Old 10-30-2009, 07:47 AM   #1 (permalink)
help! logo and binding ambering
searched over here but just can't find a solution...
i want to yellow/amber my custom binding and logo coz they are too white
i like some works i saw from nicolasrivera, but i think the ageing process of the laquer over binding and logo are a secret as they are not explained unlike many other things.
anyone can help me?
is there a dye to use? stain that penetrates the lacquer?
EBONY MAFIA member!
maicolp is online now   Reply With Quote
Old 10-30-2009, 07:53 AM   #2 (permalink)
Knarbens's Avatar
Re: help! logo and binding ambering
As far as I know, you gotta do it befor finishing a guitar. The first clear coat is a amber stained, that will turn the cream binding more into a yellow. Same for the headstock! Someone please correct me if I'm mistaken! There is a way to do it on a guitar later because I ones saw it on the forum a wile back, but the result is not the best and it's ot easy ...
1992 Orville Les Paul Standard Plaintop HCS
3D 1959 Les Paul
Knarbens is offline   Reply With Quote
Old 10-30-2009, 07:58 AM   #3 (permalink)
can you remember the title of the post?
EBONY MAFIA member!
Old 10-30-2009, 08:29 AM   #4 (permalink)
monsterwalley's Avatar
If it were me, I would spray a thin amber toner over the guitar and then a couple coats of over thinned coats of clear over that. That way you don't wear through the amber coat and over thinned to cut down on the orange peel, also to melt everthing together.
Just my opinion though.
monsterwalley is offline   Reply With Quote
Old 10-30-2009, 08:43 AM   #5 (permalink)
i was looking into something easier...
what about leather dye or show polish? will they stain thru lacqer?
EBONY MAFIA member!
Old 10-30-2009, 02:15 PM   #6 (permalink)
Knarbens's Avatar
I searched for it and finally found it for you man!
Hope that helps! Aging the Binding???
3D 1959 Les Paul
Old 10-30-2009, 07:57 PM   #7 (permalink)
roadhog96's Avatar
Wonder if Frenches Mustard would yellow the clear coat on top of the Binding. Seems like it stains everything it get on. This way you wouldn't have to re-spray the guitar and it's non toxic.
roadhog96 is offline   Reply With Quote
Old 10-30-2009, 08:21 PM   #8 (permalink)
and the guitar then smells like hotdogs from now on, its a win-win situation
09 Gibson Traditional
07 Gibson BFG
05 Epiphone Standard
03 Epiphone ZW
Blackheart BH100 'Hothead'
Line 6 HD75
Bubbletonic is offline   Reply With Quote
Old 11-01-2009, 09:20 PM   #9 (permalink)
DGNRepair's Avatar
You might want to give the shoe polish a try. If I remember right thats what was used to age that guitar. Nitro tends to soak in whatever is on it if it is left there too long. I would experiment with a spot, the treble side of the neck binding for instance, you won't need much and it is an on off type of deal. Don't leave it on too long or you will discolor the binding too much. This might not be the result you are after though. If you are looking for a slight yellowing of the finish than you might need to take monsterwalley's advice and shoot super thinned coats of tinted then clear finish.
Its not a replica, its just under the influence......
DGNRepair is offline   Reply With Quote
Logo MRJ Luthier's Corner 4 09-05-2009 02:58 AM
What should I use as my Logo? Epison The Backstage 28 08-12-2009 06:57 PM
pre-china logo? leftylover Epiphone Les Pauls 8 08-02-2009 08:07 PM
Binding on the body or no Binding? SoundwaveLP Epiphone Les Pauls 25 03-13-2009 03:25 PM
Need Inlay or a LoGo ??? FLICKOFLASH The Custom Shop 11 10-25-2007 02:05 PM
