#1 (permalink) |
![]() Join Date: Jan 2009
Pickup selector giving me grief- any advice?
The pickup selector on my Les Paul has started goofing. The rhythm selection works perfectly, but if I put it in the middle or on treble, it doesn't do anything at all. I popped it open and looked for loose soldering, but it seems pretty solid. Any take on what this could be?
#2 (permalink) |
Re: Pickup selector giving me grief- any advice?
Wire pinched somewhere?
Take it out and have a good look at it.If it works then put it back in and don't pinch the wires. Just because it looks OK doesn't mean it is. |
#5 (permalink) |
![]() If it ain't broke, Mod it till it is ![]() Leonidas no is puteus in primoris rudimentum |
#6 (permalink) |
^ Ha! That's effectively what I have.
Thanks Pinkie and Thump! I'll take another look. For good measure, I'll post a video too. See if you all catch anything I don't. Edit: what's this about a contact leaf? |
#7 (permalink) |
I have the same problems on most of my Epiphones. So now I usually replace the switch to a Switch Craft right off the bat and I don't have the problem anymore.
#8 (permalink) |
Yeah I've had it for 3 years. Just popping up now. I'm kinda short on cash at the moment, but I'd normally rather just replace the switch and be safe.
#10 (permalink) | |
2012 Gibson Les Paul Traditional Mahogany Satin Vintage Sunburst 1994 Gibson Les Paul Studio Wine Red with Ebony Fretboard 2007 Epiphone Les Paul Custom with JP wiring and Gibson BBIII and Gibson 57 classic Pups. 2010 PreVal Strat Pro Stratocaster. 1987 BC Rich NJ-STIII series. Marshall 6101 30th Anniversary Blue tolex .Marshall MG15MSII. Electro Harmonix Screaming Bird Treble Booster. Electro Harmonix Lpb-1 Power Booster Preamp. Korg Pitchblack Black Chrome. Dunlop CryBaby. |
#11 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Aug 2007
do switchcraft switches fit into the epi's with no drilling or do you have to widen the hole..
#12 (permalink) |
![]() Join Date: Apr 2008
Location: Kalifornische Demokratische Republik Core Club ®
"Fast is fine, but accuracy is everything." .... Wyatt Earp "I want you to be nice until it's time to not be nice." .... Dalton "Free the two." .... KP 01110011 01101000 01110101 01110100 00100000 01110100 01101000 01100101 00100000 01100110 01110101 01100011 01101011 00100000 01110101 01110000 ![]() ![]() |
#13 (permalink) | |
#14 (permalink) |
My toggle switch on my epip lp standard started acting up only 6 months after purchase, apparently there known for it, i fixed it but have a switchcraft ordered as ive had to fix it again since, i just took the switch out without disconnecting any wires, got a flat head screwdriver and prised the switches contacts closer together to increase the pressure the contacts make against each other when the switch is engaged as thats what was causing the problem, i also gave the screws another twist as far as they would go, its hard to explain this procedure properly in words, a video would be much more usefull to you if i had one but i dont, order a new better quality switch as it will only be a reoccurring problem
#16 (permalink) |
Yep ,exactly what I was thinking. Mine started doing the same thing a while back. The rhythm and middle positions were fine but the neck would cut out. All I did was blow into really hard a few times and I haven't had trouble since.
