Unread 08-29-2010, 12:56 PM   #1 (permalink)
megatron's Avatar
Planning a refinish....maybe tobacco sunburst!
I was never a fan of the color of my Epi Standard Birdseye maple(wine red). I've always been in love with tobacco and cherry sunbursts. I am seriously considering a refinish. Where would I go to get the stain/varnish what have you? Is this something I need to order somewhere? What kinds of tools do you recommend for taking off the original color? ie sandpaper grit? What kinds of worries do I need to have about the binding? This would be a complete refinish....not just the top. If I do a cherry burst, the back and neck can stay, but not for a tobacco. Basically just kind of brief me on the types of prep and stuff I need to do. I'm a novice at this type of work.
Don't touch that metal railing........ZAP!!!!........Yep, that one.
-2005 Epi Standard Birdseye Maple top - Wine Red
-2004 Gibson SG Special - Worn Cherry
-Line 6 Spider III 150 Watt combo
-Crate GT212 120 Watt combo
-GOD's Grace in my hands too! haha
megatron is offline   Reply With Quote
Unread 08-29-2010, 01:36 PM   #2 (permalink)
Re: Planning a refinish....maybe tobacco sunburst!
Pretty much any type of stripper that will put a dent in the poly will also ruin the binding. Your pretty much limited to sanding. Next problem is the figured top of your guitar is a very thin veneer. If the color was applied to the veneer you may end up sanding right through it to get to veneer's natural color. If it's clear, color then more clear then it's possible to save the veneer, but if you are inexperienced you will likely end up going through the veneer at some point. Under the veneer you may find a decent plain top to work with or a hideous mess of many pieces glued together.
Epi Joe Bonamassa Signature Goldtop
Epi Les Paul Standard 1959 Faded Iced Tea
2009 Epi Les Paul Standard Plus Top Heritage Cherry Sunburst
2008 Epi Les Paul Custom Plus Vintage Sunburst
2009 Fender MIM Strat Brown Sunburst Rosewood Neck
Traynor Darkhorse 15H/Darkhorse 112 Cab
Vox VT30
Fulltone Clyde Deluxe Wah
Fulltone Robin Trower Overdrive
MXR EVH Phase 90
t.c. electronics ND-1 Nova Delay
t.c. electronics Polytune
dave-m is online now   Reply With Quote
Unread 08-29-2010, 01:49 PM   #3 (permalink)
megatron's Avatar
I really like the flame maple tops too. I know you can buy a flame maple veneer....any places to go or ideas how much an unfinished veneer will cost? This might be a good option if the original veneer cannot be saved.
Unread 08-29-2010, 02:42 PM   #4 (permalink)
ptate's Avatar
Just trade it for another......Believe me you can screw it up big time unless you are careful.
Some of the Epi's were veneered backs too, so you can bugger that side as well and unless you know what you're doing spraying a burst, you can make it look awful. As an example, I have heard of a guy using flat red colour in his....!!!!
Stripper is chemical and can react with a lot of things. Sanding is hard work and takes a long time if you do it carefully. The paint on the top will likely have bled into the veneer anyway when it was applied.
Once you've refinned it, it will lose a lot of value on the market and will only retain some if the finsh is left amost perfect.
In terms of the finish, it will be a thick, hard poly which means you will have to sand the wood and binding too, unless you plan on repainting it with the same (not really a home technique). If you just plan to do the top, have you thought about how the edges will react/look when it's sprayed? When it's covered in a nice orange peel effect, do you know how to sand it back, buff and polish? And so on......
Back to point 1; either live with it or sell and buy another.......
Peace.
- www.facebook.com/MississippiRelic -
ptate is offline   Reply With Quote
Unread 08-29-2010, 04:52 PM   #5 (permalink)
megatron's Avatar
Peace.
I have done a fair amount of woodworking before, but not on a guitar. I just didn't know if it would be worth all the hassle refinning it. I really like the bursts, and actually have my Epi out on the market right now. Hoping to snag a cherry sunburst or tabacco sunburst custom. It was my first idea, then someone suggested refinning it. I'll probably just sell.
Unread 08-29-2010, 06:55 PM   #6 (permalink)
Phildog's Avatar
Peace.
+1
I refinished my Ebony. The plain top underneath was a very thin veneer. Mine came out pretty good, but I'd never try it again as I probably wouldn't be as lucky. That's a pretty LP, so there's probably some good trades out there for you. Or, you can sell it outright and get the one you really want.
2006 Epiphone Les Paul Standard
2005 Epiphone Les Paul Classic
2008 Epiphone G400 1966 Reissue
Eric Johnson Sunburst Strat
Jimi Hendrix Monterey Pop Strat
Fender Telecaster 50's Reissue
Univox Hi Flier Phase II
Premier 4 String Bass
SKB Stage 5 LOADED!!!
Fender Hot Rod Deluxe
Phildog is offline   Reply With Quote
