Unread 11-22-2010, 03:43 PM   #1 (permalink)
Brian_C's Avatar
Changing PUP's - Epiphone wiring issue
Hi guys, I'm in the process of changing the pups in my Epi LP Standard (2009 MiC) to Gibson Burstbucker Pro's. On the Bridge PUP there's only a single wire coming from the new PUP. There's only one on the Epi PUP, but once I peel back the plastic wire coating there are 4 smaller wires (black, white, green and red). What do I connect the new BB Pro wire to, do I just cut the existing grey wire, and connect the BB Pro wire to that, that way I'm not interferring with the existing 4 into 1 wire connection.
It's a similar score on the Neck PUP, the single black wire, has a secondary smaller white coming out of it, connecting a terminal no the Vol pot.
My 'ther passion in life >> MySite
Brian_C is offline   Reply With Quote
Unread 11-23-2010, 03:19 AM   #2 (permalink)
Re: Changing PUP's - Epiphone wiring issue
Wiring Library
pedrology is offline   Reply With Quote
Unread 11-23-2010, 03:22 AM   #3 (permalink)
Big_dawg's Avatar
on the new pups are they braided wire...?
t'sall Good
And Jesus said 'come forth and you shall receive eternal life'....
But I came fifth and only got the toaster
But damn I got another guitar....
Big_dawg is offline   Reply With Quote
Unread 11-23-2010, 05:26 AM   #4 (permalink)
Brian_C's Avatar
Yes, it's a braided outer casing around the electric wire.
