Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Unread 03-01-2009, 08:21 AM   #1 (permalink)
need help with wiring diagram
With all my coursework and exams latley i haven't had time to do my guitar wiring but i had time today and pulled out the schematic i had, and now i'm confused
look at the capacitor that is soldered to the vol and tone pots. It is soldered to one of the lugs of the volume pot, but then i think it shows that lug being soldered to the shell ?! Also, you see the connection between the tone and volume pot just below the cap, it shows the lug of the volume with the connection havin another wire soldered to it (that leads to the 3 way); what is this ?! sorry for being so noobish x)
please if anybody can explain to me what those solder connection are i'd be really grateful
File Type: gif Les Paul Style Pick-up Wiring Diagram.gif (9.6 KB, 23 views)
crispacket is offline   Reply With Quote
Unread 03-01-2009, 08:25 AM   #2 (permalink)
dennistruckdriver's Avatar
Re: need help with wiring diagram
That's the ground for that cap, and since that lug has to be grounded also, it is just as easy to bend the lug over, and solder both the leg of the cap and the lug at one time to the back of the pot. It makes for a more solid solder joint.
Unread 03-01-2009, 08:29 AM   #3 (permalink)
ahhh i see, thank you dennis
after i wrote the question i looked at the schematic again and realised i wa confused with something else xo wonder if you could help me there too?
but thanks still
Unread 03-01-2009, 08:36 AM   #4 (permalink)
There are guys here who will eventually get around to answering your questions. Go ahead and post it, and someone will answer sooner or later. I do not actually know much about wiring; I just knew about the lug being soldered to the pot.
Unread 03-01-2009, 10:09 AM   #5 (permalink)
the bull's Avatar
Your pickups have a ground and a hot. The shell of the pots are ground. You can solder your ground side of the pickups to these. Then run the hot sides(from both pick ups) back up to the 3 way switch I like to do this with thin wire. The wire running from the 3 way to the volume pot is your hot wire coming from the pickups, depending on where the switch is set it will send back both or just one (selected) pickup signal(s).
the bull is offline   Reply With Quote
Tags
wiring diagram
