Unread 11-24-2010, 11:36 AM   #1 (permalink)
DonLP's Avatar
Grover 135-N Vintage Tuning Machines - Nickel
Will these fit my Epi LP Custom? Its more cosmetic but i want to make sure they will fit.
http://www.activemusician.com/item--...eads%2C+Nickel
EDIT: They require a 10mm hole... i'm not sure what i have. thanks in advance!!!!!!
DonLP is offline   Reply With Quote
Unread 11-24-2010, 07:07 PM   #2 (permalink)
DonLP's Avatar
Re: Grover 135-N Vintage Tuning Machines - Nickel
Bump
Unread 11-24-2010, 07:46 PM   #3 (permalink)
nzo
nzo's Avatar
They will fit- after you re-size peghead holes to 10mm or 25/64 (9.9MM actually). I recommend a reamer.
nzo is offline   Reply With Quote
Unread 11-24-2010, 09:52 PM   #4 (permalink)
Customs have regular single screw Grover's, which are 13/32(10mm compatible). Epi's with Kluson style tuners have 11/32(8.7mm) and would need resizing to work.
You will need to drill new holes for the mounting screws, I would recommend putting some tape on the drill bit to act a depth gauge so you don't accidently drill through the headstock.
Epi Joe Bonamassa Signature Goldtop
Epi Les Paul Standard 1959 Faded Iced Tea
2009 Epi Les Paul Standard Plus Top Heritage Cherry Sunburst
2008 Epi Les Paul Custom Plus Vintage Sunburst
2009 Fender MIM Strat Brown Sunburst Rosewood Neck
Traynor Darkhorse 15H/Darkhorse 112 Cab
Vox VT30
Fulltone Clyde Deluxe Wah
Fulltone Robin Trower Overdrive
MXR EVH Phase 90
t.c. electronics ND-1 Nova Delay
t.c. electronics Polytune
dave-m is offline   Reply With Quote
Unread 11-29-2010, 10:16 AM   #5 (permalink)
DonLP's Avatar
awesome, thanks guys!
