MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Like Tree4Likes
Unread 06-22-2008, 07:40 PM   #1 (permalink)
Kiwirocker's Avatar
how do i remove humbucker covers?
hey im gettin my first les paul on monday and i what to see what it would look like without the covers but im not sure how to remove them...
its a les paul custom
Kiwirocker is offline   Reply With Quote
Advertisement
Unread 06-22-2008, 07:47 PM   #2 (permalink)
-Ninja-'s Avatar
Re: how do i remove humbucker covers?
If you remove them, you would have to wax seal them back on, if you want to put them back on. But to remove you would have to unsolder then from the bottom plate, or cut the solder and they will pull off with some force. There is a small chance you can damage the pickup doing this. You could rip a wire out from the wax not seperating. Not recommended just to see what it would look like without it. Look online, you will get all the pics you want.
-Ninja- is offline   Reply With Quote
Unread 06-22-2008, 07:56 PM   #3 (permalink)
jkinnison90's Avatar
Removing a humbucker's cover
2003 Epiphone Les Paul Standard - Heritage Cherry Sunburst
jkinnison90 is offline   Reply With Quote
Unread 06-22-2008, 08:30 PM   #4 (permalink)
Dino's Avatar
Don't use a solder gun ... the pickup will serve as a heatsink and you'll only end up burning yourself and making a mess.
Just cut the solder joints with a razor and slide off the covers.
wwit likes this.
Dino is offline   Reply With Quote
Unread 06-22-2008, 09:17 PM   #5 (permalink)
Kiwirocker's Avatar
well i was actually thinking of taking the bridge cover off... how do you think that would look?
Unread 06-22-2008, 09:26 PM   #6 (permalink)
-Ninja-'s Avatar
I personally like the look of the nickel covers. You may not. I am sure you can find some pics of them off.
Unread 06-22-2008, 09:29 PM   #7 (permalink)
To be honest you should just buy an open coiled pickup instead of removing the covers. I've seen some pictures of horrible colors underneath those covers. Also if you remove them you have a lot of wax to melt and tear off of the pickup.
Unread 06-22-2008, 09:29 PM   #8 (permalink)
dennistruckdriver's Avatar
A Dremel with a cutting wheel, if you have access to one, would be quicker, and you will be less likely to cut yourself. You may need to heat the cover slightly to soften the wax (if it is a potted pickup) to make it easier to remove.
Unread 06-22-2008, 09:31 PM   #9 (permalink)
Deliberately Obtuse
bildozr's Avatar
Dnt do it its a mess
When i got my new pups i did it to experiment
The wax made a total mess
+1 on buyin open coils
Youll probably find someting with more mojo one of these days and put em in
Latest endeavor, FT Leendrix:
https://soundcloud.com/billmanduder/maverick
Twitch:
http://www.twitch.tv/space_liger
bildozr is offline   Reply With Quote
Unread 06-22-2008, 09:44 PM   #10 (permalink)
-Ninja-'s Avatar
I experimented with my stock pups when I replaced them as well. I removed the cover on one of them. I was able to take a toothbrush and clear the wax out. I also had no problem of the plastic being discolored. Maybe some of them do, but mine came out good. I am planning to re wax the cover back on. I think the stock Epi pups are actually real good. But obviously you can get better from SD or someone.
Unread 06-22-2008, 09:58 PM   #11 (permalink)
Kiwirocker's Avatar
ok if i was to buy open coils what would they cost?
Unread 06-22-2008, 10:01 PM   #12 (permalink)
-Ninja-'s Avatar
Depends on what pup but roughly $75 a piece for a nice one.
Unread 06-22-2008, 10:08 PM   #13 (permalink)
Kiwirocker's Avatar
ok thanks for that
Unread 10-13-2009, 10:46 AM   #14 (permalink)
It,s been a while since your post, but check out guitarfetish.com. They have a great selection of custom made pickups at half the cost. They ship factory direct so thier cheaper. I put a set of paf's in my son's epi lp standard, they sound great.
eastbaydave is offline   Reply With Quote
Unread 10-13-2009, 12:30 PM   #15 (permalink)
KP
KP's Avatar
Location: Kalifornische Demokratische Republik Core Club
Here you go, several iterations from stock to current...
"Fast is fine, but accuracy is everything." .... Wyatt Earp
"I want you to be nice until it's time to not be nice." .... Dalton
"The difference between genius and stupidity is that genius has its limits" Albert Einstein
01110011 01101000 01110101 01110100 00100000 01110100 01101000 01100101 00100000 01100110 01110101 01100011 01101011 00100000 01110101 01110000
8 Hammers
47 Wrenches
21 Screwdrivers
129 Sockets
8 Tape Measures
15 Pliers
9 Saws
KP is offline   Reply With Quote
Unread 10-13-2009, 12:51 PM   #16 (permalink)
I think this discussion was WAAYY over by now...
Beerdog80 is offline   Reply With Quote
Unread 10-13-2009, 12:53 PM   #17 (permalink)
KP
KP's Avatar
Damn Beerdog... I did not even look at the time date stamp.... oh well.
8 Hammers
47 Wrenches
21 Screwdrivers
129 Sockets
8 Tape Measures
15 Pliers
9 Saws
Unread 10-13-2009, 01:52 PM   #18 (permalink)
All's good brother.
Unread 01-19-2014, 04:33 PM   #19 (permalink)
I just took the bridge cover off and to my surprise, a zebra! I'm leaving the neck cover on. The wax was not a problem at all, there wasn't much on it and it was easy to get off. Looks great.
Buttsy344556 is offline   Reply With Quote
Unread 01-19-2014, 04:40 PM   #20 (permalink)
LOL! You do realize that you responded in a thread from October 2009, right?
2013 Epiphone 1960 Tribute Plus VSB
2013 Simon and Patrick Songsmith A3T
2012 Squier Classic Vibe Jazz Bass
2001 Fender HSS Stratocaster w/Floyd Rose
Fender Mustang III V.2 | Ampeg BA112
6thString is offline   Reply With Quote
Unread 01-19-2014, 04:48 PM   #21 (permalink)
MLP Vendor
Unsung Heroes's Avatar
Indeed... but maybe he got some useful info from the thread and subsequently added his experience..?
There's another thread currently running in which the poster was partly given a little grief for not searching out info on previously discussed topics, so as much as I get ya 6th, striking the balance between endless duplicate threads and digging up older ones is a tough thing to balance
paruwi likes this.
Clive
Supplier of quality, pre-owned Epiphone Les Pauls - better than new and saving YOU money!
Guitar sales - Set up, Component Upgrades & Refurbishment Service - Parts & Spares
Unsung Heroes is offline   Reply With Quote
Unread 01-19-2014, 05:02 PM   #22 (permalink)
TheAce93's Avatar
You hit the nail on the head Unsung...
You either get yelled at 'Duhhh use the search function' or 'Duhhhh freaking necroposter'.
"Moving the goal posts" is the best phrase I can think of to describe it.
Unsung Heroes likes this.
2002 Epiphone Les Paul Ace Frehley Custom (Cherry Sunburst)
2005 Epiphone Les Paul Standard (Cherry Sunburst)
2008 Tokai Explorer (Vintage White)
2008 Ibanez Iceman ICT700 (Black)
2009 Ibanez Iceman STM1 (White)
2010 Epiphone Les Paul Black Beauty III
2010 Epiphone Les Paul Plus Top Pro FX (Vintage Sunburst)
2012 Epiphone Les Paul Custom Prophecy Plus (Midnight Sapphire)
2012 Marshall DSL40 Combo
TheAce93 is offline   Reply With Quote
Unread 01-20-2014, 02:38 PM   #23 (permalink)
Sustainamaniac's Avatar
I wouldn't recommend taking the covers off. The bobbins will look gross and potentially deformed and putting the covers back on would be a major pain. Potting pickups is not a fun job.
"To some extent I happily don't know what I'm doing. I feel that it's an artist's responsibility to trust that." -David Byrne
Originally Posted by Bigfoot410 View Post
Guitar mojo is like a snow globe. One must shake it to get it working.
Sustainamaniac is offline   Reply With Quote
Unread 01-20-2014, 03:43 PM   #24 (permalink)
Hack's Avatar
Who..... are you talking to?
It's not enough. I need more. Nothing seems to satisfy. I don't want it. I just need it. To feel, to breathe, to know I'm alive.
Hack is offline   Reply With Quote
Unread 08-04-2015, 01:19 AM   #25 (permalink)
dearlpitts's Avatar
lol
new band -http://www.timefurnace.com
my band noturning back www.myspace.com/noturning & www.reverbnation.com/noturningback
dearlpitts is offline   Reply With Quote
Unread 08-04-2015, 06:51 AM   #26 (permalink)
wwit's Avatar
Wooooo
A double Necrothread of a dead horse thread started 6 years ago.
Well done
Curmudgeon likes this.
wwit is offline   Reply With Quote
Unread 08-06-2015, 03:05 PM   #27 (permalink)
Curmudgeon's Avatar
Brian
2014 Joe Bonamassa Pelham Blue
2008 MIC '56GT
2007 Elitist Standard Plus FCB
2014 Squier 60th Anniversary Strat
1976 Alembic Short Scale Bass
2002 Curbow 5-string Fretless Bass
1960's JG Single Cutaway Bass
1968 Giannini Nylon String Classical
19th Century German Bowlback Mandolin (great-great grandmother's)
Bugera V-22
Hughes & Kettner 20th Anniversary Edition Tube Combo
Fender BXR 100 Bass Amp
BK Butler RealTube Preamp prototype
Curmudgeon is offline   Reply With Quote
Unread 08-11-2015, 02:22 PM   #28 (permalink)
Alty's Avatar
LOL, why? as they are there for a reason....runs away....
Your buying the guitar, not the name on the Headstock
ES-339 (Cherry Red) - Chet Atkins SST - Washburn WD10S - Tanglewood Earth 100 - Fender Sonoran (Apple Cherry Red) - Squier P-Bass/Jazz Neck (Black/Red) - Encore Bass - Yamaha FG402 - Squier Acoustic - Aria MAC Std. - Alvarez RD12/AF66 - LAG T66 - AXL Tele - Turser Thinline - Fender Mustang II - Marshall MB-30 - Epiphone SA15C - Fender Deluxe 112
Tanglewood TW28 - Westfield WF400NL - Yamaha FG720SL - Washburn D10SL - Freshman FA1AN
Alty is offline   Reply With Quote
Unread 08-20-2015, 11:23 PM   #29 (permalink)
Zard's Avatar
6 years ago I would have said: leave the covers on. (6 YEARS AGO)
'14 Epiphone Les Paul 1960 Tribute Plus [Faded Cherry Burst]
'13 Yamaha A3R
'13 Yamaha FG700S
Fender Mustang II (v2)
Fishman Loudbox Mini
Zard is offline   Reply With Quote
Unread 08-21-2015, 07:37 PM   #30 (permalink)
XTN
XTN's Avatar
Originally Posted by wwit View Post
Wooooo
Well done
See what happens when people use the search function?
XTN
This space intentionally left blank
XTN is offline   Reply With Quote
