Unread 11-02-2010, 01:23 PM   #1 (permalink)
HNG...not!
So I get my new (used) LP Standard about 15 minutes ago.
I need some advice as I'm new to LP's.
The strings are basically TOUCHING the stinkin' fretboard, and the knobs barely move...they scratch the surface of the guitar constantly.
What is the best way to adjust these things, if they are adjustable without paying a pro to do it?
Any ideas?
horax is offline   Reply With Quote
Unread 11-02-2010, 01:30 PM   #2 (permalink)
sasquatch's Avatar
Re: HNG...not!
I always replace those stock knobs with speed knobs. They have much more clearance and just look great.
If you remove the old knobs try to polish that area real good with some Smith Pro Polish or something similar.
Sounds like the neck went flat.
maybe a 1/8th of a turn counter-clockwise may help
Epiphone LP Special wP-90's
Squier CV 60's Jazz Bass
Squier VM Jaguar Bass
Marshall HDFX 100/a cab
Acoustic B200 115
Sansamp DI/Boss TU-3
Digitech RP-355
sasquatch is offline   Reply With Quote
Unread 11-02-2010, 01:30 PM   #3 (permalink)
ext1jdh's Avatar
Send a message via MSN to ext1jdh Send a message via Yahoo to ext1jdh Send a message via Skype™ to ext1jdh
Re: HNG...not!
Take it to the shop and have a proper setup performed.
There is no point in being grown up
if you can't be childish sometimes.
-- Doctor Who
Twitter
Facebook
Stop American Censorship Now!
ext1jdh is offline   Reply With Quote
Unread 11-02-2010, 01:39 PM   #4 (permalink)
Re: HNG...not!
1/8th of a turn on the bridge? Is that what you are referencing?
Do all standard knobs rub the body? It almost looks like the pots underneath are perpendicular to the floor, but the rounded body throws off the knobs.
Unread 11-02-2010, 01:48 PM   #5 (permalink)
Re: HNG...not!
On the truss rod, which is under the bell-shaped TRC.
josephchoi is offline   Reply With Quote
Unread 11-02-2010, 01:48 PM   #6 (permalink)
GrouchyDog's Avatar
Re: HNG...not!
1/8 of a turn on the truss rod. If you don't understand what that is, take it to a luthier for a proper setup - it won't cost that much and you'll get a more playable instrument back.
<img src=http://www.mylespaul.com/forums/members/grouchydog-albums-profile-sig-pics-picture41749-drz-circle.html border=0 alt= />
GrouchyDog is offline   Reply With Quote
Unread 11-02-2010, 01:51 PM   #7 (permalink)
Re: HNG...not!
Looking down the neck of the guitar, you can see the neck is curved on the low E side, but the high E side looks totally flat.
I knwo what a truss rod is, I've never adjusted one, though.
What do setups cost on average? Anybody know Guitar Center's prices?
Unread 11-02-2010, 02:22 PM   #8 (permalink)
AngryHatter's Avatar
Send a message via ICQ to AngryHatter
Re: HNG...not!
Adjust the bridge to lift the strings.
This assumes the relief is correct, frets level et cetera.
The knobs will be trickier. Are the shafts straight? Do the knobs fit?
Have the pots gotten loose and slipped?
Open the cavity and check?
AngryHatter is online now   Reply With Quote
Unread 11-02-2010, 02:24 PM   #9 (permalink)
Re: HNG...not!
If you go to GC for a setup you are flushing the money down the toilet.
A pro will run anywhere from $50 to $150 but be worth it.
I can give my guy a dead piece of wood and get a magical thing in return.
You can learn to do it yourself, but I would buy a book and take my time. Doing it incorrectly will frustrate you more.
Unread 11-02-2010, 02:25 PM   #10 (permalink)
ext1jdh's Avatar
Re: HNG...not!
There's a thread around here about how to do a setup. Check that out. TR is to adjust neck relief.
-- Doctor Who
Twitter
Facebook
Unread 11-02-2010, 05:09 PM   #11 (permalink)
Re: HNG...not!
Went to GC since I bought it there used online, and they set it up for free.
Can't complain about that! Now it's a happy NGD.
Unread 11-02-2010, 05:36 PM   #12 (permalink)
Re: HNG...not!
Here are some pix:
Unread 11-02-2010, 10:01 PM   #13 (permalink)
ext1jdh's Avatar
Re: HNG...not!
Nice. Beaut. The techs at GC can occasionally be useless, but sometimes toy get a good one. A good setup makes all the difference
-- Doctor Who
Twitter
Facebook
Unread 11-02-2010, 10:06 PM   #14 (permalink)
Re: HNG...not!
I think it still could use new strings, but I'll take care of that myself after I read up on how to do that with LP's.
I want to keep the action where it is, so I have to do some studying.
I have Dean Markley Blue Steel's on my Strat, and standard Gibson 10's on my Epi SE II.
I might go with some Ernie Ball's or Elixirs on the new LP.
It's also time for new strings on my acoustic...definitely going with D'addario's.
Unread 11-02-2010, 11:09 PM   #15 (permalink)
Kezia's Avatar
Re: HNG...not!
When I got my Black Beauty the action was way too high. A quick adjustment of the bridge, the action was just where I wanted it!
Kezia is offline   Reply With Quote
