#2 (permalink) |
Re: Floyd Rose on a Les Paul?
Not if you want it.
Even Roman's making one, and gibson have their axcess. I'd say it looks quite good. Only thing is that you should like Floyds if you want to have it. |
#6 (permalink) |
i havent played the axess but i heard a lot good and a lot bad i think that the new body workout seems nice
B lessed U nder-rated C reative K ickass E lectrifying T ranquility H onorable E motion A wesome D efinitely the best guitarist of all time |
#9 (permalink) | |
MLP Trucker
![]() Join Date: Apr 2008
#10 (permalink) |
It would be the same thing on an Epiphone, except that I don't know that they make one already installed on an Epiphone. If not, that would involve routing the top of the guitar *and* the back of the guitar. Depending on the neck angle of the Epiphone (or a standard Les Paul, for that matter), you *could* end up with a Floyd that sits way too high on the guitar and the case might not close.
While it isn't *necessarily* so, there seems to be an assumption that someone playing a guitar with a Floyd on it is more likely to use the upper frets. All three of the guitars in my photos have modified neck heels/body joins to permit more comfort in that regard. The Axcess and the CSB Agile both have smooth, cut-down neck heels: ![]() And the AL2000 has a neck heel cut on a diagonal. That, and the neck is pushed *up* on the guitar (making the guitar longer) so that the 24th fret is at about the same spot vis a vis the bottom of the cutaway that the 22nd fret would normally be: ![]()
#12 (permalink) |
yes i know the whole neck joint and stuff like that and that it has a floyd
#13 (permalink) |
Ive actually tried an axcess...they aare pretty good.... and just about the same look in the back as thwe guitars above....
#14 (permalink) |
"What Can I Give To Be With Her And Finally Be Alive?"
![]() If you like heavier music, check out my band/music page at http://www.facebook.com/pages/The-Ch...s/135980114188 My light amplification by stimulated emission of radiation is currently being energized. Ergo, that which is Whoop will verily be Shooped. Genuinely. |
#15 (permalink) | |
Yeah, I know, all Axcess guitars have a CS or "Custom Shop" serial number prefix, but the standard production models have rosewood fretboards, plastic inlays and no inlay around the headstock. In addition, the standard colors are iced tea and gunmetal grey. Gibson has produced a few in a translucent red and a translucent green, but it's believed that those are not production guitars -- just trial balloons from the custom shop. To get one in black with an ebony FB, MOP inlays, binding at the headstock, gold (or black) hardware, etc., you have to place a Custom Shop order and have it built. So that one is a Custom Shop Custom Shop Axcess Custom <G>. Or something like that. |
#17 (permalink) |
Floyd? On a Les Paul?
Hersey, HERSEY; You bunch of heathens!
Seth - '07 Epiphone Les Paul (MIC, SD Pearly Gates bridge, Gotoh hardware) Sadie - '04 Ibanez GAX30 (MII, SD JazzN, SD '59b) Melissa - '08 Taylor 214 Grand Auditorium Vox Valvetronix ADVT15 Ibanez Tubescreamer TS9DX Vox 847A Wah (True Bypass, Inductor Mod) No Mids??....... ![]() Note to self: Line6 = Tone Herpes |
#18 (permalink) | |
How much does your case compress the Floyd when you close it? Yours is an epi, but I've seen a Gibby with a floyd mounted high eat nearly through the top of the case... |
#20 (permalink) | |
I haven't measured but the Floyd is not that high off the body. The guitar is very comfy to play. As far as the case, I pulled the lining back enough to remove a bit of padding right where the Floyd is and it fits fine. I'm considering buying an LP Axcess next year but I want to A/B it with this guitar first. I know it's "only an Epi" but it plays and sounds remakable. Other mods to it are CTS and Switchcraft electronics and Tonerider Generator pups. I also dulled the poly finish and refinished the top with Tru Oil. The Floyd on it is a Gotoh BTW. |
#21 (permalink) | ||
I've found that the Agile's "blunted" horn actually gives me better upper fret access than does the pointier horn of the Gibson; I've often run into the inside of the horn with the side of my hand. Not so with the Agile. Quote:
I like the look of Tru-Oil and Tung Oil finishes, but I'll never put them on the bodies of another guitar that will be used frequently. I've got two guitars with bodies finished in those materials, and if you play them a lot, they just absorb and retain dirt and stains. Both are approaching 20 years old and have been played, and both look shabby (and not in a cool mojo kind of way) and will require some serious sanding and refinishing (in poly this time). Meanwhile, their siblings with the poly finishes (same age, same history) are still looking good. Both guitars are solid koa, and it's a shame that they were oil finished in the first place. Interesting thing about Floyds -- OFRs for OEM at large manufacturers are manufactured in Korea. Have been for two years. ONLY OFRS destined for the aftermarket or for tiny boutique builders are still made in Germany (by Schaller?). The licensed Floyd on the cherry sunburst Agile, it turns out, was built on the same assembly line as the OFRs, with the only difference being the identity stamping. We inspected it pretty carefully against an OFR and even the machiining marks are identical. IOW, exactly the same as the black one on the Gibson. The LFR on the black Agile pictured, however, was done somewhere else (to be expected; this is a $289 guitar). But since it's dimensionally identical to the OFR, I'll be able to replace it, when the time comes, with the German OFR. |
| Limited Edition Les Paul Studio with Floyd Rose? | drewk86 | Epiphone Les Pauls | 23 | 08-22-2009 09:37 PM |
| Les paul with floyd rose!!!!! | mojofilter | Gibson Les Pauls | 20 | 01-11-2009 12:49 AM |
| Epiphone Les Paul Special II with Floyd Rose | Ar0Rose | Epiphone Les Pauls | 6 | 12-24-2008 06:19 AM |
| Anyone see a Les Paul with a Floyd Rose? | El Toro | Gibson Les Pauls | 83 | 12-20-2008 10:16 AM |
| Les paul Jr. Bridge///\\\Floyd Rose | Ryan_Riot | Gibson Les Pauls | 11 | 06-15-2008 09:23 AM |
