Old 03-29-2008, 02:24 PM   #1 (permalink)
spin32's Avatar
Tuneomatic Low E string saddle screw broke
Hi i was fixing my guitar intonation and suddenly the top of the saddle screw broke How can I Fix this?
will i have to replace all the bridge? or can i replace just the saddle?
Please help
Pictures added
spin32 is offline   Reply With Quote
Old 03-29-2008, 02:28 PM   #2 (permalink)
The Velvet Hammer
b-squared's Avatar
Re: Tuneomatic Low E string saddle screw broke
Dude--that sucks!
It can probably be drilled out with no problems by a good tech. He/She will then put a new screw in for ya.
BB
I use:
and Jonesy's Caps, too!
b-squared is online now   Reply With Quote
Old 03-29-2008, 02:35 PM   #3 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
Please help
Pictures added
Find a used bridge on ebay. A parts bridge, if you will. There is a little C clip that holds each screw in place, it is a pain in the butt to get out, but can be done with a small dental pick.
once you get it out, install the new screw. There is no need to drill it out.
I know of no place where you can get replacement screws, so I would go the "parts bridge" route.
Roman
Roman Rist is offline   Reply With Quote
Old 03-29-2008, 02:47 PM   #4 (permalink)
spin32's Avatar
Thanks Guys!
Roman How will i get the broken screw exactly?
and i found this is it any good?
Nashville Tune-o-matic Saddle Screws at Stewart-MacDonald
Old 03-29-2008, 02:48 PM   #5 (permalink)
WildeStarr's Avatar
Please help
Pictures added
Looks like the saddle was all the way back and you turned the screw to far braking off the head. I have seen this happen before.
WildeStarr is offline   Reply With Quote
Old 03-29-2008, 02:52 PM   #6 (permalink)
spin32's Avatar
I hate myself right now..
So how can i fix intonation if the saddle is to the back and the tuner shows me E sharp when i press the 12 fret?
Old 03-29-2008, 03:40 PM   #7 (permalink)
The Velvet Hammer
b-squared's Avatar
You have to reverse the saddle--it'll get you a bit more play.
BB
I use:
Old 03-29-2008, 03:50 PM   #8 (permalink)
spin32's Avatar
what do you mean in reverse the saddle?
thanks
Old 03-29-2008, 03:56 PM   #9 (permalink)
The Velvet Hammer
b-squared's Avatar
You have to carefully removed the retaining wire, unscrew it until you can take the screw out, then flip the saddle to face the other way. It'll give you more play in that direction.
BB
I use:
Old 03-29-2008, 05:24 PM   #10 (permalink)
Roman Rist's Avatar
Thanks Guys!
Hmmm, different clips than than older ones I have worked on. However It is great to find out that replacement parts are being sold!
How I would do it without drilling is 1st get the clip off.
The only thing that should have threads is the saddle itself. there should be no threads on the body of the bridge.
The screw is designed to just rotate in the bridge, As you turn the screw, the threads move the saddle back or forth.
If you have some needle nose pliers, once you get the clip off you could grab the shaft of the screw that is left and turn it.
I could tell you better with some better pictures
Old 03-30-2008, 04:47 PM   #11 (permalink)
spin32's Avatar
Hi roman thanks for the reply
I've added some more pictures tell me what u think
Thank You
BTW How do i remove the saddle clip without harming it? where should i bend its legs toward?
Old 03-30-2008, 05:10 PM   #12 (permalink)
Roman Rist's Avatar
Look at your other saddles and see if you have a "C" clip or the wire kind.
From the pictures, the saddle will have to come forward to get to the clip.
see if you can turn the screw body with needle nose pliers.
Old 03-30-2008, 05:14 PM   #13 (permalink)
The Velvet Hammer
b-squared's Avatar
With the string tension relieved you might be able to slide the whole thing (saddle and screw) towards the headstock, then use a set of needle-nose pliers to unscrew it.
The retaining clip must be GENTLY removed--I use a set of needle-nose, and very carefully ease out the ends. There's a little bit of spring tension on it.
BB
I use:
Old 03-30-2008, 05:17 PM   #14 (permalink)
spin32's Avatar
Ok guys thanks ill Post Pictures when the job is done Hope to get it right
Old 03-30-2008, 05:19 PM   #15 (permalink)
Roman Rist's Avatar
One piece of advice. get a clean uncluttered work area and use a sheet or large towel...............that stuff can FLY.
Take the bridge off of the guitar to work on it.
Old 03-30-2008, 05:23 PM   #16 (permalink)
The Velvet Hammer
b-squared's Avatar
What he said! I almost lost my retaining wire, and I was on my kitchen table!
BB
I use:
Old 03-30-2008, 06:03 PM   #17 (permalink)
spin32's Avatar
Ok thanks for the tip will do
Old 03-31-2008, 08:30 AM   #18 (permalink)
Robster's Avatar
That's a BIG +1!!!
R
Just between us,
I think it's time for us to recognize
The differences we sometimes fear to show.
Just between us,
I think it's time for us to realize
The spaces in between
Leave room for you and I to grow
{Neil Peart}
Robster is offline   Reply With Quote
Screw sizes for Elite LP ffata Epiphone Les Pauls 1 05-13-2008 11:37 AM
Anyone else broke? lol VictorLazarus The Backstage 36 04-12-2008 12:21 PM
lol i broke my new lp BlaZ1n Gibson Les Pauls 3 03-05-2008 08:48 PM
Pickguard Screw Eddie The Custom Shop 5 01-24-2008 03:33 AM
String change and saddle position? LPSWR Gibson Les Pauls 6 12-06-2007 11:54 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
