Old 11-08-2009, 06:55 AM   #1 (permalink)
monami's Avatar
wobbly strat trem arms?
do more expensive strats suffer such a wobbly arm as the budget strat copies i have? i'm talking of the screw in arms. the problem is the little bit of wobble there is just before the bridge actually moves.
http://creation.com/refuting-evolution-index
'We the undersigned petition the Prime Minister to Reverse the
UK Governments decision to classify Israeli Goods produced in
Judea & Samaria (West Bank) as made in Palestine, a country
that does not exist.'
http://www.icejuk.org/article.php?id=6449
monami is offline   Reply With Quote
Old 11-08-2009, 07:01 AM   #2 (permalink)
"Mr. Salesman"
JM Vasek's Avatar
Send a message via Skype™ to JM Vasek
Re: wobbly strat trem arms?
Neither of mine have that problem. One is a MIM Jimmie Vaughan and the other has a Warmoth replacement bridge.
I would only assume that anything higher in quality than mine would not have that issue either.
-JM
http://www.formspring.me/JMVasek
Ask away.
JM Vasek is online now   Reply With Quote
Old 11-08-2009, 07:28 AM   #3 (permalink)
No longer cares....
dennistruckdriver's Avatar
try wrapping the threads in teflon tape, or try a trem arm from a good guitar, as the threads may have been made a bit more precisely
Proud non-user of pickups made by a psycho!
Old 11-08-2009, 08:54 AM   #4 (permalink)
EatBacon's Avatar
Wow, somebody that puts the arm in their strat trem. The problem you have is just a fact of life with a strat trem. On most of them the block is made of cheap cast medal and will loosen up quick if you use it. The arm is of a much harder material than the block and it tears them up. Some come with a little spring in the trem hole to stabilize the arm, it's not much help other tan controling arm swing. I will suggest something so take it or not. Look at the back of you trem block if there is a hole on the back then this might work for you. I did it with my strat copy many years ago before I gave up on strat trems. I broke off a piece of toothpick and stuck it in there from the bottom. Screwed in the arm a nice tight fit. Afterwards I just use another toothpick from the back and pushed it out. Needless to say I had a ton toothpicks in my case. Just a thought, I would be wary to try without the hole in the back as you my find it difficult to remove the TP. To be honest I drilled the hole in mine. Good luck.
EatBacon is offline   Reply With Quote
Old 11-08-2009, 09:07 AM   #5 (permalink)
monami's Avatar
i have had about 3 trem arms break in different units... most of low quality.
Old 11-08-2009, 05:49 PM   #6 (permalink)
I took the springs out of mine and blocked it up with a bit of hardwood.
Stupid wobble bar.
Laservampire is online now   Reply With Quote
Old 11-09-2009, 10:20 AM   #7 (permalink)
monami's Avatar
just wood. i used vintage mahogany to block one of mine!
Un-trem a Strat? SpinWheelz Fender 34 08-24-2009 09:21 AM
Amer Deluxe Strat Trem ghost driver Fender 6 07-29-2009 11:41 PM
2 springs for my strat trem.. 5F6-A Fender 32 02-28-2009 08:56 AM
LF: Vintage Strat Trem Arm & Springs Pooker Member Classifieds 5 01-23-2009 08:16 PM
WTT/WTB: Strat Trem Cover randelli Member Classifieds 1 10-02-2008 11:12 AM
Powered by vBulletin® Version 3.8.4
