#1 (permalink) |
Home Made Knob Remover
Hey Guys,
I am about to tear into my guitar and replace all the electronics, in preparation i have been doing alot of research into knob removal, well after seeing what is available, and the ridiculous prices they wanted , i decided to build my own. What you see below, is 3 dollars in parts i figure , most of it i had due to my contracting business, and 15 minutes of my time.. All of the required items can be had from the local Home Depot. I am also quite sure this tool could be used to remove the bushings in our guitars.. Eric ![]() ![]() ![]()
Guitars: -Epiphone Les Paul Custom, 07 -Epiphone Zakk Wylde Bullseye, 08 -Epiphone Zakk Wylde Buzzsaw, 05 Amp: -VOX - AD100VT-XL Pedals: -Boss TU-2 -MXR M108 Equipment Wishlist: -Epiphone Zakk Wylde Camo -Gibson Zakk Wylde ZV -Marshall 2003ZW Half Stack |
| The Following User Says Thank You to inxs996 For This Useful Post: |
#2 (permalink) |
Grumpy Old Luthier
![]() Join Date: Apr 2007
Re: Home Made Knob Remover
Looks cool.
I use two flat blade screwdrivers.
Cool guitars, extreme repairs and brutal honesty. www.bcrmusic.com www.grumpyoldmenband.com http://www.youtube.com/user/unkagreg www.ristguitars.com
#4 (permalink) |
Thanks, i was kinda worried about screwing up the finish , so no more worries...i am planning this project like a i am sending a man to the moon, will be totally prepared when all the parts are in...
#7 (permalink) |
I wrap a cloth aound the underside of the knob, pull it up and twist so the knob is tightly wrapped, then pull gently.
That way you pull evenly all aound the knob. |
#8 (permalink) |
Sure those methods will work, but a more control method that is employed with the use of the tool i made, will be much more forgiving on your knobs and pots,,
With the turning of the Wingnut, removal is more precise and controlled, and the knob rises in a completely level manner, no see-sawing of the knob,, BTW, the tools used to build the tool, was a pair of Pliers, Flat Head Screwdriver and a Dremel tool,, My guitar is worth a 3 dollar investment,, But do what works for you..
#10 (permalink) |
Thats really cool but all you need to remove nobs is a platic bag....
Tuck the handles of a platic groc. store bag under the knobs, and pul up. No risk of scratching anything. But if for some reason something is wrong and you need some addition force, I bet there is no knob that device won't remove!
2007 Les Paul Custom 200x Fender Mary Kaye Relic V-Neck See thru Blond 2008 Fender Custom Classic V-Neck Daphne Blue 2003 MIM Strat Faded Green Metalic A couple of Alvarez Acoustics AMPS: VOX AD60VTX, Micro Cube |
#12 (permalink) |
Excellent idea and a fine invention!!
I recently had to do this with a G&L Legacy (granted it's ALL pickguard), but I used 2 Fender Medium picks from opposing directions. Slide the leading edge under the knob, grab the picks as close to the knob as possible, and pry upward.
1980 Gibson Les Paul Custom - Heritage Cherry Sunburst (stock) 2004 Epiphone Les Paul Standard Plus - Honeyburst Flame-Top (SD Phatcat P-90 / Gibson '57 Classic Plus Pups) 2002 Epiphone Elite Standard Plus Faded Cherry 2005 G&L Legacy '79 Alvarez 12 string 2007 Seagull 6-string acoustic Vox AD60VTX "Have you hugged your Custom today?"
#13 (permalink) |
the missus will remove my knob if i spend any more time on this forum....
1983 LP Custom Taylor T5 Custom Ibanez RG 7-string Eastwood Ovation GP Tribute Genz Benz El Diablo 100 Marshall 1960AV Cab |
#15 (permalink) |
![]() Join Date: Apr 2008
I think you did a great job man. That would be a nice tool for a luthier or tech just because it eliminates any chance of hurting the finish or bending a post. You need to patent it.
#16 (permalink) |
That's cool. It's a lot cheaper then the stewmac version. Very clever.
Knob & Bushing Puller at Stewart-MacDonald
![]() click below to for details: |
#19 (permalink) |
![]() Join Date: May 2008
Mrs Wayne Bobbit's preference was one of these ...
'Long tenons......Short tenons. When the drummer comes in, what the fuck does it matter'. |
#22 (permalink) | |
Very nice device though inxs996! |
#23 (permalink) |
Looks good! i've been using a new shoelace, the wide flat kind you get in trainers/sneakers. wrap it around underneath once and tease opposite sides side up gently at a time. this should do untill that fine gadget hits the shops and we can save a few on new knobs!
www.myspace.com/doghousemusic www.myspace.com/underdogpunkrock 87 standard 80 deluxe/standard =NOW FOR SALE!!!!!!!!! 73 goldielocks 59 spec one off copy JCM Slash
#24 (permalink) | |
#25 (permalink) |
I use the handle part of those plastic grocery bags your groceries are placed in at the check at Walmart.
Steve Lets put the "Les Paul" back in "MyLesPaul" |
#26 (permalink) |
the product is already in production it would be dificult to get a patent for something you can already buy
Knob and Bushing Puller at Stewart-MacDonald |
