Go Back   My Les Paul Forums > The Les Paul > Epiphone Les Pauls
Old 05-23-2008, 07:58 PM   #1 (permalink)
New Epi won't stay in tune
Got a new Ebony Standard Les Paul and Love it However after putting my Daddario XL's on it the G string will not stay tuned AT ALL. Not sure if original strings did same thing because I took them off immediatly. Any ideas? IS this common?
Gunnysmiles is offline   Reply With Quote
Old 05-23-2008, 08:22 PM   #2 (permalink)
MLP Trucker
dennistruckdriver's Avatar
Re: New Epi won't stay in tune
Most likely the nut. Make sure the string is not binding. Lube it with a drop of oil.
You also need to stretch the strings after you install them, and give them time to take their 'set'.
"I'm male, between the ages of 18 and 49 with a loud mouth and a gun; I AM the American Dream"-Anthony DiNozzo
"I've never used one, but I hear good things about them."
Old 05-23-2008, 08:34 PM   #3 (permalink)
They are "set" but I will try the oil trickl- what kind of oil should I use?
Old 05-23-2008, 08:49 PM   #4 (permalink)
Try a little graphite. Take a sharp pencil and clean up after you are done. This usually does the trick.
prsman is offline   Reply With Quote
Old 05-23-2008, 09:31 PM   #5 (permalink)
ZoomZilla's Avatar
I use graphite. Not sure on the oil thing. Maybe it will work, who knows. Just pick up a tube of graphite and you should be set. I use the Beefy Slinky's and I will tell you, they BARELY fit in the nut, but they never go out of tune.
ZoomZilla is online now   Reply With Quote
Old 05-23-2008, 10:23 PM   #6 (permalink)
Scooter2112's Avatar
It was either Greg or Roman that recommended Chapstick on another thread.
I tried it on both the bridge and nut last time I restrung and it works great. I had problems with the G and B string not staying in tune for very long, and a little buzzing at the bridge and that cleared it up. I have to retune very seldom now.
Oil might work short term, but I think you'd be better off using something that has a pasty consistency, rather than liquid. Chapstick, vaseline, silicone grease, teflon grease.....that sort of thing.
"Have you hugged your Custom today?"
the CS Customs make the Standards sound like a plastic banjo with a live cat stapled to the back! - Hemply, 2009
Scooter2112 is offline   Reply With Quote
Old 05-23-2008, 10:28 PM   #7 (permalink)
-Ninja-'s Avatar
I just made a post about this myself. I wanted to know what these guys thought about it. I think it is normal, but I think it can be fixed by filing the nut a little in a certain spot. I haven't had the time to try it yet, but I am pretty sure it will work. I am definitely going to do it this weekend so I will keep you posted.
If you want to read through my post here it is.
http://www.mylespaul.com/forums/epiphone-les-pauls/10636-epi-standard-g-string.html
-Ninja- is offline   Reply With Quote
Old 05-23-2008, 10:29 PM   #8 (permalink)
diceman's Avatar
I've heard nothing but good things about "Big Bends Nut Sauce" - but haven't used it yet... I have tried Graphite - which works well enough for me. My #1 and #2 have well cut bone nuts, and I haven't had any issues with mine that I've had to resolve as of yet, though...
Old 05-23-2008, 10:30 PM   #9 (permalink)
Lester B. Flat's Avatar
Send a message via AIM to Lester B. Flat
I use graphite but there is a product called Nut Sauce that is supposed to work great.
Lester B. Flat is offline   Reply With Quote
Old 05-23-2008, 10:40 PM   #10 (permalink)
diceman's Avatar
I was reading your mind Lester...
Old 05-23-2008, 10:41 PM   #11 (permalink)
Weldaar's Avatar
Don't spend a lot of your hard earned money on products you don't need. Get yourself a #2 pencil and color the nut slot with it. Graphite is what a pencil lead actually is.
Make sure you lock your strings when you install them. Then when you get some extra cash, get rid of those crappy tuners Gibson and Epiphone use on their guitars.
This just my opinion, I could be wrong.
Remember this simple truth: Satan will always seek to drive you away from the cross, but the Holy Spirit will always draw you back to the cross. Trust in Christ.
Weldaar is offline   Reply With Quote
Old 05-23-2008, 11:18 PM   #12 (permalink)
-Ninja-'s Avatar
I thought the Grover tuners that came stock on the Epi's were supposed to be good...
No???
Old 05-23-2008, 11:21 PM   #13 (permalink)
diceman's Avatar
No???
They're not terrible... Not top of the line, either. Overall they're pretty decent, and at least as high quality as the rest of the Epi hardware. The upgrade wouldn't hurt, though. I haven't had any problems with mine - and if it ain't broke, I don't fix it!
Old 05-23-2008, 11:32 PM   #14 (permalink)
Bucknasty's Avatar
Send a message via Skype™ to Bucknasty
What brand of tunners did you put on yours diceman?
Bucknasty is offline   Reply With Quote
Old 05-23-2008, 11:39 PM   #15 (permalink)
diceman's Avatar
Stock Grovers for me!
Old 05-24-2008, 05:09 AM   #16 (permalink)
IME Grovers are great tuners, worst thing that happens is the adjustment screw loosens off over time and then you just snug it up a bit. Even cheaper tuners (Ping, for example) seem to work pretty well...any tuning problem I've ever had was down to the nut. That "almost in tune, then pulls sharp" syndrome just screams nut issue. JMO
Eminor is offline   Reply With Quote
Old 05-24-2008, 05:26 AM   #17 (permalink)
Nils's Avatar
Send a message via MSN to Nils
all my electrics have had G string trouble, even my crappy strat
The most tuning problems occurred to me when the guitars were new so now they stay in tune much longer
I put some graphite in the nut of my Epi LP and it worked out fine, even though I didn't have much trouble with it, but now I kind of don't have the G string problem anymore
and I think the stock grovers are good enough
2007 Epiphone Les Paul Std HCS (Irongear Hot Slag pickups + Spague Orange Drops + new wiring)
2006 J&D LS-1 CS (Epiphone pickups + Sprague Orange Drops)
2009 Fender CD-60CE BLK
2005 Behringer Strat Starter wreck (in parts, refinishing it some day) (u/s)
Old cracked nylon acoustic (u/s)
Fame T64RS Tube
Behringer GM108
Boss OS-2
Nils is offline   Reply With Quote
Old 05-24-2008, 07:53 AM   #18 (permalink)
Weldaar's Avatar
I could be wrong on the tuners. I know the ones on my Epi and LPGT weren't that good. The best way to tell is when the strings are off, see how much slop is in the shaft that holds the string. If it has play in it, I would make a change.
However graphite in the nut is always a must. Remember, #2 pencil.
Old 05-24-2008, 09:43 AM   #19 (permalink)
No???
Yeah my Epi has nice Grover Tuners that have no slack in them at all.
Old 05-24-2008, 09:45 AM   #20 (permalink)
Thanks for all your help- tried the pencil thing and I'll let you know how it goes!
Old 05-24-2008, 09:58 AM   #21 (permalink)
Weldaar's Avatar
No slop in the shaft is good. They must have improved the Epi's a lot in 4 years. My 04 Epi had some real flimsy ones. The graphite in the nut should help you out.
BTW, I have Grovers in all of my guitars. I have the Deluxe ones.
Old 05-24-2008, 10:06 AM   #22 (permalink)
MLP Trucker
I got this:
at Harbor Freight. Works fine. You can use a drop of just about any kind of oil. I have even used a drop of fresh, clean motor oil. Drip it right on the string at the nut, let it soak in around the string, then wipe off any excess left on the nut.
Old 05-24-2008, 10:11 AM   #23 (permalink)
MLP Trucker
Originally Posted by Scooter2112 View Post
Chapstick,.....that sort of thing.
Not a bad idea......Keeps your nut from getting windburned at the same time! I hate windburned nuts!
Old 05-24-2008, 12:37 PM   #24 (permalink)
Yeah....well when all your nut sauce dries up, windchapping is soon to follow.
"Don't allow your nuts to get chapped and windburned....protect them from all sunlight" - Public Service Announcement, brought to you by the fine folks at Hanes Briefs.
Old 05-24-2008, 12:38 PM   #25 (permalink)
diceman's Avatar
You guys are killing me!
Old 05-24-2008, 01:13 PM   #26 (permalink)
Weldaar's Avatar
Old 05-24-2008, 01:25 PM   #27 (permalink)
MLP Trucker
I hate dried up nut sauce too.
Old 05-24-2008, 01:43 PM   #28 (permalink)
Yeah, tuners are number three on the list behind sticky nuts and wobbling bridges. The tuner manufacturers get both blamed and do a whopping business off poorly cut or lubricated nuts!
Old 05-24-2008, 01:47 PM   #29 (permalink)
Weldaar's Avatar
Exactly. Always good to keep your nuts lubricated.
Old 05-24-2008, 02:05 PM   #30 (permalink)
My wife always yells at me for that.
But hey.....they're MY nuts, right?
Does your Historic stay in tune ?? BOBBO Historics & Reissues 51 09-03-2008 10:16 PM
R9 - any bad years to stay away from? RCCola Historics & Reissues 35 05-27-2008 04:40 PM
switch epi tune-0-matic for gibson tune-0-matic? Paul My Other Guitars 0 01-23-2008 01:09 AM
Boycott China, Boycott Korea. Stay away from Guitar Center mojofilter The Backstage 60 01-11-2008 12:38 PM
strings don't stay in tune? taypeng Other Les Pauls 3 01-09-2008 05:47 AM
