MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Like Tree14Likes
  • 1 Post By SJM
  • 6 Post By BoatGuy1970
  • 4 Post By SJM
  • 1 Post By blues_n_cues
  • 1 Post By SJM
Unread 11-29-2011, 07:33 PM   #1 (permalink)
POT sizes
yo.. i'm buyin pots for my new guitar online.
it's an epiphone les paul standard plus top. so the question is...
what size pots do i need? the long shaft ones or the short?
can those cts pots fit? no drilling?
just want to confirm the size of pots i need b4 buyin them.
Axesrus - Guitar Potentiometers, Tone, Volume Knobs, Pots and more
mwee is offline   Reply With Quote
Advertisement
Unread 11-29-2011, 08:49 PM   #2 (permalink)
Thread Killer
Hairless_Ape's Avatar
Re: POT sizes
Long shaft pots are what you'll need. You don't have to "drill"...a hand-held reamer will do the trick, yo.
Hairless_Ape is offline   Reply With Quote
Unread 11-29-2011, 08:59 PM   #3 (permalink)
AnthemBassMan's Avatar
Re: POT sizes
-Hmm, I have short shaft CTS pots in mine. Best rule of thumb for you I guess is to check the ones that are in it right now. Mine came stock from Epi with short shaft pots. Maybe they changed things after mine....
L8R,
Matt
1991 Fernandes LE-1 Strat copy refinished by me.
1993 Samick SSM1 Strat copy with Carvin S60 single coils in neck and mid, with a Bill Lawrence L-500XL in the bridge. Screamer!
Samick Stingray bass copy.
Epiphone Valve Junior slightly modded.
Hartke B30 bass amp.
AnthemBassMan is offline   Reply With Quote
Unread 11-29-2011, 09:40 PM   #4 (permalink)
SJM
Premium V.I.P. Member
SJM's Avatar
Re: POT sizes
My Epi's have short shaft pots. My Gibson has long. I'd buy either short shaft pots or some extra washers.
blues_n_cues likes this.
______________________________
Steve-M
'52 Martin D-28
'70 Fender Telecaster
'15 Squier Deluxe Strat
'78 Ibanez Pro Mdl 2671/S-AV
'02 Epi LP Elite Std VSB
'07 Epi LP Elitist Std+ FCB
'10 Epi LP 57 Gold Top
'10 Epi LP Std Plain Top HB
'12 Epi LP 1960 T+ FCB
'12 Epi LP Ace Budokan
'14 Epi LP Custom Classic
'11 Gibson LP Bonamassa Studio
'12 Gibson LP Traditional +
SJM is offline   Reply With Quote
Unread 11-30-2011, 04:54 AM   #5 (permalink)
onlypadog's Avatar
Re: POT sizes
I buy my parts from axesrus, and when I did my Epi mods I used short shaft. They are called CTS Medium Shaft on axesrus for some reason which I don't yet know
Giggidy giggidy goo
onlypadog is offline   Reply With Quote
Unread 11-30-2011, 05:48 AM   #6 (permalink)
BoatGuy1970's Avatar
Re: POT sizes
Every Epi I've seen takes short shaft. Also, I highly recommend audio taper over linear taper, especially for volume pots.
You'll need to open up the holes for the pots just ever so slightly. I use 60 and 220 grit sandpaper. Cut a 4x4 inch piece of both grits and roll them up. Put them in the holes and gently work the sandpaper up and down while slowly rotating the sandpaper in the hole. Start with the 60, and constantly check to see if the pot fits. You don't want to make the holes too big. When the pot just barely doesn't fit in the hole, finish it off with the 220. You'll get a great result, and the pots will just slide in with almost no play in the hole. Also, you won't have to worry about hurting the finish.
The hole directly above the tailpiece has already been finished. You’ll see it looks clean compared to the other holes.
Cheers,
Mike
Check out my blog for guitar addicts - Another Guitar
BoatGuy1970 is offline   Reply With Quote
Unread 11-30-2011, 06:40 AM   #7 (permalink)
Re: POT sizes
woah.. very niceeee... Thx for the replies...
Unread 11-30-2011, 12:42 PM   #8 (permalink)
p700's Avatar
Re: POT sizes
Chart of pot sizes
http://www.box.com/s/b5tl28ia941chqn4szx1
Epiphone Les Paul 100 (2009)
Epiphone Les Paul Custom (2002)
Epiphone Riviera Custom P3 (2010)
Epiphone Emperor Swingster (2011)
Douglas Tele-copy
Surf City Spider Resonator A/E
Ibanez M511S-BS Mandolin
p700 is offline   Reply With Quote
Unread 11-30-2011, 01:08 PM   #9 (permalink)
Business Closed
Re: POT sizes
Nope. Short shaft.
martin6string is offline   Reply With Quote
Unread 11-30-2011, 01:17 PM   #10 (permalink)
KP
KP's Avatar
Location: Kalifornische Demokratische Republik Core Club ®
Re: POT sizes
Short and you do need to open the holes to accommodate CTS pots. I know this because I have done it.
"Fast is fine, but accuracy is everything." .... Wyatt Earp
"I want you to be nice until it's time to not be nice." .... Dalton
"The difference between genius and stupidity is that genius has its limits"… Albert Einstein
01110011 01101000 01110101 01110100 00100000 01110100 01101000 01100101 00100000 01100110 01110101 01100011 01101011 00100000 01110101 01110000
8 Hammers
47 Wrenches
21 Screwdrivers
129 Sockets
8 Tape Measures
15 Pliers
9 Saws
KP is offline   Reply With Quote
Unread 01-04-2012, 02:33 PM   #11 (permalink)
p700's Avatar
Re: POT sizes
Ugh, I just bought a 2002 MIK Epi LP Custom that I thought would be a little bit of a pain in the ass, turns out it's gonna be a nightmare. I thought I got a smokin deal on it so that I could toss a Bigsby on her and rock out. Turns out that it needs some serious TLC. I am about to order pots, I live down the street from Antique Electronic Supply. Do you guys buy solid shaft or split shaft.
I also need to buy:
-a pickguard and gold bracket
- speed knobs
- strap locks
- toggle switch
(but all that is for another post I suppose)
Douglas Tele-copy
Unread 01-04-2012, 04:30 PM   #12 (permalink)
SJM
SJM's Avatar
Re: POT sizes
I also need to buy:
- speed knobs
- strap locks
- toggle switch
Split shaft and I've used their Bourns pots on a couple of things and find they work as well as CTS. They don't meter out as well as CTS but the tapers are great and Antique Electronics has a really low price on them.
Steve-M
'52 Martin D-28
Unread 01-04-2012, 04:37 PM   #13 (permalink)
p700's Avatar
Re: POT sizes
got my answer - split shafts!
During my search I found Guitar Parts & Wiring Diagrams-FREE Shipping Over $49 to have sweet deals and great selection. No, they are not paying me but I can get 4 CTS 500K pots (two linear and two audio), 4 speed knobs, gold strap buttons, gold toggle switch screw ring, gold pickguard bracket, 4 caps, toggle switch knob, and a new 1/4" jack for about $75. Nice little project I have here.
From their website it looks like Antique Electronic Supply does not have guitar pots by CTS. Too bad, since they are down the street. Correct me if I am wrong.
Douglas Tele-copy
Unread 01-04-2012, 05:08 PM   #14 (permalink)
SJM
SJM's Avatar
Re: POT sizes
They sell CTS pots, just not the ones you need.
Steve-M
'52 Martin D-28
Unread 01-04-2012, 08:54 PM   #15 (permalink)
imitebelvis's Avatar
Re: POT sizes
I also need to buy:
- speed knobs
- strap locks
- toggle switch
Did the custom turn out to be a bad deal?
Fendesquire Gibsiphone - I loves 'em all!
imitebelvis is offline   Reply With Quote
Unread 01-04-2012, 09:29 PM   #16 (permalink)
p700's Avatar
Re: POT sizes
I am posting pics tonight.
Douglas Tele-copy
Unread 01-13-2013, 03:33 AM   #17 (permalink)
blues_n_cues's Avatar
Re: POT sizes
you can usually get one of these free or for less than a quarter @ Lowes or any hardware store. just trace the 3/8" diameter w/ a pencil & save the time of constantly rechecking the holes.
2007 epi lp custom antique ivory finish
Austin gold top w/ P90's
Yamaha HSS strat
(loads of other junk)
vox 847 wah>>alesis midiverb2(delay)>midiverb 3(chorus on occassion)>Marshall JMP-1(midi rack pre)>Alesis RA-100 pwr amp> B-52 4x12 cab loaded w/ Altec 417 8-h's.
blues_n_cues is offline   Reply With Quote
Unread 01-13-2013, 04:05 AM   #18 (permalink)
Bigneil's Avatar
Re: POT sizes
To fit epi lp, the collar (the threaded part of the pot shaft) needs to be 10mm long. This is what usually described as a short shaft, but watch out because you get even shorter ones for strats. The long shaft usually have 18mm collar, this is the size for gibbys.
All sparks will burn out in the end. R.I.P
the Unofficial epiphone wiki
http://epiphonewiki.com/index.php?title=Main_Page
animalfarms DIY links
http://epiphonewiki.com/index.php?ti...m%27s_DIY_List
Bigneil is offline   Reply With Quote
Unread 01-13-2013, 04:31 AM   #19 (permalink)
Re: POT sizes
I have a '96 MIK Epi GT. I assume by all the remarks that I would want to use short shaft pots?
Thanks
gmeyers is offline   Reply With Quote
Unread 01-13-2013, 04:49 AM   #20 (permalink)
SJM
SJM's Avatar
Re: POT sizes
This is an old thread. I've since started using long shaft pots on my Epi's even though short will work. The long shafts are easier to fit in and much easier to solder on inside the cavity. They usually come with two nuts for easy length adjustment. An Epi LP Standard body is typically only 1/8" less in thickness to that of a Gibson LP Standard so there is still plenty of clearance inside the cavity.
Steve-M
'52 Martin D-28
Unread 01-13-2013, 06:14 AM   #21 (permalink)
Re: POT sizes
why solder inside the cavity?
I took some old mouse pads & scrap paneling I had & traced the back plates to my LP's & cut them out then glued them together.
it's a safe solder surface & doesn't scratch or slide on the guitar's back.
I'll get a pic up later.
SJM likes this.
Yamaha HSS strat
Unread 01-13-2013, 06:36 AM   #22 (permalink)
SJM
SJM's Avatar
Re: POT sizes
I use 4X5 plastic cover plates like those used in welding helmets to make templates out of. I build the harnesses on these then install them. I solder the pups, toggle switch wires and ground wires to the harness inside the cavity. With long shaft pots, the soldering is actually quite easy. The harness in this pic was actually made by Tundratone but I soldered the connections inside the cavity.
Steve-M
'52 Martin D-28
Unread 01-13-2013, 07:10 AM   #23 (permalink)
SwisherSweets's Avatar
Re: POT sizes
do what this guy said
SwisherSweets is offline   Reply With Quote
Unread 01-13-2013, 07:47 AM   #24 (permalink)
Re: POT sizes
mmm,,me have big shaky bass player hands & I recently realized I'm going blind.
SJM likes this.
Yamaha HSS strat
Unread 04-02-2014, 07:31 PM   #25 (permalink)
arc anjil's Avatar
Re: POT sizes
So there are no good metric pots for Epi guitars?
Arc Anjil
For this is the vixen, Maeve,
Of the "Order of The Falcon's Talon".
Sweet as honey, and warm like the sun.
arc anjil is offline   Reply With Quote
