#1 (permalink) |
Super Moderator
Pots : 250k / 500k / 1 Meg ????
250K / 500K / 1 MEG ???? how do each effect the sound ? Full on is full on right? Is it the amount of sweep that is different? Is one better than the other for volume or tone controls ?
| The Following User Says Thank You to FLICKOFLASH For This Useful Post: |
#2 (permalink) |
![]() Join Date: Jun 2007
Re: Pots : 250k / 500k / 1 Meg ????
Using 500k pots with humbuckers as the standard, a 1 meg will have a brighter sound with more output, a 250k will be darker with less output. Some guys mix and match different ohmages like a 1 meg volume with a 250k tone, but IMO if it ain't broken, why fix it?
#3 (permalink) |
Lexluthier pretty much covered it. The lower the value pot, the lower the resonant peak. This is a nice fine-tuning tool for overly bright or dark guitars. I have a R7 that was excessively bright so I installed a 250k volume pot to shave off some of the high end. Worked like a charm.
#4 (permalink) |
Super Moderator
On TGP someone said :Gene Baker and Dimarzio recommend a 250K volume and 1 Meg tone with a .022 cap between as the best compromise.
Gene came across it while at Fender, it was some trade secret there, and he uses it in ALL his guitars. |
#5 (permalink) |
![]() Join Date: Aug 2007
There are ranges and options inbetween, 550 K, Pots, 300 K pots, 300 not as cutting as a 250, 550 for a lil more range, just some thoughts to add, and options to possibly consider
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#6 (permalink) | |
I use different values depending on the guitar. I also measure my pots to position them optimally to the specific guitar (regardless of the advertised value). But (IMO) a 250k volume and 1meg tone sounds like a good setup for a bridge position 'bucker in most guitars. |
#8 (permalink) | |
RS Guitarworks Online Store
#9 (permalink) | |
#10 (permalink) |
Contact RS, They might sell them that way, You asked and I found you an answer, I sometimes help my kids with their homework, I darn sure dont do it for em'
#13 (permalink) |
Super Moderator
I got 250K volume control and a 1 Megohm tone control, (vintage) & wondering what you think / dimarzio & Gene Baker recommends this too. would I need a hotter pickup ?
Regardless of what type of pickups are in your guitar, higher potentiometer resistance values produce a little more power and treble response. Whether this is a good or a bad thing is a matter of individual taste. In the early days, Gibson used 500K controls and Fender used 250K, thereby starting the single-coil = 250K, humbucker = 500K theory. Even though neither company has stuck strictly with this formula since then, the theory lives on. You won’t damage your pickups or your amp by mixing and matching different value controls, and one of our current favorites is a 250K volume control and a 1 Megohm tone control, EP1202.( DiMarzio) |
#15 (permalink) |
Years ago I experimented with 1 meg pots, sure the output was boosted, but the treble was too. For metal playing where you wanted the guitar to scream, it wasn't such a bad thing. The thing I hated was the pot taper of the 1 meg audios I was using.
A proponent of 250k volume and tone pots with humbuckers is Allan Holdsworth. He uses PAF-output (with screw poles on both bobbins) pickups with 250k pots, gives him some of that rich, warm tone he is known for.
#16 (permalink) |
Marty Friedman used to do that with his Jackson Kellys. He wired them straight to the Jack. Jackson refused to do that with his siggy guitars and put a volume knob on them.
#17 (permalink) | |
#18 (permalink) |
Similar in design, but with alnico magnets and wound to low output PAF type specs. Dirty Fingers had ceramic magnets and mega hot winds.
Allans pickups are Duncan 59's ordered with dual screw poles. Also Scott Henderson, back when he played humbuckers, used the same pickups. I think the dual screw pole idea is kind of cool, it changes the sound of the pickup because they sound different than slug poles. Check out the difference in sound between a Duncan JB and the old Duncan Holdsworth (which Allan never used, BTW). Exactly the same pickup, except that the Holdsworth had both bobbins with screw poles. The Holdsworth has a smoother high end and less of that upper mid hump the JB has.
#19 (permalink) |
Super Moderator
lex I got a vintage harness off ebay 250 K volumes 1 Meg tones & I have dead on vintage bumble bees ... should i convert the pots or try a extra hot pickups ? Would like your thoughts . I am looking for a fat thick tone not a strat on a LP tone
#20 (permalink) | |
ok I have 496R/ 500T set in my fav Les, generally I like the sound of the front but want to darken up the rear, a bit, make it creamier thicker , just trim off a lil of the high end, my tone setting on that pickup when using it exclusivly is normally 5-7 on the tone, its rarely dimed out ever My present caps are the factory orange drop type .o22UF
#21 (permalink) | |
![]() Join Date: Mar 2007
Have you tried lowering the pickup ( I'm sure you have )Ok so First try an .033 Cap ( Orange drop 715P ) If it's still too bright go to a .047
#22 (permalink) |
Hey Bro, I went over and paid a visit to my fav tech wizard amp guy, He maybe joining us shortly I told em specifically about our convo on this, and he agrees, I cant drop the pickup much more without losing the close eveness of the volumes but I amg gonna try, I do think .047's may possibly make it too dark, and I will lose nearly all my high end treble end on my amp is also between the 12 and 1 o' clock postions, bass and mids straight up 12, Seems to be good
#23 (permalink) | |
#24 (permalink) |
I knew that Brother HG,. I got no worries at all man I do want a new set of Custom handwounds, which we discussed , Now which Les will they go in first, this is the $64,000 question
#25 (permalink) | |
My problem with dicking around with tone caps is, if you actually use your tone pot, using a .047 with humbuckers is going to sound like shit if you roll it back, total mud tones. I actually like a .015 cap for the bridge pickup, because it is more useable for me. With some overdrive going, you can roll it back and get the woman tones without the tone turning into farty sounding glop. I also like .022's if they are good sounding ones. They all sound different. Best cheap ones I've found are those Russian military surplus PIO caps you can get on Ebay.
#26 (permalink) | |
#27 (permalink) |
You can also experiment with 50's style wiring and modern style. Both work differently, even though electronics experts will tell you there is no logical difference. I personally like 50's style wiring, it lets more of the highs through when rolling back the vol. pot without using bypass cap, which is another pet peave of mine. LOL
I hate bypass caps, I find the highs they bleed thru sound artificial, and messes with the taper. Every guitar I buy that has them, they get clipped out pronto.
#28 (permalink) | |
On my Orville Les Paul I have three Jap Caps and one Gibson, I Believe that one is still modern wired , when you roll down/back the tone cap sometimes it also has a tendancy to clip volume a bit, can this also be fixed with 50s type wiring?
#29 (permalink) |
MVP Clown
![]() Join Date: Sep 2007
A discussion about POT and I wasn't asked for my expert opinion ?? Ohh it's guitar pots !!! as Gilda Radner would say ... " Nevermind " !!
#30 (permalink) | |
Super Moderator
| 500k Pots Volume and tone | ozone | Tonefreaks | 100 | 05-15-2009 06:56 PM |
| 500k pots stock? | schmidty123 | Tonefreaks | 2 | 04-24-2008 03:45 PM |
| FS: Gibson 500K Long Shaft Pots | WildeStarr | Member Classifieds | 0 | 01-30-2008 04:01 PM |
| Super pots vs standard 500k cts pots | JPizzzle | The Custom Shop | 3 | 01-30-2008 01:01 PM |
| FS: CTS 500K Pots, Audio Taper, Short Shaft | Darkburst | Member Classifieds | 1 | 01-20-2008 10:47 PM |
