#781 (permalink) |
Re: Dulling Poly Finished Guitars PIC HEAVY!!
thank you for this tutorial. I'd like to ask you one thing : did you also do the side of the guitar? is it the same process? is this way good for all poly guitars? thank you |
#782 (permalink) |
0000 steel wool, even done lightly by hand looks like years of someone wiping the guitar with a dirty rag. I used Dunlop 65 polish after. I've gotta talk the custodian at work into saving the floor pad for me. I only did the back of the neck, but it already looks better. Well, except for the scratches.
I got a black roller bridge today and still waiting on the tailpiece, tuners, and pickups. It's gonna look so much better than it did with the chrome. It no longer looks like a toy.
#783 (permalink) |
I tried this process with my Black Epi SG 66 and it failed miserably. I used the same equipment (B&D Mouse, 3M pads) as everybody else and didn't apply any pressure but it just left too many scratches & swirl marks for me to live with. My sander left tons of little scratches that look like spiral notebook wires or old school telephone cords.
Luckily I experimented on the back and was able to get the shine back by wet sanding it with 1000 grit then 1500 grit then a white 3M Final Finishing pad (p/n 10199NA at Lowe's) and a combo of turtle Wax Polishing compound and Meguiar's Scratch X 2.0. I think this process is better suited for a clear coat poly over wood and not a solid finish, especially black. |
#784 (permalink) | |
There are several black guits that have been dulled, in mi own experience I rather sand by hand with 1500 or even 2000 grit sand paper and the finish was excelent.
When I used the mouse I get scratches all around, when I start to get the shine back sanding with 1500 grit paper, I realice that the finish get dulled like I wanted first so I let it as it. Quote:
Epis: Elitist Jay Jay French Pinkburst, ///OBL, Black Beauty, Tobacco PlusTop, CherrySB Plus Top, Honey PlusTop, Joe Bonamassa GT, G400 Goth Gibson LP Std Honeyburst Yamahas: Image Std CherrySB, Pacifica 112 OVS, SG1000 CherrySB Ibanez: S540 LTD Custom, Art300, Art200, SA160 Suzuki cherrySB LP copy Hohner GT LP copy Ovation: Celebriry Deluxe CS257, CC059 Nylon ... And some others Some pics |
#785 (permalink) | |
When you sanded yours by hand, Did you go in a circular pattern or with the grain of the wood? |
#786 (permalink) | |
I did it in small circules, but around the arm I couldnīt, so I did it back and foward. But the really really important stuff was that I use a wet sand paper. You donīt need a lot of water, but you have to soak the sand paper time to time to clean it and mantein it wet all time.
#788 (permalink) |
My best results were from a red and white 3m pad, with a random orbital sander. Red pad used a couple of passes to get a nice, white, dusty, OMG, WHAT HAVE I DONE surface, and then clean with wet towel, followed by the white pad with Dunlop 65 polish. Polishing compound and swirl remover had grit that left scratch marks. Sand paper was too harsh, even down to 2500. I even tried toothpaste.
![]() Some parts were pretty thin on this cheap POS, but I guess it adds to the "aged" look. I'm liking the black hardware. Now if I wasn't so tired with other things to do, I'd set up the strings and try out the new Wilkinson P-90's. |
#789 (permalink) |
I know it's probably not what you guys are used to, but I've already started the process on my Jaguar! So far, so good.
If you guys want pics, just let me know and I will take some. |
#790 (permalink) |
Don't know if this has been asked yet, but has anyone given this a shot with a Mr Clean Magic Eraser? I'm wondering if it would be effective or not? I know when I cleaned the shiny finish on my white macbook, it made it a dull/flat finish, but not sure of it's effectiveness on poly. Any test dummies out there or folks that have given it a shot already?
#791 (permalink) |
I want to do this soooo bad but Im worrying I will screw up really bad.
"BCON" BrandonConnor ![]() Two things you should never forget: 1 - The only time it's okay to work with amateurs is if you're making porn 2 - If you want to work with clowns, join a circus! |
#792 (permalink) |
trust me you wont, i put it off for the longest time. Just get what you think are the right materials and try it out on a spot on the back of the guitar or on the back of the neck. The thing is as long as you dont eat into the veener or the wood, whatever you do can be buffed back to a shine. Dont put it off just do it, there is nothing to it just follow the OP's directions its as simple as it seems just let the sander do all the work.
#793 (permalink) |
Alright, I have a question for those of you who have successfully pulled this method of dulling off.
I am fixing to buy a black Ibanez RG2EX1 for a good deal, but part of the reason it is a good deal is becuse the body has been scratched up quite nicely. There aren't any scratches deep enough to the wood, so it's all in the poly. Now despite the fact the it is scratched up, I really like satin black guitars. Now to the question; being that the poly is scratched up, would using this method to bring the guitar to a satin black pretty much eliminate most or all of the scratches? If I can make the guitar a satin black and clean it up from scratches in the process, then this guitar would be absolutely beautiful, and a killer deal worth it. Thanks for your help!
Guitars Gibson Les Paul Studio- Satin Black Epiphone Les Paul Standard- Black Squier Vintage Modified Jazz Bass '77- Black Squier Vintage Modified Jazz Bass '72- Natural Squier Vintage Modified P Bass- Black |
#794 (permalink) | |
IMO a killer deal always worth it, because the wood and electronics still there. If after wet sanding you didnīt get all scratches off, you can always paint your axe again. If you donīt know how to do it, I strongly recommend that ask for help to a professional luthier.
Good luck with your deal !! Quote:
#795 (permalink) |
What would you guys say is the best wax/polish for finishing this off? I'm trying this later and doing it by hand. Did the neck on an Epi Goldtop a while back and am now ready to do the rest!
#796 (permalink) |
I registered here as a result of finding this thread. The guitars in all these photos look amazing!
I'm seriously GAS'ing for an Epi Dot and I'll be looking into doing this on the finish as well as upgrading all the electrics and maybe the hardware too. I'm interested to hear about anyone who has tried this technique on the finish and then either polished up to a moderate shine or applied some other laquer like nitro. Still not sure what colour to get, but Cherry is looking like number one contender right now. After that a black Epi LP Standard would be nice too. Really inspiring thread guys. |
#797 (permalink) | |
#798 (permalink) |
If I had a Guitar I wasn't afraid of messing up... I would totally try this. Haha, might have to throw a little bit of cash at buying me a cheap LP copy just for the sake of doing this. Then get me some pups and new plastics and just mod that shizz up. XD Ahh, I'm in the mood to customize a Guitar... =D
CRAP. I just necro'd a thread didn't I? XD |
#799 (permalink) |
This thread should be sticky, a lot of views and a lot of good ideas here !! Don't be afraid to try, as I said before, you can always get the shine back, the poly finishes are very thick.
#800 (permalink) |
Has anyone in Canada done this, and where did they find the materials that provided them with success?
I really want to attempt this but I am very hesitant as I really don't want to screw up my LP. Cheers EDIT: Is there a 'grit' rating on the pads that were used in the OP? |
#804 (permalink) |
Looks great that top !!!
#807 (permalink) |
Has anyone done this on a black guitar? I wanna try it on my LP tribute but don't want to ruin it either so I'd like to see some pics.
Also, do you have to keep applying that Turtle Wax polish every so often or is it just one application and that's it? |
#808 (permalink) |
There are some post about black guits, after the process they stay awesome !! Try it over that tribute and post some pics.
#809 (permalink) | |
Thx, I posted a more detailed (german) tutorial here: [DIY] Epiphone Les Paul Lack matt schleifen
#810 (permalink) |
She looks really stunning!! Bravo!! Or shud I say Brava?!
BORN TO LOVE LES PAULS!!! GUITARS: 2012 Epiphone LP Custom PRO Silverburst - Silvana 2010 Epiphone LP Tribute 1960 Trans Black - Trisha K.Garage EA400 MiK AMPS: VOX VT40+ Ashton BA15 Effects: Digitech RP1000 |
| Tags |
| dulling, dulling yourself...., omg dont do that!, poly, ruining a good guitar |
