Go Back   My Les Paul Forums > The Les Paul > Epiphone Les Pauls
Old 10-10-2008, 08:22 PM   #1 (permalink)
whats the ideal nut height for an electric guitar ?
I have difficulty playing on 1st fret and I think that my nut height is not set at optimium. How do I check if my nut height is OK without using any measurement tools. I only have a ruler and I dont think its accurate enough.
slash300 is online now   Reply With Quote
The Following 2 Users Say Thank You to slash300 For This Useful Post:
Old 10-10-2008, 10:18 PM   #2 (permalink)
MLP Trucker
dennistruckdriver's Avatar
Re: whats the ideal nut height for an electric guitar ?
The taller the nut, the better!
Life without music would be
TOO DANG QUIET!!!
-Dennis The Truck Driver, 2008
dennistruckdriver is online now   Reply With Quote
Old 10-11-2008, 12:30 AM   #3 (permalink)
lp_junkie's Avatar
it absolutely depends upon the guitar itself, there are factory specs with tolerances, but string gauge, playing style and a lot of things will have impact on what is optimum for your guitar.
LP_Junkie now on MySpace
Les Pauls and Marshalls- Hammer of the Gods.
EPI/MIJ Modders (Orville-Tokai-Burny-Greco-etc.)
lp_junkie is offline   Reply With Quote
Old 10-11-2008, 07:39 PM   #4 (permalink)
Any reason for that ? Wouldnt that make playing a bit harder near the 1st fret ?
Old 10-11-2008, 07:45 PM   #5 (permalink)
River's Avatar
I daresay he's kidding. If the nut is substantially too high, it will make your fingers bleed bending at the lower frets. Been there, done that, have the T-shirt (and scars).
Some pictures would help, though they'd have to be quite hi-res.
Nothing beats a really good setup, if you can get one locally.
Light a candle for all children who have died. Dec. 14, 2008, 7-8PM around the globe.
Old 10-11-2008, 09:29 PM   #6 (permalink)
kspeed's Avatar
Are you hearing buzz when you hold down the first fret? Does it happen when you play acoustically or amplified or both? Or is it just really hard to push down on the first fret? If it's the latter, the nut's probably too high, but if you could snap us some pictures that would help a lot.
It's impossible to say what the ideal height is for any given electric guitar. It all depends on neck angle (is the neck perfectly parallel with the back of the body or is it angled?), the type of bridge, how high that bridge is set, even the gauge of string.
For most people the "best" action is as low as it can get with slight buzz played acoustically, but not enough to be amplified. Others, such as Stevie Ray Vaughan, preferred relatively high action/neck relief to improve sustain and output.
C/N: It all depends the guitar and your playing style. For most people it's "the lower the better" but that doesn't come close to covering everybody.
kspeed is offline   Reply With Quote
Epiphone G-400 SG Electric Guitar blueburst Other Gibsons 31 05-14-2008 03:09 PM
guitar strap height schmidty123 Epiphone Les Pauls 37 05-07-2008 09:25 PM
Help me to learn electric guitar fedrick My Other Guitars 7 05-06-2008 07:53 PM
The Secrets of Electric Guitar Pickups FLICKOFLASH Pickups 4 12-08-2007 11:28 PM
FS: Line 6 Variax 500 Electric Guitar teejayh Member Classifieds 1 10-18-2007 04:57 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
