#1 (permalink) |
![]() Join Date: Jan 2012
What EMG pots for Epiphone LP Custom?
Hello all.I am working on a trade with my Yamaha Pacifica for an Epiphone LP Custom SB.The Epiphone has Seymour Dunkan jazz which he will keep them (they didnt fit my style anyways) so i am looking for EMG most likely the JH set.The question is do i need the long shaft pots or the regular for the Epiphone?Thank you.
#2 (permalink) | |
Re: What EMG pots for Epiphone LP Custom?
I don't know about the shaft length but you will need 25K pots for active EMG's and not the standard 500K used with passive pickups.
#3 (permalink) |
I know that.The pots are included in the set as long with all the electronics.There are 2 types of EMG pots though the regular and the long shaft.As i know Gibson LPs requires the long shaft version of the pots but i dont know about the Epiphones
#4 (permalink) |
you need the short shaft pots. the long shaft pots are for Gibson LP guitars which have a thicker cap than Epiphones
modded Squier strat MIC Epiphone LP Standard Plus (SD Jazz/'59, graphtech bridge, graphtech tusq nut) MIK Epiphone LP custom(emg 81/60, gotoh bridge, graphtech tusq nut) Fender bk-4 accoustic Marshall JVM410H Marshall AFD100 Marshall JCM slash signature cabinet |
#8 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Dec 2010
The last time I installed EMG's in an Epi I'm almost certain I used the short shaft pots.
Aren't the long shaft pots just for Gibsons with the "Norlinesque" steel plate?
Gibsons: 1979 GK-55 1984 Flying V 2011 LP Traditional Faded 2011 LP 60's Tribute Others: Danelectro Hodad (Bigsby) Burny "Rock'n Roll Version" DC JR Kraken Legion 7 Epiphone DC LP Special Jackson RR Pro Larrivee L-09 Rig: Soldano Hot Rod 50 s/n 1911 Saxon 2x12/UK G12M 60's Garnet 2x15 Fairfield Barbershop OD ![]() ![]() Six Slugs, Six Points of View... |
#9 (permalink) |
Most Epi's can use short shaft pots, some of the newer ones like my Standard 1959 are a little thicker and long shaft pots are needed. Fact is long shaft pots work in them all. Long shaft pots also allow you to use the inner nut to set the depth so you get just the right clearance for the knobs, also makes the use of indicator washers that much easier.
Epi Joe Bonamassa Signature Goldtop Epi Les Paul Standard 1959 Faded Iced Tea 2009 Epi Les Paul Standard Plus Top Heritage Cherry Sunburst 2008 Epi Les Paul Custom Plus Vintage Sunburst 2009 Fender MIM Strat Brown Sunburst Rosewood Neck Traynor Darkhorse 15H/Darkhorse 112 Cab Vox VT30 Fulltone Clyde Deluxe Wah Fulltone Robin Trower Overdrive MXR EVH Phase 90 t.c. electronics ND-1 Nova Delay t.c. electronics Polytune |
#10 (permalink) |
I currently have EMG's in my Epi LP and had them previously in my Epi SG (G400) and I have never used long shaft pots. Unless you buy the Zakk set or other type 'set' you will get both long and short, but if you buy the pickups individually you usually only get a short shaft pot (maybe it's changed but that's the way I bought mine years ago.)
The short shafts work just fine with Epi LP's.
#11 (permalink) |
Thanks Jrnic.I am after the James Hetfield set i dont believe they include both long shaft and regular.Nice guitar btw.
#12 (permalink) | |
If you end up needing long shafts, check eBay as a lot of guys buy the ZW set and don't end up using them.
#14 (permalink) |
Hey mate,
I just installed the JH Set in my epi les paul custom. The short shaft pots that came in the set fit just fine.. Buy the set mate, they sound great..! |
#15 (permalink) |
Hey just to close this thread i actually installed the 81/60 and the regular pots barely fits especially the neck tone and vol which i had to remove the interior nut.So the regular do fits but the long shaft is preferable.Thanks for the help everyone
Guitars Gibson Explorer 68 Gibson LP Studio AW Amps Peavey 6505+ Combo |
#16 (permalink) | |
This space for rent!
Pics? |
#17 (permalink) |
You can see here the neck pots especially the tone on the right that i could barely screw the nut.Pics also here NGD Epiphone LP Custom Silverburst.
