Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Unread 04-08-2010, 07:23 AM   #1 (permalink)
JLH
JLH's Avatar
pickup spring specs help
Can someone help me find stiffer springs for installing pickups/ humbuckers in a Les Paul, I need to know (stewmac is no help) where to buy and what the size and dia. of the springs are for les paul pickups as when I install pickups with no covers they wobble, I believe a stiffer spring will fix this.
JLH is offline   Reply With Quote
Unread 04-08-2010, 08:33 AM   #2 (permalink)
Re: pickup spring specs help
I dont have any I can measure but you might be able to get some from McMaster-Carr. It looks like there were 6 or 7 options for wire size.
You will have to buy a long spring and cut it down. Good luck!
neil_004 is offline   Reply With Quote
Unread 04-08-2010, 04:22 PM   #3 (permalink)
Xavier_32's Avatar
Don't buy new ones, just unmount your pickups, disassemble the mounting rig, and stretch out your springs by hand. I did this and my wobble was gone. Just pull on them with a tiny little bit of force, holding on to the very edges of the springs. Don't pull too hard, just hard enough to stretch them, and hold the stretch there for a few seconds. Repeat 2-3 times.
Bassist for Cab 20 and Future Shock
Originally Posted by blakem (in regards to Norlins) View Post
Mines done got sausage too! Maple, Pancakes and sausage!
From now on, mini humbuckers shall be known as sausages.
Xavier_32 is offline   Reply With Quote
Unread 04-08-2010, 04:49 PM   #4 (permalink)
xsouldriverx's Avatar
longer pup springs usually help, no need for a stiffer one. (technically longer will be stiffer when its compressed) you can also try X's suggestion before buying anything too
Helvick Guitars
set-ups, tuneups, repairs & custom work
helvguitars@gmail.com
xsouldriverx is offline   Reply With Quote
