#1 (permalink) |
Epi weight relief
So we hear about Gibson weight relief all the time..swiss cheese, chamberd bodies etc....But what is Epi using? I recently aquired my 07 Epi silverburst custom, and It's definitely lighter than my previous 78 (non weight relief custom) and 94 (swiss cheese relief) Custom.
2011 LP JR w/ noiseless fralin Hughes and Kettner Edition Tube Last edited by marc1kim; 01-12-2011 at 10:42 PM. |
#2 (permalink) |
Re: Epi weight relief
Other then the Ultra/Ultra II(chambered) Epiphone Les Paul's are solid with no weight relief. Every now and then we see pics of odd balls that are chambered, from all that I have seen they are older Korean Zakk Wylde's and are not normal for that model.
Epi Joe Bonamassa Signature Goldtop Epi Les Paul Standard 1959 Faded Iced Tea 2009 Epi Les Paul Standard Plus Top Heritage Cherry Sunburst 2008 Epi Les Paul Custom Plus Vintage Sunburst 2009 Fender MIM Strat Brown Sunburst Rosewood Neck Traynor Darkhorse 15H/Darkhorse 112 Cab Vox VT30 Fulltone Clyde Deluxe Wah Fulltone Robin Trower Overdrive MXR EVH Phase 90 t.c. electronics ND-1 Nova Delay t.c. electronics Polytune |
#4 (permalink) |
hmm so no weight relief. Thats interesting. I suppose the African Mahogany is lighter than the Honduran variety.
2011 LP JR w/ noiseless fralin Hughes and Kettner Edition Tube |
#5 (permalink) | |
Epi Verification Expert
![]() Join Date: Jan 2009
But yeah, from what I've read, African Mahogany is lighter than other species. My non weight relieved all (African) Mahogany Tokai Custom weighs in at 4,3kg (9,48lbs). |
#7 (permalink) |
Hmm I don't know. I owned two 13lb boat anchor norlin Les Pauls, and The lighter modern ones...I prefer lighter. But most vintage guitars, seems like people look for the lighter grade mahoganies cuz they resonate better
#8 (permalink) |
As far as I know, Epi does not ''solid'' wood on their guitars. It's some kind of laminating process,which results to lighter instruments. Therefore, no need for swiss cheese holes or chambering.
#9 (permalink) | |
Laminate= plywood Plywood= more glue Glue= heavier than wood. The only REAL Epiphone I've ever seen made of plywood are the double neck SG's and some of the low end models like the LP specials and such. The higher end guitars are made of Nato, known as Asian mahogany, which is much cheaper and more readily available than African mahogany and helps to explain the price difference in Epi/Gibson. |
#10 (permalink) |
Epiphone wood is less dense and lighter than higher-grade (or real, for that matter) mahogany, but is also consequently less resonant and does not transfer vibration as nicely. As far as I'm concerned, this mainly affects sustain and isn't as important as people make it out to be.
My Epi weighs in at 8 pounds 6 ounces, which is pretty light but not featherweight by any means. The wood seems to be some sort of low-grade mahogany; the grain and texture seems to be that of mahogany, but the wood is light in color and pretty brittle.
'07 Epi Les Paul -SD JB & '59/Gotoh bridge/Switchcraft toggle & jack/CTS pots/2 push-pulls for coil-split/Orange Drops/Reflectors/Schaller strap locks/Custom cavity covers/Removed gloss from neck, pup rings, poker chip, fretboard, TRC '04 DSL401 -Bad Monkey/DS-1/Monster Cables/casters |
#11 (permalink) | |
Current Setup: Genevieve - My Epi Les Paul Standard in Natural Dot Studio in faded cherry with GFS Mean 90 in neck & Gibson 57 reissue in bridge. Home built 52 style tele with matched custom wound Bare Knuckle 'Yardbirds' Epi BC30 fitted with RCA Blackplates & a Mullard GZ34 Strat style bitsa known as the plank Korean Tanglewood TW400N Epi EJ200CE AXL Player PJ Bass Laney HCM30B Digitech GNX3 Yamaha AW16G http://www.soundclick.com/ianwigg Very little talent & big dreams! |
