
He uses a Strat...but the principle is the same
MOJO'd
Old 01-05-2009, 03:16 PM   #7 (permalink)
As for doing it on purpose.....I want mine balanced( I use both pups at the same time ,a lot),,that being said I am in the process of setting up a guitar for a friend and he want's his bridge pup more pronounced ( he never uses both @ the same time)..I guess anything is possible....
MOJO'd
Old 01-05-2009, 07:30 PM   #8 (permalink)
lifele55's Avatar
Send a message via MSN to lifele55
+1
Pups adjustment is always up to each individuals preference... One man's meat is another man's poison.
Ebony MIJ Epiphone Custom + Buncha Pedals.
Laney LC15R
www.youtube.com/psychotubes
sis ♥ lin
lifele55 is offline   Reply With Quote
Old 01-06-2009, 01:42 PM   #9 (permalink)
Looks like the neck pickup ring is too high...I got replacement rings which didn't seem to be an issue with the old pickups but the burstbuckers are far more sensitive.
Old 01-11-2009, 05:39 AM   #10 (permalink)
Hi everyone - well got a new neck pickup ring and managed to lower Burstbucker 1. The bridge Burstbucker 2 is as high as it can go without causing problems. The levels have become noticeably better there is still a difference in the volume levels between treble and rhyme. Is this just to be expected?
Old 01-11-2009, 07:45 AM   #11 (permalink)
Honestly...mine are pretty well balanced....I'll measure mine and either send or post the results and see what you think if you want to try it on yours...although it will possibly be late this afternoon..
MOJO'd
Old 01-11-2009, 05:14 PM   #12 (permalink)
LEFTY LES's Avatar
just had to do the same thing. my bridge volume was a lot lower than my neck.
"You thought you was the cool fool...never could do no wrong.
You had everything sewed up tight, how come you lay awake all night long?"
My stuff My Gear
Lefty's visit Southpaw City
LEFTY LES is offline   Reply With Quote
Old 01-18-2009, 06:24 AM   #13 (permalink)
Was that with Burstbuckers too. It's better but still not level. I'm controlling the levels with the volume controls instead now.
Old 02-08-2009, 06:36 AM   #14 (permalink)
Turns out it was an electronic problem rather than the height of the pickups. Had the pots re-wired and all is good. Guitar sounds excellent....would recommend Burstbuckers to anyone now
Tags
burstbucker, pots, rhythm, treble
1999 Les Paul Studio Vs. Epiphone L.Paul Custom Zakk Wylde Bullseye(new) DimebagFan Gibson Les Pauls 24 05-03-2009 06:57 AM
pickups off epiphone g -400 to Epiphone les paul FENDERL Epiphone Les Pauls 10 01-23-2009 11:19 AM
Les Paul Vintage Mahogany - when did they switch from 4xx's to Burstbuckers? patternrecognition Gibson Les Pauls 5 11-24-2008 04:25 PM
Epiphone Les Paul custom vs. Epiphone 1958 Explorer drkurv Epiphone Les Pauls 2 11-11-2008 03:51 PM
Gibson Les Paul Studio or Epiphone Les Paul Standard? Carroll1218 Epiphone Les Pauls 45 05-19-2008 02:50 PM
One of the largest message boards on the web !
