#1 (permalink) |
Inconsistency in Knob Resistance/Movement
I just got an epi studio and I noticed that the tone/volume knobs rotate with different amounts of resistance compared to each other...
is this normal, and is there any way I can fix it? |
#2 (permalink) |
Re: Inconsistency in Knob Resistance/Movement
It's normal: The stock pots are cheap and low-quality. You can change them to better ones, and while you're at it rewire the whole guitar, it's not a big deal. It's not unusual that people redo the electronics and re-make all grounding to a guitar upon aquiring. CTS pots are good, so are MIA Gibson; New Gibson pots are MIC, OK pots as is, but there are better ones out there.
#4 (permalink) |
they are not glued on, they just slip onto a splined shaft.
So for imports (Epi's etc.) you get course splined knobs, for Gibson or USA aftermarket pots you need knobs for fine splines. So yes they are replaceable, I do it to all my guitars.
--------------------------------------------------- Shane Just a guitar bum........... |
#5 (permalink) |
No, they aren't, just try to wiggle 'em off gently
Was an unlucky child...was abandoned at the doorstep...by my foster-parents... |
#7 (permalink) |
The knobs can be a little tight though, so if you can't get a good grip on them, (usual with bell knobs, speed knobs are easier to pull) slide something underneath the knob and lift GENTLY upward. You don't want to break the knobs.
#8 (permalink) |
![]() Join Date: Jul 2007
Some guys use a cloth which they wrap around the underside of the knob so that it lifts evenly. Others use a plastic grocery bag - loop the handles under the knobs (handles criscrossed) and lift.
#9 (permalink) |
I didn't have a problem getting mine off. But I cracked one straight through putting it back on. Haha.
There was a hairline crack when I got it anyhow, so I don't expect they're all that fragile. Just be careful.
Guitar: Honeyburst '89 Epi LP Std Plus Top Amp: This little Piggynose went Weeee Weee WEEEE! http://thinkinganddriving.com |
#10 (permalink) |
Check it out man. This is how I get them off. I use a t-shirt
![]() ![]() ![]() dont have to worry about scratching your finish, breaking your knobs or anything. They come right off with a little ummph!! ![]()
She promised and she vowed that she never would deceive me But the devil's in the women for they never can be easy |
#11 (permalink) |
Yeah, but is a left-handed t-shirt compatible with a right-handed guitar?
#12 (permalink) |
well of course not joe, you have to get the right t-shirts man. I didnt think I had to tell you guys that. Jeeze
#13 (permalink) |
perfect, thanks everyone... Today I was setting it up (intonation etc) and I made the mistake of lowering the pups too far to where the bolt came out of the threaded pup tray!! That took forever.. I pried the pup back up and then had to get the screw back in and threaded with that spring fighting me... I didn't want to restring it.. Hah
