MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Unread 08-16-2010, 06:16 PM   #1 (permalink)
Slackerprince's Avatar
Stripped Truss Rod Nut. What Now?
So, I just discovered that the truss rod nut is stripped in my Epi Les Paul Standard, Plus Top.
I googled and saw the Stew-Mac Rescue kit and read a few other articles.
Has anyone else dealt with this?
Any experienced opinions?
The neck is straight now, and it plays nice, but if I ever wanted to sell/trade it, it would probably be a problem.
Thanks!!
S
And I think my spaceship knows which way to go
Slackerprince is offline   Reply With Quote
Advertisement
Unread 08-16-2010, 06:23 PM   #2 (permalink)
diceman's Avatar
Re: Stripped Truss Rod Nut. What Now?
Take it to a good luthier ASAP... I would suggest.
If that truss rod can't be "rescued" - the guitar is destined for the garbage, as I can't imagine anyone being willing to pull the fretboard and replace the rod for anything less than the value of the guitar.
Unread 08-16-2010, 08:19 PM   #3 (permalink)
I contacted my tech, and he seems to think he can handle it.
Thanks.
S
Unread 08-16-2010, 09:25 PM   #4 (permalink)
lp_junkie's Avatar
Rule #1- stop messing with your guitar if you don't know what you are doing.
Rule #2- remember Rule #1 or be prepared to spend some money.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
Unread 08-16-2010, 11:07 PM   #5 (permalink)
I didn't strip it.
I took off the truss rod cover and saw that it was stripped.
I never said that I "messed" with it.
I don't appreciate your condescending reply.
S.
Unread 08-16-2010, 11:43 PM   #6 (permalink)
omicron's Avatar
Originally Posted by Slackerprince View Post
I didn't strip it.
S.
In my experience, sometimes a nut can look stripped when it actually still holds an allen wrench quite well.
Have you actually tried turning the truss rod (or just inserting an allen key to see if it still can turn)?
omicron is offline   Reply With Quote
Unread 08-16-2010, 11:54 PM   #7 (permalink)
lp_junkie's Avatar
Slacker-
Again humor/sarcasm is hard to impart over the net..............
They make a tapered allen wrench for getting "stripped" allen bolts out, it may be that this is more what you need to remove the damaged part and replace it.
Shane
Unread 08-16-2010, 11:59 PM   #8 (permalink)
diceman's Avatar
Aaaaaaaaah, the portion of the nut where your allen wrench is stripped, and not the threads on the nut?
Not as big a deal. I follow.
