Old 04-14-2009, 11:46 PM   #1 (permalink)
VILLANOVA's Avatar
VILLANOVA'S Guide To Aging Metal Hardware (Pic Heavy!)
So I decided to experiment and age the hardware I bought for my epiphone LP. I read threads about how chrome CANNOT age and was glad that the parts I bought (replacement tail piece and tune-o-matic) were able to be aged.
I gathered everything in my room and got to work. For the aging, I used Etchant solution (easily found in Radio Shack for us Americans). I also had some 0000 grade steel wool on hand, as well as a sponge or two (with the abrasive back side).
Other then that, I used some cotton balls, paper towels, and a couple of large bowls. Be sure to keep a couple of bowls of clean water on hand. You'll need to quickly dip the parts into water to stop the etchant from doing any more aging. This is how you control it.
Sorry I didn't take any pics of the aging process :/
Before you start, if you have silver polish, you're supposedly able to polish the piece back to almost normal and try the aging again. This only worked with the aluminum tailpiece. I can't vouch for any other parts.
And finally, DO THIS AT YOUR OWN RISK!
What I did was create a solution with a total of 1/2 cup water and 1/4 cup etchant solution. The stuff is yellow and smells awful. Be sure to work in a well ventilated area, use gloves, and even eye protection (should you feel it necessary).
From here, I made a harness out of floss (ingenuity!) and dipped the tailpiece into the solution for 2-3 seconds max. MAKE SURE TO DIP THE PIECE IN ALL TOGETHER AND EVENLY. After, I quickly dipped the TP into a bowl of water. I checked the aging, decided it needed a little more, and dipped it back into the solution for another 2-3 seconds (followed by quickly moving the TP to the water bowl). Be careful if some of your parts aren't fully nickel or aluminum. Underneath there is copper. If you leave a piece in for too long, it will eventually "age" to this copper level.
I did this until I reached a level I was satisfied with. I then moved on to the tune-o-matic and the studs/bushings for each.
For the pickup cover, I got a little lazy. I didn't want to remove it so I did this instead. I taped off the sides so no water would leak. Then I dipped a cotton ball into the solution, and prepared a very damp cloth in my other hand. I quickly wiped the PU cover with the cotton ball and then wiped it with the damp cloth a second or two later to stop the etchant. I slowly did this until I reached a level I was satisfied with. Please use extreme caution. I don't know what etchant will do to your pickup and the inside of your guitar, should you use too much solution or water.
After doing this for some time, I finished all my pieces. After drying them, what I did was give each piece a quick rub down with some 0000 grade steel wool (when doing a PU cover, make sure to keep that tape on. Cleaning bits of steel wool from the sub-top portions of a pickup sucks). This, IMO, made the parts look smoother and helps enhance the effects of the etchant.
After this step, if satisfied, you should be finished
Some of my pictures aren't the best. It's roughly 12:40am here and all I've got is my weak ceiling light.
Enough talking, here are the pictures
I'd be happy to answer any questions you have. Enjoy!
Nickel Tune-O-Matic v. Stock Epiphone
Gotoh Metric Tailpiece v. Stock Epiphone
Random Bits v. Stock Epiphone Random Bits
VILLANOVA is offline   Reply With Quote
The Following User Says Thank You to VILLANOVA For This Useful Post:
Old 04-14-2009, 11:46 PM   #2 (permalink)
VILLANOVA's Avatar
Re: VILLANOVA'S Guide To Aging Metal Hardware (Pic Heavy!)
SD Nickel Pickup Cover v. Stock Epiphone Pickup Cover
It's almost like a mirror! Note: Jimi Hendrix reflection haha
ALL TOGETHER NOW!
Old 04-15-2009, 12:44 PM   #3 (permalink)
SABLE's Avatar
Awesome thread.
In Blood,
SABLE
I'm happy I live with my brother. I'm even happier he's with the FBI Special Quarter 7 Crew, hah. Bodyguard and political prosecutor anyone?
Guitars and strings go together for Gibsons
Guitars and etching acid go together for Fenders
SABLE is offline   Reply With Quote
Old 04-15-2009, 05:54 PM   #4 (permalink)
Sinster's Avatar
Try Wood Bleach (oxalic acid)... I haven't tried it but when I used my spoon to stir it up it made it look aged.
2009 Les Paul Kit - GFS Dream 90 (N), SD Seth Lover (B)
2009 Gibson Les Paul Worn Brown
2009 Epiphone Studio Deluxe
2008 Epiphone Custom - GFS VEH (N), Fat Pat (B)
2008 Ovation Celebrity CC48
2007 Agile AL3000 - SD Alinco II set
2005 Epiphone Standard - SD Pearly Gate (N),SD Alinco II (B)
2004 Epiphone Custom Plus Top
2004 Gibson SG Faded - Stock
1997 Epiphone Slash Snakepit
1995 Fender Strat - SD Lil 59' Bridge, SD Hotrail Middle, Stock Neck
Sinster is online now   Reply With Quote
Old 04-25-2009, 03:03 PM   #5 (permalink)
VILLANOVA's Avatar
Originally Posted by SABLE View Post
Awesome thread.
Thanks. Anything to help out MLP'ers
Old 08-10-2009, 04:15 PM   #6 (permalink)
#1guitarman's Avatar
Send a message via AIM to #1guitarman
Bump for a GOOD thread!!
.....................TONEMOJO ROCKS!!!.....................
.. "Live every day as if it were your last, one day it will be...."
Hairs turnin' WHITE, necks always been RED, collars still BLUE
#1guitarman is offline   Reply With Quote
Old 08-10-2009, 11:44 PM   #7 (permalink)
lp_junkie's Avatar
good work.
LP_Junkie
____________________________________________
Shane Dunn on ReverbNation
NOA Album sneak peak
Cherish your friends and don't take the days for granted
lp_junkie is online now   Reply With Quote
Old 10-11-2009, 06:35 AM   #8 (permalink)
Gibson's Avatar
Ive always loved the look of age nickel on guitars
]"Its 40% how you play and 60% how you look"
Slash
GAS List:
Gibson Les Paul Studio Worn Brown
Boss RC-2
Vox VSF5 Footswitch[/COLOR]
ಠ_ಠ
Gibson is offline   Reply With Quote
Aging metal hardware Drayke The Custom Shop 32 02-05-2009 04:24 AM
82 year old heavy metal fan! WildeStarr The Backstage 13 01-15-2009 02:42 PM
Have a HEAVY METAL CHRISTMAS! Pwozzie The Backstage 4 12-25-2008 10:05 AM
Heavy Metal Concerts... Paul_Cat Epiphone Les Pauls 54 11-24-2008 03:23 AM
Looking for a p90 with some fat heavy metal tone EEF13 Pickups 7 11-05-2008 06:28 PM
Powered by vBulletin® Version 3.8.4
