Like Tree3Likes
  • 3 Post By Barcham
Unread 08-18-2012, 08:56 AM   #1 (permalink)
Davet59's Avatar
Changing strings
Pardon me if this has been asked before, but when you all change your strings do you change them one at a time or all at once. I have heard its best to do one at to keep the tens ion on the neck. But doing only one time seeems to be counter productiveto cleaning the fretboard
My Gear
Sigma Picador Acoustic ( Circa 1983)
Aria 12 String Acoustic (Circa 1984)
1990 Takamine FP-360SC
2010 Fender HSS Stratocaster
2011 Epiphone Les Paul Standard Plus top Pro
2012 Ibanez AF125 Amber Burst ArtCore
2012 Epiphone SG400 Pro Cherry Red
Davet59 is offline   Reply With Quote
Unread 08-18-2012, 08:57 AM   #2 (permalink)
56GT's Avatar
Re: Changing strings
all at once so I can clean the fretboard
56GT is offline   Reply With Quote
Unread 08-18-2012, 09:16 AM   #3 (permalink)
Mesamay2003's Avatar
If you need to change strings a lot, but not clean the fretboard, changing one at a time is recommended to avoid any neck shifts, parts falling off, etc...but if you need to clean the fretboard, they all come off...but one at a time!!
Mesamay2003 is offline   Reply With Quote
Unread 08-18-2012, 09:25 AM   #4 (permalink)
Barcham's Avatar
You're supposed to change them? I just buy a new guitar. But now that I think of it, it would be a lot cheaper that way!
Seriously though, as posted above - all at once if you want to clean the board and one at a time otherwise. And don't cut the old ones off. I know that it seems like a no brainer, but I have seen someone do that once. A string winder is also a good thing to have, only costs a couple of bucks and well worth it.
Joe Dirty, Davet59 and 56GT like this.
'04 MiJ Epi Elitist '57 Gold Top Les Paul
'04 MiJ Epi Elitist '61 SG Faded Cherry
'04 MiK Epi G-400 Vintage Faded Brown
'08 MiC Epi Les Paul Ebony Standard
'08 MiK Epi Les Paul Midnight Ebony Ultra II
Peavey Vypyr 30 + Sanpera II pedal
Roland Micro Cube
Crate CA30DG Taos Acoustic amp
The Guitar Dater web site does NOT help you determine if a guitar is real or fake. It ONLY decodes the serial number and it does not decode any sn newer than 2008.
Barcham is offline   Reply With Quote
Unread 08-19-2012, 04:06 AM   #5 (permalink)
56GT's Avatar
I wish I put locking tuners on all me guitars, as it makes string changes much faster and easier.
Unread 08-19-2012, 06:25 AM   #6 (permalink)
Bartlett Retrospec Member
Electroman67's Avatar
One at a time, when i clean the fretboard, i slide a cloth under the strings and put pressure on and around the strings, onto the cloth, to clean the fretboard. 1st fret is usually the only tricky one.
Electroman67 is offline   Reply With Quote
