#1 (permalink) |
A friend of mine owns a 2004 U-Serial Epiphone Les Paul Standard. I noticed that the intonation was everything but correct so I decided to set it up. That's the way I tryed:
At first I tuned the open string. Then I pressed the same string on 12th fret and the tuner showed that this note was too low. So I took a screwdriver and screwed the saddle more in the bridgepickup direction! - Is that the right way? Did I do something wrong? ![]() I screwed the saddle all the way into this direction until I can't make any more turns, but the intonation wasn't any better!? I also noticed, that the harmonics on the first, second and third string are not over the 12th, but between the 12th and the 13th fretwire! What's going on here? How to fix these intonation problems? It's not a pleasure to play this guitar! My buddys strings are 0.9 Gibson Les Pauls - are there to thin or what? Will a professional setup help? Pease help me!
Sorry for my bad english! ![]() 1992 Orville Les Paul Standard Plaintop HCS |
#2 (permalink) |
Re: Epi intonation problem!
Gibson Les Paul: Electric Guitar Setup | Expert Village Videos
This shows Gibson Setup, but should be the same. |
#4 (permalink) |
Hey Knarbens,
first thing: Yepp - for a normal setup, you did everything right. There certainly are finer methods to do this, but I wouldn't mind those for now. Now, if that particular guitar is so far off in intonation that you cannot handle it by moving the saddles of the bridge, you might try a different string gauge like for example 10/46 and then try to setup the intonation again. I have never seen a Les Paul style guitar THAT way off, but one hardware thing you could do is to get a new bridge from GOTOH or TONEPROS (more expensive but the same as the Gotoh, only that it can be locked with screws...). These bridges have a broader range for moving the saddles. Works perfect on my Les Pauls. It may be worth having a luthier or an experienced tech have a look at the guitar. Maybe there is even something wrong with the nut or the studs the bridge rests on have moved or are otherwise damaged... Hope this helps. Cheers Axel BTW: Cool Orville Paula you got there. How do you like it ? ...do these have the long-neck-tenons ?
Axilla -------------------- MUSICMANiac & Paula-Lover Epi Paula Slash Sig. Plus Top Epi Paula Slash Sig. Gold Top Epi Paula Boneyard Joe Perry Sig. ...and heaps of EBMMs ;-) ...in-tune by Peterson Strobes and running thru Diezel/Marshall/Hiwatt/Peavey and TC FX http://s206.photobucket.com/albums/bb188/AxelBartig/ |
#5 (permalink) |
Knarbens, just quick thought, was the bridge put on the wrong way round when the guitar was last restrung? Could explain why it is so far out.
Rick.
Meh... :shrugs: |
#6 (permalink) | |
Thank you Axilla! I like my Orville! She plays great, even without a long neck tenon! I believe the G-Serial Orville by Gibsons, built in the same period than my Orville, do sometimes have a long neck tenon.
#7 (permalink) | |
Thanks for the info - I'm currently thinking about Orvilles, but first I've got to to see and try some in the flesh before buying...
#8 (permalink) | |
![]() FYI, both my Epis have the saddle adjustment screws facing inwards towards the bridge pickup, that's how they came from the factory. Rick.
Meh... :shrugs: |
#9 (permalink) |
Hey Axilla! Great to see another German member here at the forum! I'm from Chemnitz! Welcome to the forum!
(Ich schreibe mal in Englisch, damit die lieben Amerikaner auch wissen was ich hier schreibe! )
#10 (permalink) |
...indeed, I see not many German participants here in the Epi section ;-)
We gotta grow our community
#11 (permalink) |
Willkommen zu den Foren Axilla,(Knarbens Ihr Englisch ist besser als mein Deutscher).
LP_Junkie now on MySpace _____________________________________________ Les Pauls and Marshalls- Hammer of the Gods. EPI/MIJ Modders (Orville-Tokai-Burny-Greco-etc.) |
#12 (permalink) |
(lp_junkie, das glaube ich auch!
) No, I'm just kidding you!
#13 (permalink) |
Mein Gott Walter, das werd langsam einen Deutsche Forum hier. Just yanking some chains….. lol
KP Les Paul Standard Plus Top Heritage Cherry Sunburst Squier Standard Strat (highly modded) Vox AD30VT Fender Champion 600 Digitech RP350 The Official Retiree on MyLesPaul.com MLP Thread Pirates Chief Flogger ![]() ![]() |
#14 (permalink) |
I had to flip one of my saddles around to get intonation right on the G string. Because the saddle goes to a point you may be able to flip it around and gain an extra 1/8 in. of movement, if it's not already facing that way.
#15 (permalink) | |
It costs about $25 and has longer saddle travel. I added one to my SG Custom and wow, it finally intonated correctly.
Epiphone Les Paul Plus Epiphone SG Custom Fender HSS Std. Stratocaster Gretsch Electromatic Pro Jet Marshall HDFX 100/a Digitech RP-250 |
#16 (permalink) | |
#17 (permalink) | |
![]() Join Date: Jul 2007
![]() ![]() 1969 Gibson Deluxe / 08 Gibson R8 / Epi Elitists: Standard & Custom / Epi Custom & Studio Goth - '65 Fender Jaguar My Band: www.comeupswingingmusic.com or www.myspace.com/comeupswinging |
#18 (permalink) |
There are even a few still available new from MF, etc.
08 Epiphone Les Paul Ultra-II Tiger's Eye Faded Cherry 07 Epiphone Maraschino Cherry Burst LP 02 Black and White Mexican Fender Standard Stratocaster with SD Hot Rails |
#20 (permalink) |
#21 (permalink) | |
Whats the deal I thought no one else was getting them? If this is true I might have to get it now. They are discontinued though, right?I don't think I can blow 1,200 bucks right now but I can sure make payments. ![]() P.S. Sorry for the hijack
#22 (permalink) | |
They come in on 11/05Thanks a lot for the link.
#23 (permalink) |
Happy to help, although I envy you! I'm tempted to snap one up, but I already have more guitars than time to play 'em!
| Intonation help for my lp | bobby mckenna | Tonefreaks | 1 | 09-26-2008 12:23 PM |
| LesPaul Intonation help!! | edr56 | Tonefreaks | 12 | 09-18-2008 01:29 PM |
| intonation problem | schmidty123 | Epiphone Les Pauls | 30 | 08-30-2008 03:05 PM |
| epi intonation | hunt1622 | Epiphone Les Pauls | 27 | 08-23-2008 04:32 PM |
| Intonation 101....Duhhhhhh for me | Blues Power | Gibson Les Pauls | 5 | 12-28-2007 05:42 PM |
