Go Back   My Les Paul Forums > The Les Paul > Epiphone Les Pauls
Old 03-23-2009, 12:51 AM   #181 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
Re: Complete EPI custom setup
Originally Posted by Sinster View Post
The problem I run into sometimes when I fret the 12th is depending on the pressure I put on the string I don't get a good reading any suggestions.
Every player should learn to do their own intonation.
The reason being, is that every player has their own touch with how hard they push the string onto the fret.
When you factor in different fret heights or even scalloping, the players touch becomes more of an issue.
WHEN YOU INTONATE, USE THE SAME PRESSURE ON THE STRING AS WHEN YOU ARE PLAYING. In other words, you are intonating the guitar for YOU.
That is KEY.
Roman
Factories build guitars for profit, Luthiers build them for players
Roman Rist is offline   Reply With Quote
Old 03-29-2009, 09:04 PM   #182 (permalink)
LEFTY LES's Avatar
Originally Posted by Roman Rist View Post
I did the final nut height adjustments and she is playing pretty sweet!
Except for one thing.................Sticky neck!
We fixed that by sanding it with 400 grit to take off the gloss. Then followed it up with some steel wool.
The back of the neck now has a satiny matte finish and is MUCH smoother to play.
Of course I would not do this unless some one asked.
After steel wool.
As It gets played it will shine up a bit more but will still retain the slinky feel.
I have 600 grit sandpaper and 0000 steel wool. Would that be ok or is 400 grit a must???
LEFTY LES is offline   Reply With Quote
Old 04-01-2009, 08:09 PM   #183 (permalink)
how much did that cost????
TTACKK is offline   Reply With Quote
Old 04-13-2009, 07:20 AM   #184 (permalink)
jimmyslash's Avatar
i would never do this all by myself. i would just ruin the guitar and i don't want that to happen.
Epiphone Les Paul Standard Plus HCS
Roland Cube 60
Digitech Bad Monkey
Dunlop Crybaby GCB-95
jimmyslash is offline   Reply With Quote
Old 04-17-2009, 07:56 PM   #185 (permalink)
I just sanded my neck as well. Did it with 320 grit sandpaper and 000 Steel Wool.
Used masking tape to make a nice "edge" on the headstock and where the neck meets the body. After each pass with the sand paper i used a towel to wipe away to dust to make sure the whole area had a light sanding. After i was satisfied with the sanding i went over it very lightly with steel wool before taking off the masking tape.
Sanded too much by accident and wore through the paint, the wood showing is an area smaller than a tuning head. Noticeable but on the neck so it doesn't bother me.
rusnak167 is offline   Reply With Quote
Old 05-13-2009, 01:08 AM   #186 (permalink)
#1guitarman's Avatar
Send a message via AIM to #1guitarman
OK, Roman...
I have an Epi standard that you can pimp for me...THAAAATS RIIIGHT...Pimp My Ax...all I need is an address and a price...I'll send ALL hardware (Duncan pearly gates neck and bridge/tulip tuning keys/bone blank nut)electronics(CTS pots/Vit Q oil filled caps/Switchcraft jack and switch..YOU SIR do one HELLUVA JOB!!!!...you can email me @ Greatwhite087@AOL.Com, I'm not afraid to ship, I pack like I'm never comin back! do the whole deal>frets,board,intone,just pimp the ax bro!!! Treat it like it was yours...
Peace
#1guitarman is offline   Reply With Quote
Old 05-17-2009, 10:26 PM   #187 (permalink)
In closing, She plays great. I would not hesitate to take it to a gig and play it.
We'll see what Hector has to say
Cheers,
Roman
Roman,
Great thread. I've learned to do my own setups also and a lot of guys who own much more expensive guitars enjoy playing my Epi, for the great feel.
gord1013 is offline   Reply With Quote
Old 05-17-2009, 10:28 PM   #188 (permalink)
Cheers,
Roman
Roman,
Great thread. I've learned to do my own setups. A lot of guys who own much more expensive guitars enjoy playing my Epi, for the great feel of the neck.
Old 05-21-2009, 03:28 PM   #189 (permalink)
dork5002002's Avatar
I really enjoyed looking through this thread. I thought it was pretty informative. I really wish I had someone near me that could do work like that. I could never trust myself to do that to a guitar I wanted to play. I would probably destroy something in the process.
dork5002002 is offline   Reply With Quote
Old 05-24-2009, 03:13 PM   #190 (permalink)
watchunglava's Avatar
Location: Portland Maine USA made man in the ebony mafia
Send a message via Skype™ to watchunglava
roman , you are clearly the man at his shit !
quick question if you have the time to answer it , why do you recogmend scraping the board and removing wood rather than using something like frombys deep clean or murfeys oil soap .
both of which i have used with great success.
watchunglava is offline   Reply With Quote
Old 06-09-2009, 04:31 AM   #191 (permalink)
p90rules's Avatar
Great Thread.
How do you smooth down the fingerboard between the frets without causing scratches ? My Les Paul had a clumsy fret dress/profile that left some marks & gouges either side of some frets & I want to tidy them up without affecting the frets if that's possible.
Steve Hunter & Dick Wagner
Rock & Roll Animals.
p90rules is offline   Reply With Quote
Old 06-18-2009, 08:02 AM   #192 (permalink)
GaloDeBarcelos's Avatar
A little polish and it is time for the glamour shot!
We are done..................till the next edition. pickups and electronics.
been waiting for long...oh well..whenever your ready. Thanks
Rocking the world From Portugal
VIDEO
VIDEO
GaloDeBarcelos is offline   Reply With Quote
Old 07-17-2009, 10:23 AM   #193 (permalink)
Where would I find this import gotoh bridge. I would like to get the right one the first time
johnnyfever is offline   Reply With Quote
Old 07-18-2009, 04:11 PM   #194 (permalink)
Thanks for this great thread.
I own a EPI Les Paul limited edition.
Using this thread I tried to set up the intonation.
I could correct all strings except the high E string.
The open E is tuned, but when I press the 12 th, it is to flat. The problem is I can not screw any further on the bridge. It is on its end in the direction to the neck. The bridge it correctly mounted accoring to me. What could be wrong here ?
Thanks in advance
abrink is offline   Reply With Quote
Old 07-20-2009, 06:03 PM   #195 (permalink)
KP Willits's Avatar
Gotoh Tune-o-matic Bridge with Studs/Bushings at Stewart-MacDonald
A government big enough to give you everything you want, is strong enough to take everything you have. ...... Thomas Jefferson
Seriously, thats not cool. I'm probably smarter than you when you were my age. I get all A's (Occasional B) and I'm also clever...... J-man123
Kim Jong-Il invented Corey...... KPW
KP Willits is offline   Reply With Quote
Old 07-21-2009, 03:49 AM   #196 (permalink)
I just did the fingerboard scraping, 0000 steel wool buff, and lemon oil to my PRS SE Custom, and I am amazed at how different the board looks. Thanks Roman!!
lpplayer is offline   Reply With Quote
Old 07-22-2009, 02:26 PM   #197 (permalink)
Thanks for the help... I looked at those but wasn't sure if that was the right one. I am in the middle of a project that involves a new Epi LP Custom Classic Antique Ebony that I am installing gibson 409r/498t pickups, bone nut, grover deluxe keystone tuners, Schaller strap locks, Rs Guitar works upgrade pots, Switchcraft switch and input jack, and Gibson vintage reissue strings. I am using some of the ideas from this thread and some of my own research and working with a luthier here in Indianapolis. Now I get the Gotoh bridge.....
Old 07-29-2009, 02:24 PM   #198 (permalink)
Satrian's Avatar
Mn... I wish I could send you my recently purchased Les Paul Custom Silverburst. I guess I'll have to fin a decent luthier in Argentina to do the job. Great post hombre!
Satrian is offline   Reply With Quote
Old 08-02-2009, 02:02 PM   #199 (permalink)
oldaxeman's Avatar
This is my absolute favorite thread! When I 1st read it i had to do the fingerboard thing and it was amazing how much better it looked! This is the kind of information I've always wanted and I get it for free from Roman! I've always loved to play guitar and when it looks better and feels better it just makes it that much better! Invaluable information Roman! You should write a book! There are guitar players everywhere that would gladly spend bucks for this kind of stuff! You Da Man!
oldaxeman is offline   Reply With Quote
Old 08-18-2009, 07:06 AM   #200 (permalink)
ToothDecay's Avatar
So is it easier to sand the neck by hand or to use a machine?
ToothDecay is offline   Reply With Quote
Old 08-20-2009, 11:13 PM   #201 (permalink)
ToothDecay's Avatar
Nevermind, just finished sanding
Old 08-23-2009, 04:54 PM   #202 (permalink)
dynac0mp's Avatar
Question for you, Roman: I'm just about to get a replacement bridge. It looked like a Nasvhille bridge from TonePros that you said fit right over the original metric? Can you point me to a model number? I've got an Epi LP STD circa 2009...
dynac0mp is offline   Reply With Quote
Old 08-23-2009, 05:58 PM   #203 (permalink)
Atomic's Avatar
wow what a great thread!
i had to learn to do all of this on my own.. so its really great to see someone like mr Rist taking the time to give us all some very valuable information!
i recently did just this kind of setup on my Yamaha, and im really glad to know that all this time i have been doing it right.
Atomic is online now   Reply With Quote
Old 08-27-2009, 01:37 AM   #204 (permalink)
Geardog's Avatar
Best setup thread. A master sharing his experience, expanding the art form unselfishly for all - is a true craftsman.
Thank you RR
http://StringDog.net
Geardog is offline   Reply With Quote
Old 08-27-2009, 11:17 PM   #205 (permalink)
ahowell21's Avatar
Send a message via AIM to ahowell21
Great thread roman
ahowell21 is offline   Reply With Quote
Old 09-26-2009, 06:35 AM   #206 (permalink)
My first post here, hello everybody.
Learnt a hell of a lot out of this thread. Kudos to the OP, will be looking to get my cherry sunburst LP Epiphone setup when I can.
Boss 302 is offline   Reply With Quote
Old 09-27-2009, 01:26 AM   #207 (permalink)
Send a message via MSN to rfcbeach
Thumbs up Thank You, Roman!
Also my first post here, what's up guys? I just wanted to send a huge thanks to Roman, very informative and concise thread you have here, my friend. Let me say, this shit works, no doubt! I may not own an Epiphone, but I sure as hell can say from recent experience that it works like a dream on my entry-level Ibanez RG120. I dressed and polished all the frets as shown here, replaced my old plastic nut with a new graphite nut, fixed the intonation, tightened the truss rod and fixed the action and my $170 guitar looks and plays like a $5,000 masterpiece. Very well done, Roman !
rfcbeach is offline   Reply With Quote
Old 09-29-2009, 09:49 AM   #208 (permalink)
brianugly's Avatar
Welcome RCFBeach and Boss 302 to MLP! Hope you guys enjoy the posting, and information about guitars as well as the rest of us do! If you guys have questions be sure to post them in the FAQs--the guys that know the answers will give you great advice.
AL3000
Epi LP Deluxe
Vintage SG400
V32
brianugly is offline   Reply With Quote
Old 10-05-2009, 01:08 PM   #209 (permalink)
Street Fighting Man
lukemacauley's Avatar
Roman, could you email me a price on a full set up, plus installing a prewired harness, toggle and jack please. Love the thread!
Luke.
"If I was suddenly stuck alone, I could stop myself going mad as long as I had a guitar."
Keith Richards.
Epiphone Les Paul '56 Goldtop Reissue (Currently Upgrading)
Takamine EG523-SC Black
lukemacauley is offline   Reply With Quote
Old 10-06-2009, 10:50 AM   #210 (permalink)
latomas's Avatar
Thanks Roman. definately makes the guitar sing hell of a lot better.
latomas is offline   Reply With Quote
Complete wiring upgrade for Epi LP ZoomZilla Tonefreaks 9 08-07-2008 03:10 AM
Arm Surgery Complete... b-squared The Backstage 34 07-03-2008 01:04 PM
Les Paul Custom cleaning and setup [pics inside] nakleh Gibson Les Pauls 46 06-16-2008 09:53 AM
please help my 55 Les Paul Custom be complete CRR444 Vintage Les Pauls 3 03-19-2008 02:20 AM
Rig is complete ZoomZilla The Squawk Box 10 02-01-2008 10:14 AM
