Old 10-24-2007, 06:15 PM   #1 (permalink)
MVP Clown
BOBBO's Avatar
Who Makes the Best ! Repro Gibson 50's Plastic ?
Who's aftermarket vintage reproduction parts do you prefer ?? I have had reproduction 50's style plastic from a bunch or makers but I thought I'd ask who's stuff you guys prefer ?? DMC ? Vintage Clone ? RS ? Fatboy ? Buzzy ? etc ! Please post pics of your stuff !
BOBBO is online now   Reply With Quote
Old 10-24-2007, 07:14 PM   #2 (permalink)
Sean French's Avatar
Re: Who Makes the Best ! Repro Gibson 50's Plastic ?
DMC for me.
However,I looked at the Vintage Clone parts from Historic Makeovers at the Arlington show and they look fantastic.
DMC parts:M69 rings,pickup covers,R/T ring,nut and tip,pointer washers.
Allparts:Replica pickguard,reflector knobs(gold insert).They look silver in the pic but,are light gold.
Pigtail:ABR-1,studs and tailpiece.
Pickups are Wolfetone DR. V's
Pots and caps are Rick Norman's Dr. Vintage Early Spec kit.
'07 R0.
[IMG][/IMG]
DMC: R/T ring,nut and tip.
Pigtail:studs
Pickups are Wolfetone Dr. V's
NOS Russian PIO .022uf caps and stock pots(soon to be Rick's Dr.Vintage kit)
'06 R0.
[IMG][/IMG]
Sean French is offline   Reply With Quote
Old 10-24-2007, 07:38 PM   #3 (permalink)
Darkburst's Avatar
Send a message via AIM to Darkburst
Generally speaking, DMC has the best parts if you're going for vintage accuracy.
My Site
My Blog
My Flickr Stream
Darkburst is offline   Reply With Quote
Old 10-24-2007, 07:46 PM   #4 (permalink)
MVP Clown
BOBBO's Avatar
I was under that impression too until taking a close look at some of the DMC hardware !! If so take a good look at the toggle switch nut , The DMC version is too pointy at the tips and not flat enough on the knurls ! I got a set of the DMC single line single ring tuners and the buttons had no swirl , color was ok but vintage Klusons had swirly buttons ! I recently replaced my DMC toggle nut with the one from Fatboy ! It has the vintage correct specs and look ! I then changed the tuner buttons to Uncle Lou's ! Now they look right !
Old 10-24-2007, 07:54 PM   #5 (permalink)
Darkburst's Avatar
DMC isn't perfect, but overall they're the best. It's true that some other companies have nailed certain parts better. If you want the best plastic you're going to have to mix and match.
My Site
My Blog
My Flickr Stream
Old 10-24-2007, 08:00 PM   #6 (permalink)
MVP Clown
BOBBO's Avatar
I have a mega mix and match .. You have to .. I have DMC tuners with Uncle Lou tips .. DMC rythm/treble ring but with a Fatboy nut ,,DMC switchtip ,,DMC M69 rings and version 2 PAF covers ,, Vintage clone pickguard and knobs ,, DMC thumbwheels & volume pointers ,,Fatboy pickguard bracket and screw ,, Pigtail steel studs ,, Luxe Bumblebee paper in oil cap repro's .. There's more but my fingers are cramping !
Old 10-24-2007, 08:43 PM   #7 (permalink)
Fatboy nut.(I borrowed this pic from the LPF)
[IMG][/IMG]
DMC nut on my '07 R0.
[IMG][/IMG]
Old 10-24-2007, 09:18 PM   #8 (permalink)
MVP Clown
BOBBO's Avatar
DMC toggle plate with Fatboy toggle nut mounted !! DMC nut on the side .. notice the points where the Fatboy is flatter ?
Old 10-24-2007, 09:26 PM   #9 (permalink)
Fatboy nut looks better
lp59aholicDon is offline   Reply With Quote
Old 10-24-2007, 09:30 PM   #10 (permalink)
MVP Clown
BOBBO's Avatar
Uncle Lou's
DMC aged tuner tips
Old 10-24-2007, 09:57 PM   #11 (permalink)
BOBBO,yeah I see what the diff is.
My aged DMC nut on my '07 is closer to the Fatboy than the DMC nut you have pictured.
The non aged DMC nut that's on my '06 is like the DMC nut you have.
Interesting.
My '06 R0 with the non aged DMC R/T ring and nut.I also just put the Historic Makeovers Vintage Clone switch tip on there.
[IMG][/IMG]
Perhaps there are two versions of DMC nuts?
The DMC tuner tips you had don't look very good IMO.
Uncle Lou's look way better.
Did you just get the DMC tuner tips or the whole DMC tuners?
One the DMC site the show the tuners and they look fantastic.
Very different from what you have.
DMC tuners.
[IMG][/IMG]
Old 10-25-2007, 07:49 AM   #12 (permalink)
MVP Clown
BOBBO's Avatar
Interesting.
[IMG][/IMG]
DMC tuners.
[IMG][/IMG]
Sean .. I got the DMC aged tuners with tips and just changed the tips to the Uncle Lou's !
Old 10-27-2007, 10:26 AM   #13 (permalink)
MVP Clown
BOBBO's Avatar
Buzzy is making great pickguards now !
Old 10-27-2007, 05:17 PM   #14 (permalink)
MVP Clown
BOBBO's Avatar
DMC rings and covers .. Vintage Clone pickguard
Old 10-27-2007, 05:19 PM   #15 (permalink)
MVP Clown
BOBBO's Avatar
I think the VC knobs are great or are they real ?? !
Old 10-28-2007, 09:49 AM   #16 (permalink)
badhabit's Avatar
Fatboy Retrovibe kit and Uncle Lou's Tips--
badhabit is online now   Reply With Quote
Old 10-28-2007, 04:44 PM   #17 (permalink)
lexluthier's Avatar
I make my own pickguards. Takes me about 10 minutes. Bottom one is a Historic guard, top one is mine.
lexluthier is offline   Reply With Quote
Old 10-28-2007, 04:56 PM   #18 (permalink)
Mike60's Avatar
the colour on yours is shitass perfect...do one for a '69GT?...
Mike60 is online now   Reply With Quote
Old 10-28-2007, 05:11 PM   #19 (permalink)
lexluthier's Avatar
I'd have to make a routing template. It's just cream plastic sheets from Allparts. Don't know why Gibson has such a funky color on their guards.
Old 10-28-2007, 05:20 PM   #20 (permalink)
Mike60's Avatar
...a '69 P-90 pick guard is the same as an R6 pick guard,even the screw hole at the neck matches...If you get around to doing any,give me a holler,I'd like one...
Old 10-30-2007, 02:35 PM   #21 (permalink)
MVP Clown
BOBBO's Avatar
Anyone have one of Buzzy's guards ?? If so
Old 10-30-2007, 07:24 PM   #22 (permalink)
Lex, do you have a picture of one of your guards installed.
RobertD is offline   Reply With Quote
Old 11-04-2007, 09:48 AM   #23 (permalink)
MVP Clown
BOBBO's Avatar
My R8 next to a pic from BOTB !
Old 11-11-2007, 07:04 PM   #24 (permalink)
MVP Clown
BOBBO's Avatar
That looks damn close to my Vintage Clone pickguard that I paid $80 for !
Old 11-11-2007, 07:23 PM   #25 (permalink)
Darkburst's Avatar
I posted pics weeks ago:
Pickguard Color Comparisons
My Site
My Blog
My Flickr Stream
Old 11-22-2007, 08:51 AM   #26 (permalink)
MVP Clown
BOBBO's Avatar
I meant mounted on a guitar so I could see what it looks like against maybe a set of DMC or Fatboy pup rings ?? etc
Old 12-08-2007, 10:39 PM   #27 (permalink)
MVP Clown
BOBBO's Avatar
Mostly DMC ... color comparison to BOTB .. different Burst
