Old 03-09-2009, 09:10 PM   #31 (permalink)
djwilbanks's Avatar
Re: BFG Refinish -- Flame top?!
Well, that was my first idea, but I didn't have any on hand (from the can), and I am quite a ways away from an air compressor and a nozzle, unforunately.
The thing is that the dust is down in the pores... I wonder if compressed air would even do any good.
º|||||º
djwilbanks is offline   Reply With Quote
Old 03-09-2009, 09:22 PM   #32 (permalink)
Master Crafter
Last's Avatar
Gee, I dunno. I've never run into this issue.
I take it you're not refinishing the back/sides/neck?
I usually refinish the entire guitar then fill the Mahogany with Wood Grain/Pore Filler (clear).
If you're not going to do any refinish work on the back/sides etc. then I'd leave it be either until you get to a compressor or until you're satisfied that it's cleaned up enough to go ahead & tung oil it?
I assume you will be using a Tung Oil?
If you're going to just leave it though. I'd forget about it & focus on that top!
Last is offline   Reply With Quote
Old 03-09-2009, 09:28 PM   #33 (permalink)
purevilpleasure's Avatar
Send a message via Yahoo to purevilpleasure
Yeah don't bother with the canned stuff, that won't do it for ya. Got a friend that works at a factory?? I do and we have a huge compressor that will easily blow out any dust in those pores. I have a good size one out in the garage that would do it also. Another place to see if they would do it for you is a shop class at a high school or an auto body place.
purevilpleasure is online now   Reply With Quote
Old 03-09-2009, 09:45 PM   #34 (permalink)
Master Entertainter
alligatorbling's Avatar
Send a message via ICQ to alligatorbling Send a message via AIM to alligatorbling Send a message via MSN to alligatorbling Send a message via Yahoo to alligatorbling
+1 on an auto body place, any garage with an air compressor would prob do it for you...
"It is no measure of health to be well adjusted to a profoundly sick society."
-Jiddu Krishnamurti
alligatorbling is offline   Reply With Quote
Old 03-09-2009, 09:52 PM   #35 (permalink)
djwilbanks's Avatar
Well, I've got plenty of friends... they just live an hour away where I went to automotive school.
I'm not planning on refinishing the rest of the guitar... if I do I'm just going to dye the mahogany with a dark coloured dye. I have a feeling it'll all come out eventually anyway. I'm not sure if I'm going to nitro it just yet... depends on how I can get a burst to look by wiping. I'll probably have to do a vintage amber dye and an orange coat of laquer. We'll see.
I didn't have any alcohol this time to try so I'll get some tomorrow and try.
I just want to get the top finished.
º|||||º
Old 03-11-2009, 05:48 PM   #36 (permalink)
FennRx's Avatar
david,
i could just tell there was a nice top under there. i toyed with having it professionally Bursted, but i sold it to ya instead. i am eager to see how she turns out.
FennRx is offline   Reply With Quote
Old 03-11-2009, 08:56 PM   #37 (permalink)
djwilbanks's Avatar
it won't be professionally done, but I've done enough automotive painting to handle a spray gun. We'll see.
Thanks for killer deal, BTW. It just keeps getting better.
º|||||º
Old 03-16-2009, 01:03 AM   #38 (permalink)
djwilbanks's Avatar
Bump for an update.
I finally got all the dust out of the pores, and polished up the top a little bit just to see if I could bring out the flame. I'll have to clean it with naptha before I dye it, but I wanted to see what it would look like.
Results?
º|||||º
Old 03-16-2009, 07:14 PM   #39 (permalink)
very nice my friend.....
dogbone94 is offline   Reply With Quote
Old 03-20-2009, 01:04 PM   #40 (permalink)
djwilbanks's Avatar
Since Mike (aka: rottenlpconer, aka: ole'leftey, aka: pretty much one of the nicest guys I have ever dealt with) is putting together a new headstock overlay with a Gibson MOP logo and crown inlay, I decided it might be a good time to get that old overlay off.
So here's the process.
First, gather up a few essentials... these are what I used and I suppose you can use similar objects.
1 x Frosting Spatula
1 x razor blade
1 x pocket knife
1 x bottle of water
1 x Clothes Iron
1 x wash rag
Now, lets prepare shall we? Remove the nut from the guitar. This is accomplished by scoring the finish (if you have one) with a razorblade, carefully, around the nut. Then you take a hammer or a rubber mallet and a file or a similar wide, flat object and tap (only a tap!) the nut and it should come out easily.
No pics of that, because I forgot about my camera.
Next, plug up your Iron and get out your pretty ironing board (if you don't have a workbench, like me) and place the guitar onto the ironing board. I don't think I have to tell you the horrors that would ensue should you knock your guitar from the ironing board. Do be careful.
Take the washrag, dampen it with your water and wring it out. Then place the rag over the headstock and place the iron onto the rag. I kept my iron on halfway until I realized it wasn't doing anything. I recommend you start low and work up higher since you don't know exactly how hot your iron will get.
Once it gets a little hot you can begin to work your knife under the overlay, prop open a gap with the knife and slip the spatula under the overlay. Close your knife, you won't need it anymore. Then you repeat the iron and the rag, hold it on for a few seconds, then begin to work the spatula under the overlay working towards the top of the headstock.
I chose a metal spatula, against the better judgement of those more knowledgeable, because I assumed its heat transfering properties would allow me to slice through the glue more readily. It worked, but truth be told the whole time I was worried about digging into the headstock or breaking the overlay. It also can burn you if you let it get too hot. Ask me how I know.
Once you repeat these steps a few times and redampen the rag (a little bit of the water from your bottle will go a long way) as needed, the overlay should come right off... right as rain.
You're then free to put it on your wall, or send it to a perfectly capable gentleman as a guide for your new overlay.
Just a side note, I ordered all my dyes, nitro, and grain filler from stewmac last night. We're nearing the meat and potatoes portion of this thread folks!
º|||||º
Old 03-20-2009, 01:16 PM   #41 (permalink)
The_Sentry's Avatar
Jeez...that top looks great!!! That was a very clean work on that headstock! Dude...I think you have a raw talent for this sort of stuff...I'm not kidding.
(PS: That BFG is going to look amazing!!! I can't wait to see the finished product!! )
The Geartalk Video Blog
The_Sentry is online now   Reply With Quote
Old 03-20-2009, 01:19 PM   #42 (permalink)
djwilbanks's Avatar
I can't either... I've been told all my life I need to learn delayed gratification...
I'm learning.
And thanks, but the raw talent is just me going slow and standing on the shoulders of giants.
º|||||º
Old 03-20-2009, 07:25 PM   #43 (permalink)
Sinster's Avatar
What you going to do with the old overlay? If you don't have any use for it I'll take it off your hands. I really wanted a custom one but hey my skills aren't all that.
2009 Les Paul Kit - GFS Dream 90 (N), SD Seth Lover (B)
2009 Gibson Les Paul Worn Brown
2008 Epiphone Custom - GFS VEH (N), Fat Pat (B)
2007 Agile AL3000 - SD Alinco II set
2005 Epiphone Standard - SD Pearly Gate (N),SD Alinco II (B)
2004 Epiphone Custom Plus Top
2004 Gibson SG Faded - Stock
1997 Epiphone Slash Snakepit
1995 Fender Strat - SD Lil 59' Bridge, SD Hotrail Middle, Stock Neck
Sinster is offline   Reply With Quote
Old 03-20-2009, 08:01 PM   #44 (permalink)
djwilbanks's Avatar
I need it for some tracings to send to mike and then I won't have a use for it anymore.
º|||||º
Old 03-20-2009, 08:04 PM   #45 (permalink)
Sinster's Avatar
I'll take it!!!! If the price is right
Old 03-20-2009, 08:26 PM   #46 (permalink)
djwilbanks's Avatar
The price will be excellent I assure you.
º|||||º
Old 03-20-2009, 10:16 PM   #47 (permalink)
This is a great thread! Inspirational really! Thank you sir!
Paul86 is offline   Reply With Quote
Old 03-20-2009, 10:22 PM   #48 (permalink)
djwilbanks's Avatar
Now we need more people refinishing BFGs.
º|||||º
Old 03-20-2009, 10:48 PM   #49 (permalink)
Skynyrdpicker's Avatar
Good work so far!
What are you going to do about inlays?
Check out my MySpace!
Skynyrdpicker is offline   Reply With Quote
Old 03-20-2009, 10:51 PM   #50 (permalink)
djwilbanks's Avatar
I'm not sure. I want trapezoids. I feel fairly confident that I could do them myself if I could get a hold of a set.
º|||||º
Old 03-20-2009, 11:00 PM   #51 (permalink)
Awesome! That'll look great
Old 03-20-2009, 11:07 PM   #52 (permalink)
djwilbanks's Avatar
I'm going to dye the fretboard with this:
Black Fingerboard Stain at Stewart-MacDonald
And then I'll think about the traps.
I'm still thinking about binding the body... working on that headstock awoke a love of cutting/scraping/and otherwise destroying perfectly good wood.
º|||||º
Old 03-21-2009, 12:20 AM   #53 (permalink)
Sinster's Avatar
So you are dying it not painting it? You going use a spray gun?
I'm going hold off on painting mine as well until I see how yours turn out.
I was going do the vintage amber http://www.stewmac.com/shop/Finishin...r_Lacquer.html lacquer, really want to know if the stain would be better..
Old 03-21-2009, 12:25 AM   #54 (permalink)
djwilbanks's Avatar
I am dyeing the top and then I'm using stew-mac's aerosol nitro. Nitro is nitro and it all melts together regardless of how its sprayed. I won't get a perfectly level finish from the rattle-can without a bit of elbow grease but I believe I can get a workable finish.
º|||||º
Old 03-21-2009, 10:38 AM   #55 (permalink)
markophonic's Avatar
DJ...You will get a more than adequate finish from a spray can. Remember your finishing a guitar top, not a bus.
Even if you spray with a gun you will still have to finish sand it smooth and it doesn't really take too much elbow grease at all....Let the paper work the finish...no need to bear down on it at all.
A gun is nice if your bursting but if you are just spraying a clear coat a spray bomb is fine.
I'll put my recently refined standard fadeds topcoat (sprayed with a can) up against anyones gun sprayed topcoat any day.
The BFG is looking great!
I can't wait to see it completed...
Makes me kinda wished I traded you for it
"To me, the guitar is a friend when there's nothing else around. Everyone else is asleep or gone, or your lady's left you, Well, You've always got her, I mean, the shape alone...I sleep with the thing sometimes" --- Keith Richards
markophonic is offline   Reply With Quote
Old 03-21-2009, 10:42 AM   #56 (permalink)
djwilbanks's Avatar
thanks for the reassurance, my friend.
º|||||º
Old 03-21-2009, 02:24 PM   #57 (permalink)
Master Crafter
Last's Avatar
I don't have a spray gun either & I'm on my 6th refinish!
I know you've seen my work so I won't bore you with yet another pic but rattle cans work very well indeed!
Go for it!
Old 03-22-2009, 01:55 AM   #58 (permalink)
CEO Teen Axe Leader
Gunner's Avatar
DJ, its really looking good. I'm liking the subtle flame a lot Bro!!!
TAD Member Ekom's Band are Recording Artists known as JungleUnderKings. Sample their music at www.myspace.com/jungleunderkings
Come visit us at www.geartalk.com
Take me on a trip upon your magic swirlin' ship,
My senses have been stripped, my hands can't feel to grip,
My toes too numb to step, wait only for my boot heels
To be wanderin'.
Gunner is offline   Reply With Quote
Old 03-22-2009, 07:04 PM   #59 (permalink)
Epi Verification Expert
Sinmastah's Avatar
That's a nice looking flame. Shoot me a PM when you get this baby finished, I wanna see it!
Epiphone Elitist SG Faded Cherry (Tone Mojo'd and WB'd)
Faded Cherry Epiphone SG G-400
Flamed Cherry SunBurst Epiphone Les Paul Plus Top
Fender Mexi Oly White Strat
Squier Natural Vintage M Jazz bass
Peavey Classic 50
SG's FTW
Sinmastah is offline   Reply With Quote
Old 03-22-2009, 07:18 PM   #60 (permalink)
djwilbanks's Avatar
º|||||º
refinish? mcl116 The Custom Shop 8 12-06-2008 04:14 PM
refinish? beanoburst66 The Custom Shop 4 11-02-2008 05:23 PM
How about this for a refinish idea? nitrous12 Gibson Les Pauls 3 10-24-2008 10:24 PM
Refinish? radicalcon The Custom Shop 2 07-17-2008 09:49 PM
Great Flame...a lesson on selecting a nice R9 flame tasticafe Historics & Reissues 42 03-27-2008 05:04 PM
