Like Tree1Likes
  • 1 Post By Phildog
Unread 04-28-2012, 08:18 PM   #1 (permalink)
Gfs pups
I put a set of gfs boutique fat pats in my les paul MIK and it kind of sounds like a duck now like old 70's funk bass.
I backed them off to see if it would fade but it didn't I am using .047 caps modern wiring.
Any ideas?
Or are they just what they are? Ducks
Thanks
John
littlejon is offline   Reply With Quote
Unread 04-28-2012, 09:30 PM   #2 (permalink)
Epi Verification Expert
GNR4EVR's Avatar
Send a message via AIM to GNR4EVR Send a message via Yahoo to GNR4EVR
Re: Gfs pups
I have a set in my wifes Laguna and they sound great to me. Might be in your wiring or cap choice.
2005 Epiphone Elitist Standard Plus Honeyburst MOJO-ED!
Dean Hardtail Red Tiger
Fender squire Bass
Morell jumbo accoustic
Marshall Micro Stack
GNR4EVR is offline   Reply With Quote
Unread 04-29-2012, 12:01 AM   #3 (permalink)
Phildog's Avatar
Re: Gfs pups
I'd suggest changing the caps to .022 PIO (paper-in-oil). With that change, you'll be getting a better tonal range from your pickups. Heck, you can even try a .015 in the neck position. I'd also change the pots to CTS for better signal flow and reliable service. Also, consider changing the wiring scheme to 50's style for much more usable tone control throughout the entire knob travel. Those pups should sound really good! IMO
SJM likes this.
2006 Epiphone Les Paul Standard
2005 Epiphone Les Paul Classic
2008 Epiphone G400 1966 Reissue
Eric Johnson Sunburst Strat
Jimi Hendrix Monterey Pop Strat
Fender Telecaster 50's Reissue
Univox Hi Flier Phase II
Premier 4 String Bass
SKB Stage 5 LOADED!!!
Fender Hot Rod Deluxe
Phildog is offline   Reply With Quote
Unread 04-29-2012, 07:47 AM   #4 (permalink)
Bartlett Retrospec Member
Ole'Lefty's Avatar
Re: Gfs pups
Historically, they are bargains- I've used the crunchy PAF's and Mean 90's.
Ole'Lefty is offline   Reply With Quote
Unread 04-29-2012, 08:14 AM   #5 (permalink)
SJM
Weekend Minstrel Emeritus
SJM's Avatar
Re: Gfs pups
I'm thinking it's something to do with the wiring schematic and caps also. I have a set of GFS professional series Alnico II's in one of my Gits and they sound exceptionally good. Way better than I expected given the price.
______________________________
Steve-M
'52 Martin D-28
'70 Fender Telecaster
'78 Ibanez Pro MDL 2671/S-AV
'02 Epiphone LP Elite Standard VSB
'07 Epiphone LP Elitist Standard + Top FCB
'10 Epiphone LP Trad Pro Ebony
'10 Epiphone LP 57 Gold Top(Upgraded version)
'10 Epiphone LP Standard Plain Top HB
'12 Epiphone LP Tribute Plus 60's FCB
'12 Epiphone LP Ace Budokan
'11 Gibson LP JB Studio
'12 Gibson Traditional LP Plus Iced Tea
A few Amps too.
SJM is offline   Reply With Quote
Unread 04-29-2012, 09:47 AM   #6 (permalink)
Metalrulez's Avatar
Re: Gfs pups
Maybe the coils are wired out of phase?
Metalrulez is offline   Reply With Quote
Unread 04-29-2012, 09:52 AM   #7 (permalink)
Danno1985's Avatar
Re: Gfs pups
Any ideas?
Thanks
John
It "sounds like a duck"??? "Like old 70's funk bass"?? What does that even mean? You're going to have to be more descriptive if you want help figuring out why your pickups don't sound right.
But yeah, I have GFS pickups and they sound pretty great to me.
'95 Epi LP Standard.
'89 Am. Standard Strat with '62RI neck, Duncan Antiquities.
'92 Tele
'99 "70s" Strat.
Danno1985 is offline   Reply With Quote
Unread 04-29-2012, 04:36 PM   #8 (permalink)
Pauli's Avatar
Re: Gfs pups
He quackers.
1994 Epiphone Les Paul Standard Cherryburst
with GFS Vintage '59 Classic Nickel V humbuckers
Fender Strat in Black
Line 6 Spider II 120w amp
Line 6 DL4
Line 6 AM4
Digitech GNX3
Zoom G2
Pauli is offline   Reply With Quote
Unread 04-29-2012, 05:37 PM   #9 (permalink)
Re: Gfs pups
Double check to be sure you didn't connect the wrong 2 leads together from the pickups. My guess is that instead of wiring the two "end" leads for the coils together you wired an "end" to a "start" (or maybe it's the other way around...not THAT familiar with the terms in pickup design) and ended up with the two coils cancelling each other out. Check the sheet that should have come with the pickups to be sure.
2008 Epiphone Les Paul Custom (Silverburst)
2009 Gibson Les Paul Studio (Raw Power - maple)
2010 Epiphone Les Paul Custom (Alpine White)
2010 Epiphone Les Paul Standard (Ebony)
2011 Epiphone Les Paul Studio (Silverburst)
2012 Epiphone Les Paul Traditional Pro (Gold Top)
2013 Epiphone Les Paul Tribute Plus (Faded Cherry Burst)
2010 Ibanez Artcore AF75TDG
Ariana STG-3
Ibanez Artcore AM73T
Alvarez Dana Scoop
Preacher403 is offline   Reply With Quote
Unread 04-29-2012, 05:56 PM   #10 (permalink)
Re: Gfs pups
Problem was a poor ground to the tone pot.
Now they sound good but still think they are a bit dark.
I am going to swap out the caps for 022 or 015.
Thanks for all the help
And go listen to an old funk album with a nice bass grove it has a quacking type of sound, that was the sound!
I guess it would have been alright if it was 1972 I could have joined the group Parliament!
