Unread 08-26-2010, 04:36 AM   #1 (permalink)
When I got my guitar set up I told them to tune it to Eb can I still tune standard?
I took my guitar in to get set up today and they asked what I tuned to. I told them Eb.
I will occasionally switch from Eb to E. If I tune it up to E, and then tune back down to Eb will it mess up the intonation or anything because of the tension or will it just not be perfect in E but still be perfect in Eb???
drad is offline   Reply With Quote
Unread 08-26-2010, 04:40 AM   #2 (permalink)
Stu
Stu's Avatar
Re: When I got my guitar set up I told them to tune it to Eb can I still tune standar
I do all the time. Haven't had a problem, yet.
Stu is offline   Reply With Quote
Unread 08-26-2010, 06:00 AM   #3 (permalink)
Bartlett Retrospec Member
jay1williams's Avatar
it shouldn't be a big deal on an LP - if it was a strat or floyd rose, you could have issues....
jay1williams is offline   Reply With Quote
Unread 08-26-2010, 06:52 AM   #4 (permalink)
lp_junkie's Avatar
It will be fine, I switch between the two all the time.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
Unread 08-26-2010, 04:09 PM   #5 (permalink)
Diocletian's Avatar
You could probably go from E to C and beyond with no issues other than slightly loose feeling strings.
www.myspace.com/marchofalaric
Diocletian is offline   Reply With Quote
Unread 08-27-2010, 12:50 PM   #6 (permalink)
Yes you can do both Eb and E tunings without worry. Good Lawdy, I sometimes go for open G and D and dropped D all on the same guitar in one night. Ain't had no intonation issues yet when going back to standard.
56Bluesboy is offline   Reply With Quote
Unread 08-27-2010, 01:01 PM   #7 (permalink)
morats8up's Avatar
Iv'e never had a problem on any of my LP's.
Edwards E-LP-98LTC
04 Epi Elitist Studio antique white
05 Epi ebony custom
84 San Dimas Charvel
70's Suzuki wt-150 12 string
  • 69 Princeton reverb
    Vox AC4TV
morats8up is offline   Reply With Quote
Unread 08-27-2010, 01:09 PM   #8 (permalink)
River's Avatar
C will be a little bit more than "slightly" loose. The same gauge strings will be flopping like shoelaces. You'll need 12s or 13s.
Unread 08-27-2010, 01:46 PM   #9 (permalink)
Diocletian's Avatar
I had my SG tuned to C with 10s (think I wanted to play a Carcass song) and it was just, like I said, slightly loose. I wouldn't have played it in anger like that, nor was I suggesting the guy should, I was just making the point that going from E to C is possible, so E to Eb is a piece of cake.
Unread 08-29-2010, 12:35 AM   #10 (permalink)
shouldn't be a problem. les pauls deal with altered tunings like pros.
rocknorroll is offline   Reply With Quote
Unread 08-29-2010, 12:54 AM   #11 (permalink)
formula73's Avatar
It depends on how demanding you are on your setup. If you go for whisper-low action at standard, you'll likely have to make an adjustment or two on the action and truss rod to try to eliminate your newfound buzz.
I find it difficult to accept that LPs deal with string tension changes like a champ...they're just guitars with truss rods in temperature/humidity sensitive mahogany necks.
1973 Les Paul Custom
1974 Les Paul Signature
1987 Burny RLC RR Duncan Custom Custom/59
Metaltronix M-1000 FJA mods/Killer Kab
Carvin V3
Hamers, Deans, Ibanezes, KxK, Kaufman, Grecos...
I even named my kid Les Paul.
formula73 is offline   Reply With Quote
Unread 08-29-2010, 10:05 AM   #12 (permalink)
Tenacious Texan
Nicky's Avatar
You can get a Robot SG for $750 new at Guitar Center these days.
Originally Posted by Nicky View Post
I told my daughter that MLP "is the finest association of like-minded guitar and music lovers from all over the world." ............She believed me!
Nicky is offline   Reply With Quote
Unread 08-29-2010, 10:43 AM   #13 (permalink)
Diocletian's Avatar
Exactly. Unless those Robots also adjust the truss rod, there's the proof it can be done easy enough.
(If they DO adjust the tross rod, well, that's amazing!)
Unread 08-29-2010, 11:04 AM   #14 (permalink)
ElectricGuitarist33's Avatar
It'd be funny if it did adjust the truss rod, and one day went all Hal snapping it's own neck. Buddy's playing Air Supply or something.
ElectricGuitarist33 is offline   Reply With Quote
Unread 08-29-2010, 11:00 PM   #15 (permalink)
Tenacious Texan
Nicky's Avatar
Dave to HAL the Robot Guitar: "OK, HAL, drop tune to Eb, and when we re-tune to standard, please adjust the truss rod."
HAL: "I'm sorry Dave, I'm afraid I can't do that."
Unread 08-30-2010, 03:45 AM   #16 (permalink)
Diocletian's Avatar
Haha, love it guys!
Unread 09-03-2010, 09:19 PM   #17 (permalink)
Lester's Avatar
HAL: "Dave, what are you doing Dave? ...Dave, put down that allen wrench!".
Lester is offline   Reply With Quote
