Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Unread 12-04-2009, 05:17 PM   #1 (permalink)
zeppelinled's Avatar
Question fitting humbucker cover. how to?
hi, i'm planning on fitting a humbucker cover onto the neck p/up of my les paul classic. i'm reasonably handy with the soldering iron. any tips or advice as to how to go about this?
zeppelinled is offline   Reply With Quote
Unread 12-04-2009, 05:19 PM   #2 (permalink)
captain tightpants's Avatar
Location: In the pit rubbing the lotion on it's skin. It doesn't like the hose.
Re: fitting humbucker cover. how to?
Just a little patience, it takes a bit of heat to get the baseplate and the cover heated up. I use a 40watt iron minimum. Not much to it, otherwise.
Unread 12-04-2009, 05:21 PM   #3 (permalink)
so just slip the cover on the p/up and solder a small seam either side? i assume. anything to watch out for so that damage doesn't occur? thanks for your help.
Unread 12-04-2009, 05:29 PM   #4 (permalink)
You might have to tear a bit of tape away from the edge of the baseplate. Just be careful when slipping the cover on, other than that, I think you've got it covered!
What pickups do you have, and where are you getting covers?
Unread 12-04-2009, 05:36 PM   #5 (permalink)
the stock p/ups in the les paul classic which are the 500t and whatever the neck one is. i'm using the cover from my epi les paul standard that i removed.
Unread 12-04-2009, 05:38 PM   #6 (permalink)
Outta work, just make sure the holes line up, should be good. Only other thing I'd say is those Epi covers are a little on the thick side, they will need some heat, but it'll work fine. Good luck, post pics of the results!!
Unread 12-04-2009, 05:53 PM   #7 (permalink)
will do. thanks!
