Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Unread 07-30-2012, 04:35 PM   #1 (permalink)
Re-shaping neck
I bought this travel guitar for a trip to Mexico, but I don't like the neck. It's a baseball bat... I like thin necks.
So, I went to HomeDepot and got some 180, 220 and 400 sandpaper thinking I'd just start sanding away.
Do you guys have any advice before I begin?
Doxastic is offline   Reply With Quote
Unread 07-30-2012, 04:37 PM   #2 (permalink)
Re: Re-shaping neck
Oh... here's the guitar:
Martin LXM Little Martin | Sweetwater.com
Unread 07-30-2012, 09:18 PM   #3 (permalink)
Re: Re-shaping neck
have at it, but mind the truss rod of course
kezian is offline   Reply With Quote
Unread 07-30-2012, 09:57 PM   #4 (permalink)
Re: Re-shaping neck
Yeah... I will. Then again, I have no idea where it is in there. And I won't know until I hit it.
Unread 07-31-2012, 10:49 PM   #5 (permalink)
Re: Re-shaping neck
hmm i wonder if a trip to the local dentist would shed some light. wonder if anyones done that before
Unread 08-01-2012, 03:55 AM   #6 (permalink)
skynyrd67's Avatar
Re: Re-shaping neck
You`ll want to start off with 80 grit,, the 180 will take forever to work the neck down, I used my palm sander to take mine down, just take it down a little at a time and check it often for feel.
skynyrd67 is offline   Reply With Quote
Unread 08-02-2012, 10:34 AM   #7 (permalink)
Re: Re-shaping neck
Oh... yeah. That would have been good.
I started it last night. Started with the 180 and went to the 400.
The 180 did an ok job of taking it off. I picked up a dry wall hand sander to wrap the sandpaper around so I would sand flat. I guess sanding blocks are no longer used? I couldn't find one at any hardware store. But with that I was able to take a lot of quickly. A lot more than if I was just using my hand.
I stopped last night once I felt I took an ok amount off. I still think it could go thinner, but I wanted to sleep on it. You can always sand away neck, can't really add more to it.
Unread 08-03-2012, 03:37 AM   #8 (permalink)
skynyrd67's Avatar
Re: Re-shaping neck
USually a walmart carries the block sanders back in the paint dept. Alot of times if you lay the neck down and look at the back of it like a clock removing wood from the 10 o`clock and 2 o`clock areas will make a big difference in feel. Without knowing how deeply the truss rod groove was routed in the neck you have to be careful how much of the very center you remove or you could wind up opening up the truss rod cavity. Thats why i mentioned just trying the 10-2 areas of the neck for the majority of the sand down.
