#2 (permalink) |
Master Entertainter
Re: switchcraft toggle switch
if your unsure take your current switch out and measure its diameter, then check the demensions of the switch... if it dosent say contact the seller and ask... this will be your only sure way of knowing it will fit... someone here might eyeball it and say yep thatll fit... but you never know for sure with out numbers....
"It is no measure of health to be well adjusted to a profoundly sick society." -Jiddu Krishnamurti
#3 (permalink) |
well the current switch is one of these
![]() heres a link. Guitar Parts Resource* ::*Toggle Switches well the longer switch supposely meausures 1 1/2 inches. just measured my cavity for the switch and it measure 1 1/2 inches.idk if the cavity needs to be bigger or if thats enough. |
#4 (permalink) |
Master Entertainter
thatd would be a tight fit, if it fits at all... remember your going to have the wires comming off of it as well, then again the switch may not have all 1 1/2 inches inside of the cavity, some of that will be going though the hole and out of the hole... im sure someone will chime in thats replaced theres... what makes you want to change it anyways, is yours going bad?
#5 (permalink) |
Page d'accueil
Check out that site. He's compared a couple of switches cause the Epi's used different measurements, the switchcrafts might be a lil tight..
Ebony MIJ Epiphone Custom + Buncha Pedals. Laney LC15R www.youtube.com/psychotubes sis ♥ lin |
#6 (permalink) | ||
nope not yet,but im replacing it sometime in the future and just wanted to know. Quote:
#7 (permalink) |
Of concern also is the length. I bought a long one just like that for my Gibson Vintage Mohogany and it was too long, but not by much - if I had a thick maple top it may have been a different story - maybe. I think as far as length goes, the shorter ones will more often fit than the longer ones.
#9 (permalink) |
No prob
#10 (permalink) | |
![]() Join Date: Jan 2008
#11 (permalink) |
I stated in another post about reaming the hole a little bigger. Notice the Epi switch has more threads. Once the hole is reamed place the switchcraft in. Notice maybe 1 or 2 threads peek over the top. You will have to remove some wood around the hole from the inside a little at a time until you have enough threads to secure the nut properly. Wires should be soldered downward towards the switch or it might not fit in the cavity.
#12 (permalink) | |
Epiphone hasn't used a box switch like that since the mid 90's. This is what is in my Epiphone Les Paul. http://www.guitarpartsresource.com/ESHORTYTOGGLE.jpg these can be found in in about every Epiphone electric. Check the lower F hole of any Casino, Sheraton ,Dot, Wildcat and you will see a mini toggle just like the old switchcraft, only smaller. Last edited by sasquatch; 07-10-2008 at 06:19 PM. |
#13 (permalink) |
oops!sorry your right it is like that,they looked similar so i thought maybe it was it.thanks for clearing it up for some future forumite that searches the forums!
#14 (permalink) |
So what is the Switchcraft part number I should be hunting for then?
I have 1992 Epiphone Les Paul (with one of those boxy toggles) that needs a toggle upgrade. Would hate to order the wrong one. |
#15 (permalink) | |
"Now Known as The Post-O-Matic 5000" ![]() ZOMG! Its Gemma!!
#16 (permalink) |
mmm my switch is this one that sasquatch posted.
http://www.guitarpartsresource.com/ESHORTYTOGGLE.jpg im not sure if it may vary. |
#17 (permalink) | |
#18 (permalink) |
You can use the long Switchcraft type in a Les Paul. For an SG it takes a 90 degree type, or mini.
Epiphone Les Paul Plus HCS Epiphone G-400 Custom AI Epiphone G-400 Vintage WC Epiphone Firebird Studio WC Marshall HDFX 100/a Digitech RP-250 |
#19 (permalink) |
I fitted a long switchcraft toggle in my Epi LP. The length of the switch caused no problem and my guitar had the correct size hole (1/2" I think) so no reaming was required. What you do need though, is the deep nut due to the Epiphone being thicker in the area around the switch. I only did mine finger-tight and I have to have the toggle switch tip unscrewed slightly, as if I screw it right down it hits the nut and pings back into the middle position.
Deep nut ![]() Picture of toggle on my guitar. My brother has also fitted the same toggle on his Epi LP, but he tightened the nut more, so the tip could be screwed further down. Click on the thumbnail for a bigger pic ![]()
| Vintage Switchcraft Switch Tips | FLICKOFLASH | The Custom Shop | 14 | 10-22-2009 08:10 PM |
| Switchcraft toggle switch | jon_c | Epiphone Les Pauls | 3 | 04-24-2008 06:26 PM |
| i need help with my toggle switch | bas256 | Epiphone Les Pauls | 3 | 01-19-2008 06:28 PM |
| Les Paul Switchcraft Toggle Switch History | HolyGrail | Vintage Les Pauls | 29 | 11-18-2007 07:59 PM |
| Problems with switchcraft toggle switches? | loneguitar | Gibson Les Pauls | 1 | 09-17-2007 02:50 PM |
